Customs Finally starting on the wife’s 56
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jan 5, 2019.
  1. Picked this up yesterday
    Like it better than the original hood bird
    A social media commenter said that some European countries didn’t like the original hood bird so GM did something similar to this ornament.
    I’m no expert but it looks better regardless
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    that is an aftermarket bullnose molding. I sold one in the cl***ifieds a few months back. As far as lowering the back of the wagon, the Astorian 55 has double stacked lowering blocks in back....
  3. DDDenny
    Yea, I've read that they viewed it as "not pedestrian friendly".
    Sharpone, Stogy and anthony myrick like this.
  4. Guy sent me a pic of this one.
    IMG_4478.jpeg similar. He mentioned the European ban on the bird
    the Rocco and Cheaters guy had a table with several pieces of aftermarket trim. Ford, Plymouth, Chevy pieces.
    I really didn’t realize the 56 hood had this shape stamped in it. I like this better and saves the work of reshaping the nose of the hood.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, that is why those were made. It was always the first thing people did back in the day was "nose and deck" that raised stamping in the hood killed that for the most part. The bullnose molding (flat hood bird) was the quick fix for that. I recently acquired a large collection of bullnose moldings and there was just one for a 56 chev and it sold immediately
  6. Was mine worth $25
  7. I’d buy it.
    Sharpone, Stogy, NoSurf and 5 others like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    man, that was really cheap. I get 100 for my bullnoses and on Ebay I have seen them for 300....
  9. A mint 55 with box sold for 50.
    im planning another trip the next Saturday he’s open
  10. chevy57dude
    chevy57dude
    Cool piece, you got a good deal on it. Europe was concerned about pedestrians getting impaled on hood ornaments, so they were banned. Pretty abstract to me, far fetched.
  11. Glenn S
    Glenn S
    Same in Australia. 56's were cut down and rounded off, 55's got through at standard length. Yes, so as not to harm slow moving pedestrians.
  12. 427 sleeper
    427 sleeper
    YES!!! Ban the hood ornament's, they're deadly! The 3500 pound rolling piece of tin that it's mounted to, that's about to run your *** over, is inconsequential at this point! It's the hood ornament's fault! WTF... :confused::confused::confused:
  13. Crusty Chevy
    Crusty Chevy
    It was my understanding that it was not impalement bur rather that coats and handbags could be snagged and then the pedestrian would be dragged along.
    Sharpone, Stogy and chevy57dude like this.
  14. Stogy
    Stogy
    What did they do with bullet nosed Studes...:eek:
    Sounds pretty elevated...I can just imagine someone going into the Town Hall and complaining about tearing their pants walking by...
    Bylaw sends a ticket out...to appear for twisted hamstring and torn pants...
    I'd figure if someone hooked someone at an intersection it'd be the driver not the ornament's fault.
    Was there press on that?
    Sharpone and 427 sleeper like this.
  15. snoc653
    snoc653
    from Iowa
    If your coat or handbag was snagged by the hood ornament in the center of a hood you didn't need to worry about being dragged along, more like ran over as there isn't a coat or handbag strap long enough to get you to the side of the car.
  16. Spindles and cut 1 round of coil.
    Set blocks under the arms for the correct spindle height per tire diameter.
    These were new springs installed by the previous owner and measured around 16.5 inches tall. Even with a coil missing and weight in the car, the upper co trip arms are still on their bump stops
    must be some high rate springs. It barely deflects if any even with my weight on it.
    Springs are back in their correct pocket.
    Had these shocks on it
    had em in the back as well. I guess they used that old trailer hitch
  17. RodStRace
    RodStRace
    Guy must have driven a mine truck and liked the ride! :eek:
    Sharpone and anthony myrick like this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    think of the lower A arm as a lever. the pivot is at the control arm bushing. the further toward the outside of the car the more spring action there will be. where you have the block directly under the spring is not mimicking the the way the suspension works with the weight on the tire. the further from the pivot point the "softer" the springs will feel. hope that made sense
  19. ROADSTER1927
    ROADSTER1927
    Move your blocks out to the spindle and test it!
    anthony myrick and Sharpone like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Better yet, place some s**** pipe under the blocks. That way blocks can move left to right as suspension settles to it’s resting point.
    SS327 and anthony myrick like this.
  21. Should be able to get wheels on it tonight.
    Hopefully the leverage helps.
    If not, I’ll cut some more
    we ain’t building a 4x4
  22. 2 inch blocks, spindles and 1 coil.
    Needs 1/2 to another complete coil gone and a 1-2 more in back
    Wife said she digs the new “bird”.
    And the rest of the hood and tailgate emblems need to go
    Stogy, Truckdoctor Andy and Moriarity like this.
  23. 427 sleeper
    427 sleeper
    Might as well get rid of the quater scripts too
    Moriarity and anthony myrick like this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    and lose the vertical pc of side trim in the middle of the rear door. they look real clean with just that long sweeping trim with no interruptions
    Stogy, 427 sleeper and anthony myrick like this.
  25. Wife says it’s too high.
    back to cutting
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    is the engine in it? I always cut 2 coils from a 55-7 Chevy
  27. Yes and a trans.
    No rad or battery
    Stogy likes this.
  28. 2 more in the back.
    better
  29. 427 sleeper
    427 sleeper
    You get it any lower you won't be able to put anything or anyone in it!
  30. Sure can. Once I get this height dialed in I can make plans to keep it there. Some trad air helper springs might just work :)
    Car has the HD 7 leaf pack. I’ll get it to sit like we like it with em.
    Algoma56, Stogy, Moriarity and 2 others like this.
