Customs Finally starting on the wife’s 56
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jan 5, 2019.
  1. Added a battery and some weight to compensate for the radiator.
    probably leave it here for now. Would only cut another 1/2 round if I did. I can handle that on the finished in. Seats are out plus it will get AC.
    might raise up or cut the pinion bump down.
    Looks like the DS has room to operate.
    Squablow, Sharpone, Stogy and 4 others like this.
  2. Wrong year skirt but good for a reference
    ****, I’d almost fab a rear upper edge to make em work.
    will need to trim rear axle bumps tops. Possible add a small c-notch.
    Frames get narrow here. Not opposed to fabricating some floor bumps to clear a notch.
  3. Stil looking good up front
    Taped the rocker molding on for a better reference
  5. 4 pedals
    4 pedals
    from Nor Cal
    Anthony, a few thoughts on your front coils. In my experience, typically you will lose 2" per coil cut. It's not exact, but usually ballpark. Also, even after bouncing in the shop, it will settle more in the first few miles on the road.
    Moog has their springs listed online by dimension and application. While you don't know what you have, you can look up stock application and find similar ones by diameter, wire size and rate.
    Devin
    Sharpone and anthony myrick like this.
  6. Will probably purchase new springs, progressive rate preferably.
    Just trying to get close before I yank the frame out from under it.
    Considering a frame mount rear upper shock mount and possibly air shocks to keep it from bottoming out when loaded or adding helper air springs. Air Lift
    Not bagged to slam it.
  7. Got the steering hooked up and with the engine moved up the center link still hits the pan.
    I’ll either modify this one of get one that clears.
    A tri 5 pan would clear the center link but is so taller. I’ll take some measurements.
    Sharpone, Truckdoctor Andy and Stogy like this.
  8. Rolled it outside. wife said the back was too low last night. Raised it up an inch.
    Now she says it might need to drop a little :)
    If the weather is nice we might clean off all the shop dust. Give it a ho bath. Clean off the roof.
  9. Dick Stevens
    Dick Stevens
    You're close enough for now on al***ude, so you can make the final adjustments when you get to final ***embly!
  10. That’s the plan. Gonna finish up the steering column mount and take a few pics and measurements
    get the ch***is out and blasted
    Probably will add a rear shock mount to the frame and added caster upper shafts.
    Figure out what holes I need to get rid of on the firewall.
  11. Wife ordered a set of these today
    15x7s. Close out sale less than $100 per
    So looks like she’s chosen thin beauty rings, spider rings and push thru caps with chrome acorn lugs.
    Wheels painted matching blue.
    Looking at 195-205/70 maybe 65 narrow whitewalls.
    located some early 80s ones but once I showed her the difference, the understood why I dig these and the hort rod style OEs without the slotted holes.
  12. About 15 minutes. Diluted CLR with a mild cleaning pad. Rinced and dried. Mild compound on a small orbital
  13. ididntdoit1960
    ididntdoit1960
    from Western MA
    Wow - brings new meaning to "that'll buff out" lol
    Sharpone, Uncle Ronn, SS327 and 2 others like this.
  14. I’d drive it! Sorry, I couldn’t resist!! :eek::D:D
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    I'm working on a 56-g***er project and moved the rear axle back 2" to make room for 29.5-inch-tall slicks, INMHO seems like 56-57 Chevrolets have the rear tires to far forward from the factory o_O
    Sharpone and 427 sleeper like this.
  16. Probably would on a g***er.
    Stock height kinda looks off.
    But I haven’t ruled out looking at it an inch back
    But I’m not moving a gas tank. Gets tight in a lowered wagon
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I went this route for clearance. Cut and move then add filler. Had to use my 57 as a example. IMG_3768.jpeg
  19. Tickety Boo
    Tickety Boo
    from Wisconsin
    Picture was taken with rear end moved 1" to the rear, was going to cut the opening at the white line but installed longer heim joints on ladder bars to move it another 1" to allow for tire growth :oops:
    Sharpone, SS327, loudbang and 2 others like this.
  20. Dont have that issue with a 25 1/2 inch tall tire :)
    Sharpone and Tickety Boo like this.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
  22. Moving the axle back 2 inches to fit a 3 inch taller tire basically keeps the tire in the same place in relation to the front of the wheel olpening.
    Doing that on a stock size 3 inch smaller tire will probably look goofy
    Sharpone and Johnny Gee like this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It’ll screw up weight transfer as well. But your wagon doesn’t need to rely on traction off the line as well.
  24. Onemansjunk
    Onemansjunk
    from Modesto,CA
    upload_2025-1-27_6-42-52.jpeg Looks good, I like it
  25. 05snopro440
    05snopro440
    Where from? Sweet deal.
    anthony myrick likes this.
  26. Got the last 2 from Summit
    Speedway was open box garage sale
    Both 15x7
    4.25 back space
    the best deal was the spider cap rings set for $60. NOS Cal Custom
  27. Weight transfer on mine is handled by keeping the **** in the cargo area tied down
  28. The thin outside ring
    those still a available?
    Been searching. Found 1.5 wide beauty rings but nothing like these.
    Sharpone and Truckdoctor Andy like this.
  29. 05snopro440
    05snopro440
    I've never seen an outside ring like that, don't know where to get them.
    Sharpone likes this.
  30. patman
    patman
    Is that a chrome rim that has been painted?
