Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Harvested another 6. A 250 this time. Ran good
    Another future something engine. Should be my 4th or 5th sm420. So I guess I’m good for parts for the flatbed.
    Got the spindles on the wife’s 56
    Okie Pete, porkshop, pila38 and 11 others like this.
  2. lumpy 63
    lumpy 63
    I think your new handle should be something like "6 popper Tony":p
    porkshop, Sharpone, mad mikey and 7 others like this.
  3. DDDenny
    Should we tell him that Chevrolet has been building V-8's since 1955.:D
    porkshop, Sharpone, patsurf and 8 others like this.
  4. J. A. Miller
    J. A. Miller
    from Central NY
    6 in a row Antonio.:D
    Okie Pete, porkshop, Sharpone and 6 others like this.
  5. ****. I got 9 or 10 of em laying around in the shop.
    Okie Pete, porkshop, Sharpone and 5 others like this.
  6. 392_33
    392_33
    Putting -66 T-Bird seats in my -48, using reclining p***enger seats for booth sides
    Okie Pete, pila38, Sharpone and 5 others like this.
  7. choptop4
    choptop4
    20250124_130238.jpg putting the dash together on my 38 dodge coupe' . Still working on the glove box. Might strip it and start over .
    Okie Pete, porkshop, pila38 and 15 others like this.
  8. saltflats
    saltflats
    from Missouri
    Went up to my buddy's shop to lend a hand installing his new set of headers. He had sent them off to be Jet Hot coated.
    Okie Pete, porkshop, pila38 and 17 others like this.
  9. Had an intermittent strange "ding-ding-ding" noise coming from the bell housing on my '53 pickup 235 with a "stomp" starter, swapped it out for a later solenoid starter, noise gone! It looks like the pinion gear would ride along the output shaft a little way and hit the tooth on the ring gear, which would push it back for a little while.
    Sharpone likes this.
  10. vtwhead
    vtwhead
    Had the same issue lately with a 54 and it turned out to be a weak return spring on the starter solenoid causing the drive to bounce off the teeth of the flywheel.
    What starter did you use to in the retrofit?
    Sharpone and Tickety Boo like this.
  11. It came from a '54 sedan as well. The original starter was the foot start type. At least now I can start it from the engine bay with a jump switch.
  12. saltflats
    saltflats
    from Missouri
    Smoking some cheese today.
  13. deathrowdave, Sharpone, enloe and 4 others like this.
  14. atch
    atch
    James,
    You gotta get your roof over that soon. If you need an extra hand give me a call.
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    Was it the salt or the black that melted the snow off the shaker :D
  16. saltflats
    saltflats
    from Missouri
    For sure Mike. Spring time will be here soon.
  17. saltflats
    saltflats
    from Missouri
    Norb, we finally the temp got above freezing.
  18. lumpy 63
    lumpy 63
    20250131_161740.jpg Got the gears set up in the 12 bolt tonight
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    porkshop, enloe, Sharpone and 3 others like this.
  20. saltflats
    saltflats
    from Missouri
    So Johnny what would that look like if it was a Dana 60 :(
    porkshop, enloe, osage orange and 2 others like this.
  21. swade41
    swade41
    from Buffalo,NY
    My backordered parts arrived so I spent the afternoon painting the new crossmember and then drilling out 24 spot welds.
    Got a pile of patina I can throw on the new paint to disguise it lol
    Okie Pete, porkshop, pila38 and 7 others like this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    More all thread. :)
    porkshop, enloe, osage orange and 4 others like this.
  23. DDDenny
    Also big arms and a strong back!
  24. cavman
    cavman
    Head liner last week, door panels this week. Both have been hard on my old knees. door panels 1.JPG H L 4.JPG H l 5.JPG
  25. Greg Rogers
    Greg Rogers
    Looks great!!
    porkshop and Sharpone like this.
  26. Little Truckdoctor and I finished the exhaust on Papaw today. Nothing fancy, manifolds and 2” pipe with Cherry Bomb Turbo mufflers. I have never been very good at welding exhaust pipes with a MiG welder. I usually ended up with more holes, lots of cursing and welding it together with a Torch and welding rod. (Traditional?) Little Truckdoctor came over, looked at what I was doing, fetched his gloves and Mask, and went to town. Amazing. He had maybe 3 small holes which he quickly fixed and I’m just tickled ****less. I know who is doing the sheet metal work on our next project! The exhaust sounds great, and now on to the front brakes and master cylinder!
  27. lumpy 63
    lumpy 63
    20250201_145421.jpg Worked on modifying a set of fenderwell headers to fit Bob's Lark.
  28. FrozenMerc
    FrozenMerc
    Working on eliminating rust. At least as much as is possible.
    And making some Progress.
  29. patsurf
    patsurf
  30. My best Sanford and Son imitation
