Projects 1939 Ford Convertible Sedan Resurrection
Discussion in 'The Hokey Ass Message Board' started by The 39 guy, Sep 6, 2020.
  1. Wow Sam! You and Don are continuing to knock it out of the park! I've never used hot rolled steel on my projects...after hearing about your effort to strip the mill scale, I never will. Thanks for sharing that lesson.
    Merry Christmas to you guys as well!
    The 39 guy likes this.
  2. joel
    joel
    Wow, Sam, what a fantastic job. The work on the '39 is top shelf ,however, the fixtures, tools and shop modifications you guys have done is just as if not more impressive. I know how much energy can get used up just getting to the problem that needs to be fixed. Very well done. Atta Boy!
  3. Just checking in on the progress. Looks awesome so far.
  4. neilswheels
    neilswheels
    from England
    Looking good Sam. Im finally at a similar stage myself, body on rotisserie and at a friends body shop. He's letting me do all the prep there and he'll be doing the paint thing. It wont be a shiny show stopper like yours, i'm keeping the 'patina', only because I want to drive it more that I want a shiny car :) (its been 20 years, i think thats long enough) We're doing the inside in raptor and possibly a heat barrier spray on top, underneath will be shiny black, so that I can keep it clean and not have dirt grab in there. I'll update my build thread soon.
    The 39 guy and Kelly Burns like this.
  5. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    It really looks great,Thanks for sharing the pictures.
  6. The 39 guy
    The 39 guy
    Thanks Tim! It's slow progress but any progress is good!
    Thanks Joel! Solving problems is one of the most fun parts of this hobby. Buying and making tools to solve a problem is fun also!;)
    Thanks Hot rod Ron!
    Thanks Neil! I think I have owned this car over 20 years. Hope to have a driver by summer. depends on how this paint job goes. I am pretty sure i will regret this shiny black paint job some day..... my 39 ford Convertible has a shiny body color paint job underneath. It is easier to wipe down than the raptor finish but since it is white it is showing some stains . I will be using Dynamat on my floor and firewall.I am looking forward to your update.
    Thanks chainsaw! Hope you keep watching the thread.
    Progress! finally the car is all one color! It always seems like flat gray primed cars look pretty smooth, until you really look close... After another couple of days of sanding masking and cleaning we were able to apply the 2K primer and a couple of coats high build today. We start sanding with 400 grit tomorrow.
    36 ROKIT, Okie Pete, woodz and 12 others like this.
  7. willysguy
    willysguy
    from Canada
    What a great project to follow along, full of good tips & ingenuity. Two thumbs up!
  8. The 39 guy
    The 39 guy
    Thanks willysguy !
    We took a a couple of weeks off for the Christmas Holidays but have been busy sanding and sanding fixing imperfections etc. for a while now so it was fun to be able to put some colonial white ( Wimbledon white) on the firewall today. This was a single stage Matrix paint. The rest of the body is also ready for paint. Hopefully the black and clear will be on before the weekend.
    It looks a little yellow to me.... But should look good with the black car.
    I think it is a good improvement over what we started with many years ago. This was the first piece I started with on the car.
    The car had one of those manifold exhaust heaters in it so this jagged hole had to be filled . I also replaced the firewall behind the distributor with some 16 ga. There were just too many holes and some br*** in the that area so I deemed it easier to replace the whole section.
    That's it for now . happy New Year everyone!
  9. Outback
    Outback
    from NE Vic, Oz
    Looking good!
  10. Happy New Year to you guys as well Sam! You guys are really making great progress. Looks great so far, eager to see it in color.
  11. joel
    joel
    Well done, Sam. I can't remember; did '39 have the battery in a shelf in the firewall? I thought all the open cars and woodies used the same cowl section 37 to 40.
    Kelly Burns likes this.
  12. The 39 guy
    The 39 guy
    Thank you Outback!
    Thanks Tim! It looks like Friday or Saturday will be color day (black). We plan to clear it over two days as the cut sheet on the Matrix Edge MS-52 Clear says two coats a day would be best according to Don. I don't see that while trying to fact check this. The outside temp has been around mid twenties the last two days. I have to crack a window in the shop to let in enough fresh air for the booth exhaust fan so I have to keep the furnace cranked up all day to keep the temperature in the booth around 70-75. It's supposed to 10 to 12 degrees warmer this weekend so that should help keep the booth closer to the desired spray temperature.
    Thanks Joel ! It looked pretty good today when we gave it a good close look. Just one little piece of lint got into the paint. It should clean up easily.
    So I checked my V8 Club book on 38-39 fords on the battery box question. Apparently 38 Deluxe and 39 Standard Fords used the firewall mount for the battery while 39 Deluxe used the frame mounted battery box.
    of course there are variations to the battery box and hold down systems on both models, as Ford was always changing things and of course using up old stock from the previous years.
  13. The 39 guy
    The 39 guy
    So black it is! We started painting the black today. As I feared the black exposed some body work that is not up to my standards so we will have to make some adjustments. Don did the spraying today. He did a pretty darn good job! we had a couple of runs in the sealer primer which were able to fix. We also have some orange peel in the base coat. We expected that but now have to decide if the 5 coats of clear will cover that up well enough to make it disapear after color sanding.
    This was a long day in the shop to get just this far. If we are lucky we can patch up the
    quarter panel and move on to clear tomorrow. The booth is working great! The furnace
    is keeping up with the cold air we have to allow in to the shop to keep the air clear. We are
    maintaining 70-75 degrees in the booth. I think all of the lights also help heat the booth.
  14. 40FORDPU
    40FORDPU
    Congratulations....you guys have come so far to get to this point.
  15. Crusty Chevy
    Crusty Chevy
    Good to see Don in a full suit with gloves. Too many guys being nonchalant with the paint in short sleeves and bare hands.
    The 39 guy and 05snopro440 like this.
  16. nrgwizard
    nrgwizard
    from Minn. uSA
    Hmmm;
    DARK Black - *my* kinda black... :D .
    That sure will look good. W/the multiple coats clear, is it just to colorsand w/o worry, or is it for the mile-deep effect(hopefully)?
    Btw; that would make an excellent base for RealFire( :D )(the *only* flames I like anymore), but that might not go so well w/the rest of the cars' features & image?
    Marcus...
  17. Man-oh-man! You guys are killing it! Love seeing a plan come together.
  18. joel
    joel
    Congratulations Sam and Don! This is a giant step.
  19. Bandit Billy
    Bandit Billy
    Was there ever a question? :cool:
    Looking good. Huge sense of accomplishment getting color and clear on. I love the smell of reducer in the morning.
  20. The 39 guy
    The 39 guy
    Thank you, thats true,it has been a long journey. It is very encouraging to reach this point.
    Yes, it's not all that expensive to outfit ourselves in suits and gloves. I tried using the 3M mask this time but for some reason it just is not working for me. I bought a little positive pressure breathing air system for myself from Mike the painter ( now retired). Mike Painted Don's 54 Merc and my 40 coupe) So I got a pretty good deal on it and it works very well. The only h***le is the breathing air hose. I ended up buying a second hose last night so I could have one in the booth and another for the mixing table that is located outside the booth. We are both old enough and had been exposed to chemicals through out our working careers. So our tolerance to these paint chemicals is pretty low. It wouldn't make mush sense to spend all of this time building the car to just end up to sick to drive it!
    Hi Marcus! Yes I hope it looks good in black. We had to make a couple of adjustments today after finding a couple of flaws in the body work after the base coat was applied. That delayed us a couple of hours but we still got our 5 coats of (not quite so much worry) clear on the car.
    That said we are rookies at this paint stuff. We do have plenty of orange peel. Hopefully the 5 coats of clear will give us a little rookie cushion and if we are very lucky a mile deep oh so black finish like our friend Bandit Billy likes sooo much.
    Yes black 39-40 Fords look great in flames/real fire . But I have no plans for flames so far. I thinking more sedate cruiser style for this one.
    Thanks Tim! I ditched the green! So far I think this black might just work.
    Yes, there was a question, I was looking into a light green color as seen on some of the modern cars. But I decided I wanted to join your dust the car three or four times a day club. I used to love the smell of paint but now it just makes my lungs hurt. I just hope I survie this paint stage of the project. We still have about 100 big and little thing parts to paint and polish.
    Thanks to you guys for watching and commenting! I'll post some pictures after we get this thing cut and buffed a little. We are going to take a day off and let this paint set up a bit before sanding it.
  21. nrgwizard
    nrgwizard
    from Minn. uSA
    "I bought a little positive pressure breathing air system for myself" .
    Brand & model #? Curious how well it works, always wanted one. My lungs aren't the best anymore either...
    Where do you pickup your fresh air from? & a spl filter there too? Seems to me, no matter where I'd put it, the fumes would swirl around & get pulled in. Maybe it's just here... I actually thought about using a SCUBA tank, or a firefighters' tank(which I have from somewhere). Not much time, though. Unless I'd get a rack of 3, like seen on occasionally on the "Bottom of the Sea"(or somesuch) w/Lloyd Bridges. & then I couldn't stand up, much less bend over... :D .
    TIA.
    Marcus...
  22. The 39 guy
    The 39 guy
    Hello Marcus, I guess I didn't cover this breathing air system before so I took a few pictures.
    As mentioned in my last post I now have two hoses.
    I placed the compressor outside of the shop in a covered area. When I need it I crack
    the window which I have to do anyway to supply air fore the exhaust fan. and plug in
    the multi connector and bring the power cord inside to plug it in.
    As shown before the exhaust hose travels through the window opening to the back side
    of my shop.
    You can see that there is quit a bit of distance and a wall between the booth exhaust
    and the breathing air intake. So far I have not sensed any hint of paint fumes in my
    breathing air.
    This is the mask. It has been difficult at times to keep the mask adjusted/ centered on
    my face but it is not mush worse than the 3M mask.
    The system was sold by this AO Saftey company. I did some checking to see if i could
    get some filters or mask parts from them. This system is so old they do not support it
    or have gone out of business. I think I gave Mike $80.00 for this system. It has already
    paid for itself.
    I changed out the exhaust filter today. I think it has done it's job. You can see a lot of clear
    on the floor. We used about 3 quarts of clear just painting the carc*** of this car. Looks
    like I had to vacuum up a lot of it today. The booth stayed pretty clear despite how plugged
    the filter became while spraying the clear . I was the rotisserie spinner for Don and I did my
    best to stay on the opposite end of the car while he was painting.
    SS327 and Crusty Chevy like this.
  23. sshep
    sshep
    Looking at your pictures brings back memories Sam. Glad you were able to finally shot some color on your CS. Keep up the good work.
  24. nrgwizard
    nrgwizard
    from Minn. uSA
    Thanks for pics n info. :) .
    Marcus...
  25. 31Apickup
    31Apickup
    Progress looks good. I have the same air supply system, recently bought the full face version which works so much better than the one that covers the mouth and nose which I’ve had the same issue of it sliding.
  26. The 39 guy
    The 39 guy
    Thanks! A long way to go but it's good to get to this point. Right now gray looks like it would have been a better choice.....
    . You are welcome! I hope that answered some of your questions.
    Thank you! What system did you buy?
  27. The 39 guy
    The 39 guy
    So as I was saying we are amateurs. I also said we had a lot of orange peel. You can see that in the first three photos.
    We spent about two weeks hand sanding the body with 1500,2000 and 3000 sand paper. We eventually got it smooth enough for buffing but had burnt through to primer in a few places.
    I buffed this section out by hand to see if I could be encouraged enough to continue sanding.
    It looked good enough to provide just enough encouragement to get us to soldier on.
    Our paperwork on this clear says that we had to prep the surface with 1000 grit paper.
    So after getting it super smooth with 2000 we sanded the whole car again with 1000 grit.
    After many hours of tedious sanding it was decided all of the masking would have to
    be redone since the paint had hardened on the tape and was peeling off. The plastic had
    also collected quite a bit of dust.That little project took a couple of shop days.
    Last week we prepped the back side of a stop sign and some other s**** metal for paint
    and used them to practice our paint technique. we invited a skilled painter friend to come
    over and give us some painting tips and watched a bunch of U tube videos. This was
    all helpful and the paint samples came out great. So today I patched up the bare spots with
    with some base coat using my air brush in the morning. Don applied the clear coat with
    his newly acquired skills with really good results!
    The B pillars came out great this time! ( no sanding required)
    We got some runs on the p***enger side quarter but the drivers side came out very smooth.
    The cowl looks great also. We wont have to sand the jambs or hood seal areas.
    We put just two coats of clear on today.So overall a good day in the shop. We will let this
    paint cure for a couple of days, and then get back on that cut and buff routine.
    woodz, 36 ROKIT, brigrat and 7 others like this.
  28. Looking fantastic!!
  29. Weedburner 40
    Weedburner 40
    Several years ago I tried the same process. Not to repair any mishaps but to try to make the cut and buff process easier. I put down the base coat then three fairly heave coats of clear, that didn't come out too bad but was going to be difficult to make super flat and shiny. I gave it a few days to cure than came back with 600 and sanded it completely flat. I then put two more slightly over thinned coats of clear on, which came out really nice. The cut and polish jobe came out super nice and was done very quickly.
  30. neilswheels
    neilswheels
    from England
    Thats looking great, well worth persisting.
