Projects Keeper Coupe
Discussion in 'Traditional Hot Rods' started by trevorsworth, Dec 27, 2024.
  1. Grumpy ole A
    Grumpy ole A
  2. tubman
    tubman
    I don't think you're home free with the clutch yet, I have been following this thread on and off, and I just skimmed it again, and I couldn't find a picture of the engine you are actually using. You do say it is a '49; if so it has to be an 8BA. You are correct that you have to use an 8BA style flywheel and a Merc or Ford truck bellhousing ('48-'52 truck or '49-early '51 merc) to actually bolt up the transmission you show here to an 8BA. Ford changed the transmission input shaft size between the earlier transmissions and the 8BA clutches. The cl***ic way of doing this was to use a early Merc clutch ***embly to get by this problem. The word on the street is that the early Merc clutches are no longer available in the automotive aftermarket. They are available from specialty vendors (I have heard Centerforce and Speedway Motors. Try to avoid the 11" truck clutches, as they are very stiff and will make your life miserable. Plus they won't fit in the Merc bellhousing, just the truck unit.
    Also, when you get the bellhousing, make sure it comes with the matching starter plate.
    54delray, Chucky and trevorsworth like this.
  3. trevorsworth
    trevorsworth
    The engine is a '49 8RT from an F6, currently bolted to a 4spd truck trans. My understanding is that the 8RT is basically an 8BA but with an 11" flywheel for the big truck clutch and maybe lower compression heads. I acquired this engine about five years ago... it was my introduction to both this forum & the hobby but I haven't posted it in here as I wanted to get it running again, cleaned up and painted before I did.
    I was told that this transmission is out of a '49 F1 and was bolted to an 8BA. I am unclear on if the 8RT bellhousing will accept this transmission - the engine is at @RMONTY's place and I haven't looked at it in a while - but I know I will need to change the flywheel out to be compatible with this 10" clutch and pressure plate. I vaguely recall after buying the flathead that I spent a while looking for a Mercury bellhousing but I can't remember why...
    Okie Pete and 54delray like this.
  4. tubman
    tubman
    An 8RT is basically an 8BA with different heads, carburettor, water pumps, and distributor; same everything else. I will admit my knowledge of big trucks is a little weak, but if it's an F6, it most ***uredly had the big truck 4 speed. IIRC, they don't even have bellhousing like the smaller trucks, and uses something called a "Hogshead". Hopefully someone with knowledge of big trucks will step in here. IF the engine really is out of an F6, there is a chance that is the big Lincoln 337 flathead which is a whole other ball game.
    You better make sure what you have.
  5. trevorsworth
    trevorsworth
    I am confident it isn't a 337. Here it is, five years ago, as we were building the run stand for it...
    I can tell from this picture the bellhousing/hogshead is not going to accept my transmission. So, the hunt begins...
  6. tubman
    tubman
    OK, that's definitive. It is an 8BA/8RT. I think there are still going to be clutch compatibility problems.
    I will bow out now, since my knowledge of big truck transmissions is almost non-existent. There are guys here and on "The Ford Barn" that are experts on this stuff.
  7. tubman
    tubman
    That looks like the right truck bellhousing, but I don't see the starter plate. For some reason, when people dismantled the old cars, they almost invariably kept the bellhousing and tossed the starter plate. Also, any old starter plate won't do; you need the one that matches the bell.
    I bought a Merc bell real cheap, and it took me several years to find the starter plate for a decent price.
    Okie Pete, bchctybob and 54delray like this.
  8. Flatrod17
    Flatrod17
    To me you have the needed cast haft bell in place now, no need to chase a merc pressed piece. I think your red trans will be a plug and play. You shouldn't have to change any of the clutch stuff if you don't want to. They should both be 1 1/8 10 spline inputs.
    After that I do recall there was some thicker cast haft bells. I have several of both cast and pressed here and get a deepth (thickness) for you if you need it.
    It was late when I wrote that, but I'm pretty sure it should be 1 3/8 10 spline inputs.
  9. trevorsworth
    trevorsworth
    I think you might be right. I panned through all the pictures I had of the engine and it does look like the correct bolt pattern after all. I think I need to be getting more sleep.
    Anyway, there's one way to know for sure - I really need to get this engine over to where the car's at so I can figure this out. Putting a transmission in my Dodge today so I can make the drive...
    Okie Pete, slayer and TrailerTrashToo like this.
  10. RodStRace
    RodStRace
    Chrome or stainless, put something on the threads! Either anti-seize or a light thread locker.
    Also, no zip gun on chrome, hand tools only and no cranking.
    Okie Pete likes this.
  11. 1-SHOT
    1-SHOT
    from Denton
    Then open drive transmissions usually have a 29 tooth cluster gear which gives you a very short gear, great for pulling a load but raps up quicker you might want to find a different gear set for it.
  12. luckily replacement parts for those are easy to get. or you could run a 1967 mustang master, bolt in replacement and upgrades to dual system, for t birds and other mid/late 50s fords anyway...
    porkshop and TrailerTrashToo like this.
  13. trevorsworth
    trevorsworth
    Flywheel on the way- super glad @IronTrap had one for a good price... which means I need to get that engine to the shop sooner rather than later... and get Robin fixed up with his tires...
    That should be all I need to mate the engine/trans and get it stabbed into the car!!!
    Still need to figure out what's up with the way the rear end is sitting in the car but damn we have been so busy at the shop... soon!!!
    tb33anda3rd, Hank37, rjgideon and 8 others like this.
  14. RodStRace
    RodStRace
    Busy just means you can spray down all the bolts in the area and give them another day to free up.
    Beats having to drill out stuck/broken ones!
    Spray the hinges, body to ch***is, anything you think you might turn over the next 6 months!
    Future you will thank past you.
    LCGarage, Moondog13, SS327 and 8 others like this.
  15. MojoRacing
    MojoRacing
    My future me sits and looks at my past me and thinks, what the hell were you thinking!?!
    LCGarage, bchctybob, SS327 and 7 others like this.
  16. IronTrap
    IronTrap
    Happy to help! Can’t wait to see this thing back on the road!
    Outback, Tim, trevorsworth and 3 others like this.
  17. trevorsworth
    trevorsworth
    And speaking of progress...
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I'm loving the red transmission with the white shifter and inspection cover. Keep up the good work.
  19. Sharpone
    Sharpone
    Xs2
    Great find I’m subscribed
    Dan
    trevorsworth likes this.
  20. trevorsworth
    trevorsworth
    I also have this cool chrome headlight bar with a V in it in storage... had it in my head that it was a 32 bar but seems like it's for an A. Probably gonna run this on the car.
    bchctybob, Outback, slayer and 5 others like this.
  21. duecesteve
    duecesteve
    You definitely are scoring some cool **** !
    Sharpone likes this.
  22. RodStRace
    RodStRace
    He's handling it as a good caretaker would!
  23. noboD
    noboD
    That interior looks JUST PERFECT.
  24. trevorsworth
    trevorsworth
    Bringing the flathead home tomorrow so we can get it painted and stabbed in -- hopefully this week.
    I think I have everything I need... the engine already runs - ordered truck water pumps, motor mounts, flywheel, clutch/etc to pair to the transmission, and just ordered a u-weld-it lake header kit from speedway so, depending on how busy we are this week we may well have it in the car & running by Friday...
    I don't remember if I mentioned, but the radiator holds water & seems to be in good shape so we're going with it for now. Whatever Sid did to mount this radiator/shell to the frame is missing, but I do have the hood he made, so I'll be able to use that to make sure I get the spacing right on the new brackets I'll have to make.
    Plus, it's starting to get warmer, so we're looking to start painting the ch***is over the next week.
    Today was extremely busy (and I'm recovering from flu) but I spent a little time on the transmission. I still want to do another coat of red on the case, but I re-shot the lever and also scuffed, primed, painted and cleared the screw on retainer. It's hard to tell in the pictures I posted but man, in person, it makes all the difference.
    Hank37, Moondog13, porkshop and 16 others like this.
  25. trevorsworth
    trevorsworth
    Homeward bound!
    Lots to do.
  26. RodStRace
    RodStRace
    Guess this means the OT trans is off the checklist!
    Did this get a tryout on the run stand before it gets dropped into the A?
    EDIT: answered a few posts back; YES!
    Also, I understand you are just getting this ***embled and hoping to fire, but please tell me those @#$ Yellow wires will go soon!
    porkshop and Budget36 like this.
  27. trevorsworth
    trevorsworth
    This engine was my introduction to hot rodding. It ran great for me 5 years ago and has been inside since. The yellow wires are what oreilly had that day 5 years ago lol. I am looking for some Packard or cloth wire
    catdad49, bchctybob, porkshop and 6 others like this.
  28. noboD
    noboD
    If you leave the yellow wires on we will hunt you down.
    porkshop, Sharpone and trevorsworth like this.
  29. trevorsworth
    trevorsworth
    Hahaha don't worry they're in the trash already!
    Still feeling ****py- no energy to mess with this thing today but tomorrow we'll start cleaning & painting. Water pumps & motor mounts should be here Tuesday along with the flywheel. So, as long as we've got it painted by then it will be in the car by Friday. Hoping for a slow day!
