Technical 60 Cadillac Frozen Drums
Discussion in 'The Hokey Ass Message Board' started by Vetteman61, Jan 26, 2025.
  1. Vetteman61
    Vetteman61
    from Tennessee
    1960 Cadillac sitting in barn for many years. All 4 wheels are frozen solid. Tried pulling the car with a tractor and the wheels still won't budge.
    Can I use a puller for the front and rear drums? (Front have the hubs). I can't even try to back off the shoes because on the cadillac the adjuster window is on the front of the drum, so it can only be accessed when you turn the drum so the window is in the right place.
    Also, I've been looking at drum pullers. I noticed these all state "hub" pullers. Can these also be used for the rear drums as well?
  2. swade41
    swade41
    from Buffalo,NY
    What if you clipped the "nails" holding the shoes to the backing plates, might get things moving around.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, another vote for cutting the heads off the hold down pins. If you use a puller on the drums there is a very good chance you will ruin them and there probably isn't much aftermarket support....
    SS327, Truckdoctor Andy and warbird1 like this.
  4. Another vote for cutting the heads off the nails.
    Truckdoctor Andy likes this.
  5. Vetteman61
    Vetteman61
    from Tennessee
    Thanks guys, you are correct, 1960 was a one year only, so there isn't aftermarket support.
    I'm not familiar with this brake setup. When you say cut the nails, what are you referring to?
    Thanks
  6. 392_33
    392_33
    you should be able to locate these pins on the backside of the drums. Use a die grinder to cut the head, that should loosen the shoes some, hopefully enough to hold the drums off.
  7. Vetteman61
    Vetteman61
    from Tennessee
    Ah, I see. Thanks, I had never thought of that before. I suspect if the shoes are rusted to the drums, some amount of heat and a hammer may be necessary, after cutting the pins, to break them loose?
  8. Happydaze
    Happydaze
    Lots of good taps with a heavy lump hammer should help. A small, regular hammer won't have the heft, but no need to smash things to bits with the lump hammer either. Reasonable swings and let the weight of the hammer do the work.
    Chris
  9. The shoes are rusted to the drums. Add years of moisture and they are "welded" to the drums. Removing the heads off the nails should allow for the drums to come off some depending on how much slack the retraction springs and e-brake cables allow. Should be enough to get some penetrating oil sprayed on the shoes. Heating and hammering may crack a drum. Those drums are as rare as 58 Edsel drums. Unobtanium.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Maybe unbolt the wheel cylinders from the backing plates and tap them in a little, that may help let things move enough....
  11. Vetteman61
    Vetteman61
    from Tennessee
    Thanks again guys. From my memory, it's been a long time, but I'm almost positive there is no way to access the shoe adjuster star from the back. The only hole is in the drum, and the drum has to be rotated to allow the access to to line up with the adjuster. If the drum is frozen, then I can't back them off, but this is confusing because I just looked in the repair manual and it seems to state there is an adjuster in the back.
  12. rusty valley
    rusty valley
    I've usually had good luck with just a BFH. No need to break things, just keep hitting around different spots on the edge of the drum, and the backing plate where the shoe rests. Once some rust and dirt starts falling out you're winning, just keep going. I've seen them full of ants nest too.
    1952henry likes this.
  13. leon bee
    leon bee
    Spray a **** load of blaster thru those holes wherever they are.
  14. RMR&C
    RMR&C
    from NW Montana
    Last one I did I cut a hole w/ a holesaw in the backing plate at the bottom where the adjuster is. Then cut the adjuster in half with the sawzall thru the hole. This takes the pressure off the shoes. Poke a bar or punch in there and get things loosened up. After you get it apart, weld the "plug" back into the hole you made. Saving the drums was more important to me.....
  15. F&J
    F&J
    . Best idea yet IMO.
    I recall drilling a half inch hole in an early squarebody Chevy backing plate to get to the adjuster.... I just don't recall why. Too long ago
    RMR&C likes this.
  16. Mr48chev
    Unbolting the wheel cylinder and knocking the heads off the retainer pins should let it all come loose with the drum and why didn't I figure that out 50 years ago when I was doing several brake jobs every week if if not every day.
    The hole saw trick is golden too.
    Now Vetteman61, It didn't happen unless you show us the photos and give us a story.
    Algoma56 and Moriarity like this.
  17. mrquickwhip
    mrquickwhip
    Jack car up and use axle stands for support
    Remove wheels
    Pour boiling water on drum, repeat if necessary
    Heat should expand drum
    Tap drum with hammer if needed
    Put wheel on without wheelnuts and try back and forward motion like using a steering wheel
  18. RodStRace
    RodStRace
    I agree with cutting the nails, lubing everything, lots of big hammer lightly tapping to get things moving. I'd also look at what is available before you dig in. If the drums are unobtainium, are the other parts too? The hole in the backing plate is a good idea, but if this is really rusted solid, it may not help. If this was a car with new 50 dollar drums a trip to the parts store away, I'd say cut. Lube, heat and time are your weapons, knowledge of what is expendable will guide you.
    I like @mrquickwhip 's idea of hot water. If you drill an adjuster hole, it might help to flush out the area too. Lube is going to mess up the cups and seals if it gets on them, but water shouldn't do anything but rinse, provided you don't leave it in there and let it rust up more.
  19. Vetteman61
    Vetteman61
    from Tennessee
    Thanks a ton everyone. I cut the head of the pins off and took the bolt out of the back of the wheel cylinder and was eventually able to remove the drum. Unfortunately, even though I didn't hit it hard at all a couple pieces of the lip of the drum did break off. Unfortunately, a lot of trash got onto the spindle and bearings so I had to clean, regrease and repack everything. One down, three more to go. As requested, here are some pictures. Also, I began thinking and realized this car has been in this barn for 14 years now. Time flies.
    SS327 and Algoma56 like this.
  20. 1952henry
    1952henry
    Glad they came off. Not a bad idea to go into bearings for cleaning, inspection, and re-packing.
  21. Greg Rogers
    Greg Rogers
    Fronts are usually easier than rears as you can remove the outer wheel bearing and gain some "rocking" to get shoes loose.
