Checker cab
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Nov 22, 2024.
  1. DDDenny
    Would that include a chauffeurs' uniform?
    Sharpone and 41 GMC K-18 like this.
  2. DDDenny
    You could use the same uniform you used when you drove the he****.
  3. squirrel
    I haven't figured out that part, yet. I'm working on the car still. Black and Blue Cab. I'm adding the Black part.
    porkshop, chevy57dude, Thor1 and 5 others like this.
  4. snoc653
    snoc653
    from Iowa
    I'm sure you've checked it all, but between the thermostat switch, the timing control circuit, and the relay is it possible the solenoid is not getting the proper voltage at the right time to send to the modulator? I haven't found a reference for what that voltage would be, but from the diagrams I'm seeing, I think it should be battery voltage. Perhaps you could piggy back a voltage gauge up through the floor with a switch to see what it is showing and maybe turn off/on the voltage to the modulator valve. If it is getting the voltage properly, it would most likely be an internal adjustment which the transmission setup on the Checkers are reported to be something for an experienced Checker mechanic. Having the manuals for the exact setup would be a big help with that. They have any old cab companies around that might have manuals squirrelled away?
  5. 41 GMC K-18
    41 GMC K-18
    This is a very old list of resources from 30 years ago, so these may be rabbit holes, to fall down in search of the proper information about the transmission that is in the checker that @squirrel has.
    Everyone's results may vary greatly!
    bobss396, Sharpone and SS327 like this.
  6. SR100
    SR100
    Unfortunately, the manual doesn't show up in the Seattle Public Library's catalog. I bought some old manuals at the SPL book sale in the early eighties. They were about 25 years old, so I ***ume that the SPL discarded the Checker manual quite a while ago.
  7. squirrel
    Hmmm...I think you're confusing the TCS system with the kickdown system.
    The kickdown is a simple electric switch that sends power to the solenoid in the transmission. It works.
    The Transmission Controlled Spark system uses a pressure switch that tells if the transmission is in high gear, and controls the distributor vacuum advance, based on the 3rd switch, and engine temperature, to reduce NOx emissions in the engine. I don't know if it's working, but I will eventually make sure it's getting vacuum when I'm driving down the road. I might byp*** it all, too.
  8. snoc653
    snoc653
    from Iowa
    You are correct as usual. I've been trying to do some decoding on my BMW X3 transmission and saw TCM in the diagram and thought transmission control module. I guess 70 is a little too old for one of those. I still think a light wired to the kickdown module might still shed some light on why it might be shifting too soon.
    squirrel likes this.
  9. bobss396
    bobss396
    My Ford has one of those oval plugs in the p***enger floor.
    squirrel and 41 GMC K-18 like this.
  10. squirrel
    Not really, because it's pretty obvious when the KD is working, and when it's not working.
    The overall problem is that the shift points are too early, 1-2, 2-3, whether it's in KD or not. And messing with the modulator won't get them late enough. So, there must be something else wrong with it. And using the manual low to hide the problem, doesn't help very much, as there is no manual 2nd gear selection available.
    No worries, as long as it gets me to PA and back home, I can live with it. Then put a TH400 in it with a different engine, and that problem will be solved. I'll just get a bunch of new ones!
    dogwalkin, bobss396, SS327 and 8 others like this.
  11. RMcCulley
    RMcCulley
    Did you see this teardown video?
    Sharpone likes this.
  12. Johnboy34
    Johnboy34
    from Seattle,Wa
    I wonder if you could fool it like we used to do with Fords Cruisamatic. Start in low, shift up so it shifts to 2nd then back to lo so it would stay in second.
  13. RodStRace
    RodStRace
  14. squirrel
    no, and I don't want to watch it! I've taken apart a couple of the Ford version many years ago, no desire to do it again.
    This one doesn't seem to have the same control system. I was able to do that on the 55 Tbird I worked on years ago, so I know what you mean, but this one doesn't work the same. D2 gives you 2-3, D1 gives 1-2-3, L gives 1.
    41 GMC K-18, Sharpone and Johnboy34 like this.
  15. squirrel
    ok, things are just getting silly now. Cup holder, and a built in screen? What is this, a new car?
    (yes, there's also a backup camera attached to the screen)
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    That is quite the tachometer you have there!!!!
  17. squirrel
    yeah, I had it on my 55 for a long time. Easy for me to see.
    Okie Pete, ottersea, Sharpone and 3 others like this.
  18. Baumi
    Baumi
    You beat me to it. A checker cab with a tach that goes to 10k rpms, that must be a rare sight, hahahaha
  19. Crosley
    Crosley
    from Aridzona
    Geeez. A Fancy taxi cab. Mayb a heater too?
  20. Tickety Boo
    Tickety Boo
    from Wisconsin
    Note: the tach reference needle at 4500 rpm, it should live a long time :D
    RodStRace, Sharpone and 41 GMC K-18 like this.
  21. squirrel
    yeah, the heater and defrost work! Gotta keep my toes warm
  22. snoc653
    snoc653
    from Iowa
    He wired as a 4 cylinder so it looks like he is hauling.
  23. Harv
    Harv
    from Sydney
    How many young man's dreams have been squashed when their wiser friends pointed out that the part making their 9,000rpm small block was a tachometer 4-6-8 switch?
    Cheers,
    Harv
  24. Big M.
    Big M.
    Ran across these sorry no info
  25. squirrel
  26. 41 GMC K-18
    41 GMC K-18
  27. DDDenny
    Did you join the union?
  28. snoc653
    snoc653
    from Iowa
    Awesome. Looks like you’re almost ready to hit the road with it.
  29. noboD
    noboD
    Squirrel, I forget but I think you are running straight water in the radiator. I have had good luck with running 100% white vinegar for long periods of time. Maybe that and your sock would clean things up faster?
    porkshop likes this.
  30. squirrel
    I put antifreeze in it a while ago...
    I'll keep the sock in it until it seems to not be doing much, then take it out, and just let things happen as they may.
