Hot Rods 4 Post Failure
Discussion in 'The Hokey Ass Message Board' started by dart4forte, Jan 17, 2025.
  1. tubman
    tubman
    My '99 F150 just barely misses fitting under my 4 post lift. Since it is not bolted down, I was considering a 12" X 12" 2" thick plate bolted to each foot to gain a couple of inches clearance and maybe add a little more stability. Wood is out, steel is really heavy, and then I priced aluminum. I haven't given up on the idea and have recently come into the possession of a length of 2 X 4 X 3/8 steel "C" channel. I am considering how to position them; right now, I am considering one longitudinally and one laterally on each side to maximize support. Any comments?
  2. BJR
    BJR
    From Facebook:
  3. Mr48chev
    This would be the lift in question according to the way I read the FB comment in post 152. Screenshot (1944).png
  4. hotrodlane
    hotrodlane
    Check out this video (Click link 1961 Corvette Rescued from Failed Four-Post Lift ) of one of the cheap offshore lifts that has been sold by the hundreds and being branded under a bunch of names. (None of them are ALI certified) Does this look like the one that some of you may have in your shop? If so do you think that maybe you got lucky and the 7 year old chinese girl got her welds penetrated better on yours or her little sister used a better grade pulley bolt on yours? That lift does not look very old, Pretty Scary stuff! just saying.
  5. finn
    finn
    Many,, many imported lifts are ALI certified, including Bendpack, among others.
    05snopro440 likes this.
  6. hotrodlane
    hotrodlane
    That may very well be true. But if they are ALI certified then that means they have been tested and inspected for quality and saftey which are not any of the lifts I am talking about. I am talking about the garbage that is not ALI certified that has a strong chance of hurting someone or worse.
  7. fuzzface
    fuzzface
    Here is the lift at the 2024 carlisle show after they removed the off topic vette off of it.
    rusty valley likes this.
  8. WOW! Three locks in place, one not so much. But it is on concrete, apparently.
  9. rusty valley
    rusty valley
    Why wouldn't the cables still hold it level?
  10. tubman
    tubman
    Does anyone else find it suspicious that this last and the original failure both occurred with temporary installations in what are basically outdoor locations at car events?:eek:
    HemiDeuce, seb fontana and SS327 like this.
  11. arse_sidewards
    arse_sidewards
    from Central MA
    The failure at an outdoor car show where it's far more likely that someone involved with that booth and who actually gives a crap and might even have an IQ above room temperature doing the setup is the odd one out. The failure at a proper indoor venue where you have the IATSE doing the setup is exactly what I expect from those clowns.
  12. Budget36
    Budget36
    Suspicious in what respect? Suspicious assumes, we’ll never mind, but explain what you mean please.
  13. ALLDONE
    ALLDONE
    I have 10 lifts...2 and 4 posts... I've seen both mechanical and operator failures.. murdered a couple cars,.. and a couple operaters went to the hospital thru the 40 years.... the law of average is just a bold statement... .if something looks like it might fail... I fix it... so like said.... I bolted my lift down last friday.... not saying nothing can go wrong,,,.. but like any thing... one must be aware that a lift is equipment...use it as intended... and watch what you are doing...betting against the odds, sooner or latter you loose...
  14. nobby
    nobby
  15. hotrodlane
    hotrodlane
    This looks like almost the same failure in the video I posted. Maybe these Cheaply made lifts just don't like corvettes!....LOL
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    I have an advantage lift. These are really well made. Not bolted down and has never jiggled one bit
    BJR, Lone Star Mopar, hotrodA and 2 others like this.
  17. SS327
    SS327
    I’ll be looking for a 2 post lift sometime in the next 2 years any recommendations on brands? Something in the 9,000 lbs range.
  18. finn
    finn
    Advantage
    Lone Star Mopar, hotrodA and SS327 like this.
  19. brigrat
    brigrat
    from Wa.St.
    When I bought my 2, 4 poster lifts I got ahold of a guy that serviced all the muffler shops, brake shops, front end shops and service stations. These kind of guys know where the heavy duty units are and if any are available from the shops shutting down or going out of bizz. Bought a 12 ton & a 9 ton. for 2K each, delivered and set up.
    HemiDeuce and alanp561 like this.
  20. tubman
    tubman
    As a friend of mine says : "I can explain it for you. However, I can't understand it for you".
    alanp561 likes this.
  21. Budget36
    Budget36
    So you spoke of finding something suspicious, yet can’t say what or why you feel it’s suspicious?
    I’m good.
  22. BPK65
    BPK65
    Well said!
  23. tubman
    tubman
    Substitute "questionable" for "suspicious" if you wish.
  24. Lone Star Mopar
    Lone Star Mopar
    @Moriarity We have the same exact Advantage lift ( I went & looked after this thread). Made a day trip to Kansas to save on shipping. Assembled it in a half day with just me, my Pops & an engine hoist. Also not bolted down.
    Good product for the money. I'd like to have another. We paid extra for the pneumatic jack & man it comes in handy.
    Moriarity likes this.
  25. Budget36
    Budget36
    That would have eliminated my post.
    G-son likes this.
