Technical Battery
Discussion in 'The Hokey Ass Message Board' started by Bikelessbill, Jan 27, 2025.
  1. Bikelessbill
    Bikelessbill
    What are you using for your battery where space is very limited in your hot rods ?
  2. BJR
    BJR
    A very long extension cord. :p
    clem, SS327, '34 Ratrod and 2 others like this.
  3. mohr hp
    mohr hp
    from Georgia
    Some of the AGM dry cells are very compact for their amperage.
    Tow Truck Tom and Budget36 like this.
  4. Joe Blow
    Joe Blow
  5. fastcar1953
    fastcar1953
    a riding lawn mower battery.
    flatheadpete and Tow Truck Tom like this.
  6. Bikelessbill
    Bikelessbill
    Checked it out. Seems like a possible good choice.
    Joe Blow, jimmy six and Just Gary like this.
  7. Bikelessbill
    Bikelessbill
    Though about that but didn't know how long the life would be starting a 350!
  8. Bandit Billy
    Bandit Billy
    I have Odyssey PC925's in 3 of my current drivers. No complaints.
  9. fastcar1953
    fastcar1953
    I have had them last for 4 to 5 years. 365 cca and 300 amp normal. less than 8 inches by 5.5 inches.
    Battery tender when parked very long.
    Less than 70 dollars.
    Tow Truck Tom likes this.
  10. swifty
    swifty
    A friend of mine mounted a PC680 on it's side behind the dash in his Model A bucket. You can mount them anyway except upside down which can help if you're pushed for room. The Odyssey PC680 cost me A$250 and lasted nearly 5 years -my fault as it went fully flat and AGM batteries don't like that. I replaced it with a FULLRIVER Chinese equivalent for A$150 and it's been going for 9 years now cranking a 318 cube Dodge Poly.
  11. Mr48chev
    The best battery I can afford that fits in the space I have to put it in. sixty plus years of car guy stuff says that the one place you don't skimp is on the battery you run in your older car.
  12. Admiral Tom
    Admiral Tom
    Don't know your setup, but I'm using 2 Optima 6v in series under my seat. They're on their side but since they're AGMs it's not a problem. Plenty of cranking amps!
    dana barlow and Just Gary like this.
  13. 03GMCSonoma
    03GMCSonoma
    Here is a picture of my avatar '38 Chevy Master Coupe battery located in the p***enger side wheel well. The mounting bracked is attached to the frame. It is a ***** to hook up a battery charger but it works. When the wheels are straight, you can't see it.
    dana barlow and Packrat like this.
  14. 36 Tourer
    36 Tourer
  15. 36 Tourer
    36 Tourer
    Love it , I have built three family hot rods with battery exactly like yours under the front mudguard had no issues first one was a 38 Chev second a 36 Chev tourer third and current is a 46 Ford delivery , if you need to change the battery just jack it up and take the front wheel off .
    03GMCSonoma likes this.
  16. Just Gary
    Just Gary
    The battery box in my A sedan is 0.75"x 0.75" angle, sized for an Odyssey 680.
    It fits under the rear p***enger floorboard. Frame tabs are 1.5" x 1.5" angle.
    The master power cutoff switch is under the p***enger seat, out of sight but within easy reach of the driver.
  17. Battery for a Honda from Walmarts
    seb fontana and Truckdoctor Andy like this.
  18. MARKDTN
    MARKDTN
    The battery in a boost box is pretty small but I have never seen one used as a primary battery.
  19. 03GMCSonoma
    03GMCSonoma
    Thank you.
  20. grdra1
    grdra1
    I have an Odyssey PC 925 mounted under the dash in my 31 coupe, no probs starting my sbc, been there 4 years now. Will not hesitate to buy again, Glen
    Just Gary likes this.
  21. Ned Ludd
    Ned Ludd
  22. Bikelessbill
    Bikelessbill
    Thanks for the input. Think I'm going to try the sideways 680 post.
  23. 1biggun
    1biggun
    Dual 6V Optima's on series under the seat of the Model A truck
  24. tubman
    tubman
    When I bought my last battery maintainer, it came with an additional lead with two ring terminals and a specialized connector that plugged into the maintainer main lead. You can install one of those, mounting the connector in a convenient out of the way place, and plug the charger in there without having to access the battery itself.
    03GMCSonoma and Just Gary like this.
  25. pirate
    pirate
    from Alabama
    IMG_4043.jpeg Odyssey PC680 mounted on its side. Amazing how long they will hold a charge when not being used on regular basis.
    Robdski, Kelly Burns and Just Gary like this.
  26. Richard L
    Richard L
    from Quincy, IL
    The battery on my 1937 chevy is in the right front fender . I use a side post with the post facing to the front . Then take a plastic battery box turn it upside down, cut some of the back out to make it go up and over the battery . Now it will stay clean and dry from water and dirt .
  27. brady1929
    brady1929
    Great information for when I buy a battery for my hot rod. Thanks.
    lothiandon1940 and '34 Ratrod like this.
  28. Bikelessbill
    Bikelessbill
    Can you tell me where you were able to get Fullriver batteries. I haven't been able to find a supplier and part number you replaced the Odyessy with. Thanks again
  29. 1971BB427
    1971BB427
    from Oregon
    I use a battery box in the right side of my trunk. It's out of the way, and with side terminals also. I have holes I made in the side of the box so I can attach a charger over the winter to trickle charge it and not need the lid off the box.
  30. Robdski
    Robdski
    Great information guys, thanks for sharing!
