Technical The making tube headers thread
Discussion in 'The Hokey Ass Message Board' started by nobby, Jan 24, 2025.
  1. lostone
    lostone
    from kansas
    No disrespect to some who have posted but I think there is 2 different train of thoughts going on here.
    1. Is the average hot rodder who may build a total of 2 sets of headers their entire lives.
    AND
    2. Those that build things like this for a living. Maybe not day-in-day-out but maybe a couple sets a year AND get paid to do so.
    Now I've thought about building my own but not going to spend 8,000 dollars for a saw to cut the pipe with nor give several hundred plus for a set of lego's to design with etc.
    And sure maybe I can sell the tooling later to recoup costs but how long will I have to set on it before it sells or how much of a hit in price to sell it ?
    Sounds to me that the OP has only 1 set in mind to build and spending several thousand dollars to build 1 set sounds like a major waste of funding to me, instead of a expensive high dollar saw (etc) sitting in the corner collecting dust that money instead could fund the complete rear end ***embly complete with posi etc.
    Now again no disrespect aimed at ANYONE just an observation and I do appreciate the info, tips etc from all....
  2. DDDenny
    I wanted an Ellis saw after seeing them at my friends' shops, just couldn't pull the trigger. I'd love to have it sitting in the corner collecting dust.
    bchctybob and Tow Truck Tom like this.
  3. Paulz
    Paulz
    When I built my first set for a weird application, I bought a BBC weld up kit from Speedway with a few extra J bends and made my own 3/8" Pontiac flanges by copying a ram air manifold gasket. Cut tubes with a hacksaw, tuned the fit with a flap wheel on and angle grinder and gas welded everything. Even sold the unused BBC flanges to cut down on my expense. Didn't have much $ into them at all.
    And yes people doubted the forward facing headers. But they cleared everything they had to that way and the engine doesn't know any DSCN0194.JPG DSCN0198.JPG DSCN0199.JPG DSCN0210.JPG better.
  4. Just Gary
    Just Gary
    Here's how I made the fender-exit headers for my A. I'm an amateur hack with a MIG welder and mild steel tubing..
    Prototype #1 was ultra-traditional coat hangers & bricks: ;)
    Prototype #2 was 1/4" steel rods with 2.5" radius.
    Headers themselves consisted of 5/16" thick flanges from "Headers by Ed", 3.5"x10" collectors, and 16 gauge, 1 5/8" primary tubes with 2.5" radius mandrel bends, from Summit.
    More pics here:
    https://www.jalopyjournal.com/forum/threads/introducing-my-fuel-coupe-styled-tudor.132127/page-7
    headers 01.jpg headers 02.jpg headers 03.jpg headers 04.jpg headers 05.jpg headers 06.jpg headers 07.jpg headers 08.jpg headers 09.jpg headers 10.jpg headers 11.jpg headers 12.jpg headers 13.jpg headers 14.jpg headers 15.jpg
    bchctybob, BradinNC, warbird1 and 9 others like this.
  5. alanp561
    alanp561
    Very well done.
    Just Gary likes this.
  6. Marty Strode
    Marty Strode
    No hackery there, great job Gary!
  7. tubman
    tubman
    I really like the hose clamp idea. Is there a matching hole 180 degrees apart?
    Chavezk21 likes this.
  8. patsurf
    patsurf
    GREAT tip on the nerfs!
  9. Montana1
    Montana1
    I agree 100%! Thank you for bringing that out...
    Pist-n-Broke likes this.
  10. Curt Wilson
    Curt Wilson
    I found this series very helpful when building headers
    Deutscher, Montana1 and Just Gary like this.
  11. Marty Strode
    Marty Strode
    3 holes normally! The safest way I have found to drill the holes is to put the clamp on some s**** tube and use a step drill.
    bchctybob, warbird1, Montana1 and 3 others like this.
  12. alanp561
    alanp561
    I believe you're referring to "chill rings". They are made in several sizes and thicknesses and if called for, they are sometime used as backup for the root p*** in a pipe or tube weld.
  13. Budget36
    Budget36
    Looks like what I recall being posted at one time.
    Thanks
  14. No offense taken here. I do understand watching the budget and trust me my saw was not bought just to build headers. Custom Headers are just a very small part of what I've built over the years. In fact, most of my work is O.T. here. I just like coming back to where it all started for me and seeing how the Young Blood is dealing with the renderings.
    Maybe my post should have been put under Tips and Tricks. It was more about the modification to the saw to start with thinking the guys with smaller drop arm units gathering dust could give them a Tune Up to make things easier.
    I know I don't communicate very well and why I never give advice or tell, How-To anything.
  15. rod1
    rod1
    Thanks for the tips! Any more info on the blades?
  16. Sure, when I get out to the Shop, I'll pull up the order sheet for the blades. I know they are Bi-metal and very tooth but don't remember the exact tooth counts.
    rod1 likes this.
  17. Montana1
    Montana1
    I love technology, don't get me wrong. My Step-Dad had a welding shop on the farm when I was a kid. I learned most of what I know today from "cut-n-try", working on farm stuff. When I got into cars and fast bikes I left the farm, rolled up my sleeves and went to work.
    I built some really fast bikes with some not so cool stuff. What I learned from that was, when building headers, all exhaust wants to do, is to get out, at the right time, the right velocity, and the right pressure. All of that is determined by a combination of pipe length, diameters, converging angles, sound waves, pulses, compression and cam timing.
    Some of it didn't look so cool, but it worked really good. What mattered to me was if it went fast and set records! That's probably why I love my '32. It's very simple, kind of fast, but really cool! ;)
    Sorry if I got off topic a little... :rolleyes:
  18. This is what keeps us going. There truly is a science to Exhaust. You can make horsepower or kill horsepower in a set of headers. It's not all about looks. Sometimes confinement dictates but you need to know formulas to make the best of sometimes less than ideal conditions. Even placement of primary tubes into a collector plays a part.
    Montana1 likes this.
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is what my friend did. He has an altered roadster drag car w/ a 460ish Ford V8. He uses BB Chevy roadster headers, cuts off the flanges, and welds the headers to 460 flanges.
    ekimneirbo, BradinNC and juan motime like this.
  20. nobby
    nobby
    two pies times ahh
    1.75 inches in half is 7/8
    we all know 7/8ths is 22.2mm
    if two pies is 3.14 times two, then that is 6.28
    so 6.28 times 22.2mm gives you 139.5
    lets call it 140mm
    so, if you do have elliptical ports or
    losenge shapes, maybe you can using the confuser draw the losenge shape to have a path of 140mm
    squeeze up the 1.75'' tube and wang them in ???
  21. e015475
    e015475
    from Phoenix
    Confuser? You're making this too complicated. Unless you are going to do several sets of headers a tool is unnecessary IMO
    Squeeze the primary tube in a vice so it will fit in the oval port. Put a couple of sturdy tacks on the primary to the flange. Use the ball end of the largest ballpeen hammer you have to work the primary tube into the oval flange. (I usually use the big hammer ball as a tool and hit it with another hammer) If you are using stainless tube, it will want to spring back and you may have to use some heat to get a good joint. Once you've got it fitting nicely, grind the tube flush to the flange and do a 'peanut' (autogenous) TIG weld at the joint. Braze the outside where the primary meets the flange and put in a nice fillet. Do this with the flange bolted to a s**** piece of steel (like a 6" piece of steel channel) and you'll have a pretty good chance of keeping it flat enough to seal.
    You can MIG weld the primary on the engine side of the flange like "Just Gary" did in a previous post, but you'll need to 'blanchard grind' the surface to have any hope of sealing the flange to the engine. (I've had reasonable luck using a belt sander with a sanding surface about the length of the flange) I think this is how most of the m***-production headers are made.
    ekimneirbo and patsurf like this.
  22. e015475
    e015475
    from Phoenix
    A set of long-tube headers for an OT engine. Used lumber to get the correct orientation of the flange to the collector and started cutting tubes to connect them
    Focus on fit-up - no lippage allowed! The steering shaft goes through the headers.
    An ICE header lego kit was useful and can be resold after you're done with it for nearly what you pay.
    ekimneirbo and Just Gary like this.
  23. 1946caddy
    1946caddy
    from washington
