Projects Tweety's 1930 Model A Coupe Build
Discussion in 'The Hokey Ass Message Board' started by Tweety, Aug 20, 2024.
  1. Tweety
    Tweety
    Thanks guys! I appreciate the kind words and motivation :)
    Stogy likes this.
  2. Tweety
    Tweety
    Almost forgot to mention—I had the 8" housing and buggy spring powder coated. A friend helped clean up some of the welds on the housing, and I also had a driveline shop check to make sure it was straight. For anyone in Edmonton looking for top-notch powder coating, I highly recommend Joanne at Perfection Powdercoating. Amazing service and excellent quality!
    20241104_180457.jpg 20241104_180507.jpg 20241104_190621.jpg 20241104_210344.jpg
    RMcCulley, loudbang, akoutlaw and 5 others like this.
  3. Tweety
    Tweety
    Probably over thinking things but looking towards breaking in this comp cams 262H hydraulic flat tappet cam. Figure I'll break in the cam with an Edelbrock 1406 & C4B intake. Hoping to enjoy the shakedown drives with an easily tunable 4bbl. Will give me some time to go through the 3 Ford 94's (which I know nothing about their history) later this year. Picked up this AWESOME air cleaner from Geardrive (Matt). This was one from his first production batch :cool:
    Stopped by the shop and took a few update photos. Exciting to see the doors back on it.(11/15/24)
    Still a bit of work to go on the doors... Also had to fabricate a pair of latch rods for the inside door handles. Does anybody know why these are sold out globally?
    (12/13/2024) Added a small notch to the rear wheel panels.
    IMG_20241209_122049.jpg Messenger_creation_0D5CF00E-4CCF-479F-8412-6238B32B3276.jpg Messenger_creation_E6431DCD-3DAF-4BC3-829E-A641C6349476.jpg
  4. Tweety
    Tweety
    01/10/24 Update: Getting closer to laying down some color on this old girl!
    20250110_161651.jpg 20250110_161715.jpg 20250110_161729.jpg 20250110_163235.jpg 20250110_163300.jpg
  5. Stogy
    Stogy
    Go Tweety Go!!...Young and motivated...good on you...Congratulations to you and your's...2 big milestones last year...
    When I joined the Hamb Coupe de Cab was making the rounds here...I believe it went overseas...Sweden maybe.
    You will enjoy the trip back in time...
  6. hotrodA
    hotrodA
    WOW!! Went back and read it all, straight through. It’s great to see a young guy doing such a good job on his coupe. Keep the updates coming for us.
    mad mikey, Tweety and Kelly Burns like this.
  7. 52lomofo
    52lomofo
    following this hello from fort sask
    Tweety likes this.
  8. Kevin Ardinger
    Kevin Ardinger
    Looks great! Very orderly and clean! If you don’t mind me asking, what is the diameter of that engine fan and what was the original application? Thanks
    Tweety likes this.
  9. Tweety
    Tweety
    Thanks @Stogy Gotta keep moving and motivated to stay young :)! The build has been a fun trip back in time. Looking forward to the full experience with the first drive!
    Stogy and mad mikey like this.
  10. Tweety
    Tweety
    Thanks @hotrodA I'll keep posting as the project moves forward!
    @52lomofo well hello neighbor!
  11. Tweety
    Tweety
    Thank you!! @Kevin Ardinger the fan is an Allstar Performance 15" mechanical. I could probably fit a 17" but it'll be a tight fit to the lower radiator hose. Likely end up running a 16"
    Here is a link to the fan: https://www.summitracing.com/parts/AAF-ALL30104
    Stogy and Kevin Ardinger like this.
  12. mad mikey
    mad mikey
    I am late to the party, the coupe looks fantastic. Excellent work tweety.
    Stogy and Tweety like this.
  13. Tweety
    Tweety
    Cleaned up the old Edelbrock C4B intake and decided to paint it to match the engine color.
    Everything was looking great up until this point :mad:... This is on me. The fit was too tight, and I knew it. I did my best to sand off the chrome plating where it would be installed and even froze the filler tube overnight. Now, I’m searching for a good aluminum welder in the area—really hoping it can be saved!
    20250203_131831.jpg 20250203_131836.jpg 20250203_131841.jpg 20250203_131851.jpg
    There’s always a backup plan... If it was good enough for GM, I’m sure it’ll work for what I need! Plus its the original. That counts as "traditional" right? :p Just need a spread bore to square bore carburetor adapter.
    Some time spent in the blasting cabinet and its beginning to take shape. I'll get some paint on it soon.
    Over at the body shop, the Jus Cuz crew is moving it along getting the grille shell mocked up in its final position.
    20250129_175956.jpg 20250129_180020.jpg 20250129_180058.jpg 20250129_180101.jpg 20250129_175906.jpg
    loudbang, Stogy and mad mikey like this.
  14. Tweety
    Tweety
    Thanks, @mad mikey That means a lot coming from the guy with one of the most BAD*** coupes on the HAMB. Seriously, man—your car is pure inspiration!
  15. Bentrodder
    Bentrodder
    from Cotati
    Wish you were closer. That's an easy manifold fix.
    mad mikey, Stogy and VI Lonewolf like this.
  16. leadsled
    leadsled
  17. VI Lonewolf
    VI Lonewolf
    This
  18. Stogy
    Stogy
    What would that easy fix be...hone the bore?
    Bentrodder likes this.
  19. Bentrodder
    Bentrodder
    from Cotati
    First weld, then bore.
    Tim_with_a_T likes this.
  20. Tweety
    Tweety
    I did manage to get the C4B repaired—turned out to be a simple fix. Ended up keeping the original intake but first drilled, tapped and plugged the “hot slot” ports. Pretty happy with how it came out!
  21. Tweety
    Tweety
    Meanwhile over at Jus Cuz things are progressing and the Coupe is finally wearing her first color...
    Messenger_creation_F4453CDF-E1F1-4E3A-8A81-D13D2C05A650.jpeg Messenger_creation_F22E8923-1EB9-4A28-BF5C-D47A397DD6E7.jpeg Messenger_creation_E233C539-106A-474A-A1DC-2CFFDA07323C.jpg Messenger_creation_69BFCAB1-765E-4B19-B472-3BA207367A53.jpeg Messenger_creation_7A0ACBF1-6E08-4EA1-A89C-E1161344E1A8.jpg Messenger_creation_ABFF1B25-D337-4028-ACCA-B40009250105.jpeg IMG-20250228-WA0000.jpg
    Can’t forget about the steering wheel... I hadn’t planned to focus on the interior just yet, but it’s starting to creep up the list whether I like it or not. A close eye might catch a glimpse of what is soon to come ;)
    Messenger_creation_0524E2CA-2B42-4347-971E-AB822B10C16C.jpg Messenger_creation_E2E1E959-41CF-47EC-9A96-F66ABA65E382.jpeg IMG-20250228-WA0003.jpg Messenger_creation_72A8FF81-0C72-4E26-A5D1-A1E73D0B419F.jpg 20250307_134844.jpg
  22. Tweety
    Tweety
    Scored a set of seat brackets at the junkyard that allow the bench fold all the way forward! It'll be nice to use that space behind the seat and up against the bulkhead. The recline bracket could use some attention :eek:... I’ve also been hanging on to this ’32 door handle for a while now… It found its home!
    20250314_195155.jpg IMG-20250314-WA0012.jpeg IMG-20250314-WA0018.jpeg 20250315_004606.jpg
    Also fabbed up a seat riser to cover the sliders. It will get carpeted when I do the interior.
  23. Tweety
    Tweety
    Block block block...
    20250319_183519.jpg 20250319_183543.jpg 20250319_183603.jpg 20250319_183532.jpg
    To all my wiring weirdos :p
    jet996, catdad49, loudbang and 3 others like this.
  24. Tweety
    Tweety
    Here’s a sneak peek of the interior materials. I’m still on the fence about a few details, but it’ll definitely tie in with the car’s overall theme! Planning to incorporate an original era-correct pattern into the seat. So many choices!
  25. catdad49
    catdad49
    This will be Special! I have that seat in my coupe, the fold down feature is a big plus.
  26. Tweety
    Tweety
    First peek at the color for the coupe — she'll be wearin' Ford's 1956 Meadow Mist Green :D:D
    20250409_181419.jpg Messenger_creation_483D5CE4-65B1-42E6-9024-6C58787C665C.jpeg 20250409_174102.jpg 20250409_174111.jpg 20250409_174124.jpg Messenger_creation_6AA4D28B-CA52-4A70-AFB3-CE8620B6BDA1.jpeg
    catdad49, RodStRace and Bentrodder like this.
  27. Tweety
    Tweety
  28. Tweety
    Tweety
  29. Tweety
    Tweety
    If it puts smiles on faces, that’s a win in my book :D Couldn’t have asked for a better crew to work with — the team at Jus Cuz knocked it outta the park (many missing in the photo)!
    20250507_195043.jpg 20250507_201551.jpg IMG-20250507-WA0003.jpg Messenger_creation_1345F1E6-4234-4C75-9983-FA88A0F83A4E.jpeg 20250509_165929.jpg
  30. Tweety
    Tweety
    Back in my own garage and didn’t waste any time gettin’ back after it!
    IMG-20250509-WA0004.jpeg 20250509_202246.jpg 20250510_133608.jpg 20250510_145035.jpg 20250510_145344.jpg Screenshot_20250512_110455_Gallery.jpg
