Hot Rods Homogenized ‘28 roadster build
Discussion in 'The Hokey Ass Message Board' started by Anderson, Oct 24, 2021.
  1. Anderson
    Anderson
    I know plenty about scrub radius. Hot rods are imperfect.
  2. Tim
    Tim
    from KCMO
    Ignition stuff can be frustrating. I spent a lot of July in the garage with a volt meter I’ll say that much.
    Just Gary likes this.
  3. Robdski
    Robdski
    This is drop dead ***y!
    Excellent quality build.
    Sending you good ju-ju, to sort out the ignition gremlins.
    neilswheels and Anderson like this.
  4. Anderson
    Anderson
    I swapped out the coil (though I don't think that made the difference), found the idle mixture screws turned way out, and the throttle blade adjustment screw turned way open. Reset those and did get it to run for a few seconds a couple times this morning off of fuel I dumped in through the carb vents. Started checking fuel lines and it hasn't ****ed a thing out of the tank yet. I'm going to get a little in line pump to try and get some fuel running through the lines and I think that will do it.
  5. Dedsoto
    Dedsoto
    from Australia
    You can prime it with a shot of air in the filler neck, mechanical pumps generally don't need it though
    Anderson likes this.
  6. Crusty Chevy
    Crusty Chevy
    I have done this too and also needed to add a one way valve in the fuel line to prevent siphoning back into the tank leaving a dry line every morning.
  7. Anderson
    Anderson
    This sounds like a great idea! Thank you.
    Dedsoto and porkshop like this.
  8. Anderson
    Anderson
    Jesus Christ…I’m an idiot.
    fuel pump is plumbed backwards……….
  9. Glad you found the problem Anderson. And no you're not an idiot....wish I had your skills bud!
    porkshop and Anderson like this.
  10. Anderson
    Anderson
    Well, now that the fuel pump WHICH HAS “IN” STAMPED ON IT is properly hosed…it runs!!
    It’s too late now to piss off the neighborhood. Forecast for tomorrow says rain but we’ll see…engine break in and a lap around the block tomorrow evening, weather permitting.
  11. alchemy
    alchemy
    Rooster tails!
    SilverJimmy, porkshop and Anderson like this.
  12. AmishMike
    AmishMike
    Always great to piss off neighbors. Teach them all to vote hot rods & any car changes ilegal
  13. Anderson
    Anderson
    …which is why I didn’t do it? The car has full exhaust but I wasn’t about to run it in the driveway after 9pm
    But since all their little children were running around in the street screaming by 10:30 this morning I figured I was safe. So I got break in done. But I’m still having trouble getting it to just flat run and idle. I’ve pretty much decided it’s a vacuum leak and am going to pull and reseal the intake.
    At the other end of the car…spring clamps were too tall. I drew up and ordered these from Send Cut Send before I left for the roadster show, and they arrived yesterday. Tacked the spacers to the main bar and bolted them on. The car settled a good bit out back. Looks good but I think I might need to raise it, probably stack a couple short leaves at the very top…so I might not need the spacers, hence tacks only so far.
  14. Anderson
    Anderson
    I have no intentions of turning another wrench or spending another discontinued penny on this car. Consider this the end of the build.
    IMG_7056.JPEG IMG_7057.JPEG IMG_7058.JPEG IMG_7059.JPEG IMG_7060.JPEG IMG_7061.JPEG IMG_7062.JPEG IMG_7063.JPEG IMG_7064.JPEG IMG_7065.JPEG IMG_7066.JPEG IMG_7067.JPEG IMG_7068.JPEG IMG_7069.JPEG IMG_7070.JPEG IMG_7071.JPEG IMG_7072.JPEG IMG_7074.JPEG IMG_7075.JPEG
  15. swifty
    swifty
    Sorry to hear that. Have followed and enjoyed your build since Day 1. I ***ume we will now see it listed in the HAMB Cl***ifieds as a running, driving and stopping "project". Was looking forward to a "Roadtrip to the ROC" story at a later date.
    osage orange and Just Gary like this.
  16. Tim
    Tim
    from KCMO
    Turned out killer, very tidy.
    Uncle Ronn and osage orange like this.
  17. Robdski
    Robdski
    Thanks for taking the time to do***ent your build.
    Good luck with the sale.
    neilswheels and osage orange like this.
  18. Anderson
    Anderson
    Headed elsewhere. Anyone need a cool intake and valve covers?
    Uncle Ronn, lurker mick, Tim and 4 others like this.
  19. Tim
    Tim
    from KCMO
    I’ll be keeping an eye out for it on the road! Hopefully I get to see it someday
    porkshop likes this.
  20. To a HAMB'r?
    porkshop and Just Gary like this.
  21. Anderson
    Anderson
    to a Facebook'r
