Technical Carb question
Discussion in 'Traditional Hot Rods' started by jerdan, Jan 29, 2025.
  1. What are you using to chase the threads on fuel inlet and vacuum port on a Holley 94
  2. tubman
    tubman
    The first thing I can think of is a "Ford Nut" with 3 or 4 "V" shaped grooves filed in it. The second is an application of JB Weld. The third is one of thes after re-tapping the carb body. https://www.napaonline.com/en/p/GATG492300404
    dogwalkin likes this.
  3. carbking
    carbking
    Best to acquire a bottoming tap of the correct thread.
    Jon
    mad mikey, Deuces, Toms Dogs and 2 others like this.
  4. clem
    clem
    Does a heli coil work in this situation if cleaning the thread doesn’t work ?
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I would worry about fuel seeping past the outside of the Helicoil threads.
    clem and Johnny Gee like this.
  6. patsurf
    patsurf
    seal it w/ the old permatex-as long as you never need to remove!
    clem likes this.
  7. tubman
    tubman
    Depending on the model of the carb, wouldn't it be easier to just find another carb body? These things are still around and except for some specific models, not that hard to find or expensive.
    carbking and clem like this.
  8. tubman
    tubman
    One of the carb experts on The Ford Barn says : "The threads are 3/8-24. It's not a tapered pipe thread."
  9. Speccie
    Speccie
    This might help..
    mad mikey likes this.
  10. clem
    clem
    1/2” x 20 tpi
    what Charlie shows in the video above is what someone showed me years ago and what I have done, just hard to find the fittings down here.
    The benefit is that you are not continuously disturbing the original thread.
  11. clem
    clem
    Yes - that was my concern, but I have no actual experience with helicoils.
    thanks, a possible solution if it holds up to the modern fuels.
  12. tubman
    tubman
    3/8-24 for the vacuum port.
