Lets see your car hauler/ flat bed trailer
Discussion in 'Off Topic Hot Rods & Customs' started by JD Miller, Jan 27, 2025.
  1. pprather
    pprather
  2. Texas John
    Texas John
    I share the feeling that we should drive our toys whenever possible, but there are lots of times that we need to haul it somewhere to get work done or pick up parts or another project or any number of other reasons.
    I do find it interesting that many of those that say they would never have a trailer are the same ones that ask to borrow mine when they need one. Which, by the way, is never going to happen. The last time I loaned my trailer out, I had to go get it because the guy kept "forgetting" to bring it back. He had also hit a tree with it. Never again.
  3. RmK57
    RmK57
  4. Sharpone
    Sharpone
    IMG_2914.jpeg IMG_2915.jpeg 10,000 lb Beaver tail with slide out ramps, removable 8000lb winch, tool box for a battery and strap storage, removable fenders. I need to install a removable spare tire rack somewhere yet. I also opted for the adjustable tongue height option.
    Dan
  5. fastcar1953
    fastcar1953
    trailer.jpg My trailers aren't fancy. I haul everything with them. I don't haul my running cars.
  6. Sandcrab
    Sandcrab
    Mine is an 18' EXISS 7500 GVW aluminum on torsion axles. It has pull out ramps and a very minimal rear ramp. The left fender is removable and I also added a 1 ton HF winch for pulling on a load.
  7. Tickety Boo
    Tickety Boo
    from Wisconsin
    Purchased this 2004 trailer used in 2014, welded on a receiver on the front to accept a detachable 8000 lb winch, later added the raised toolbox and pit bike front wheel chock.
    Did all new wheel bearings and brakes last year, always lost a lot of trim rings because rally wheels flex and spit rings off during the tandem axle turns, so going to put the original white painted wheels back on with new tires.
    Picture is when it was loaded up, leaving for the 200+ mile pull to the Melt Down Drags in 2018 :)
    Okie Pete, Sharpone, rod1 and 3 others like this.
  8. snoc653
    snoc653
    from Iowa
    This is a great example of why some of us plan on trailering our cars to some events even though they are capable of driving there under their own power. It is very rarely the getting to a performance event that is the problem. But if you take your car and race to win, there is always the chance that something breaks. It is something to factor in when deciding to attend events outside of the reasonable recovery range if something breaks. Since drag and drive events allow two in the vehicle, I plan to drive to the event and have the second person drive the truck and trailer. Breaking the car 600 miles from home and then having to arrange recovery or pay shop rates to repair it, could eliminate the cruise budget for the rest of the year and then some. With any racing or performance event things break. It is inevitable. That being the case, there is no excuse for not having at least some sort of a plan on what to do if the inevitable happens to you.
  9. Big M.
    Big M.
    Okie Pete, rod1, Sharpone and 3 others like this.
  10. chevy57dude
    chevy57dude
    The rusty old drag trailer has been on life support since I "saved" it. New axles, tires, paint and hardware. All this bolt on stuff is ok, but the carc*** is bad. See how the beaver tail is ready to fall off. Selling it cheap as soon as I get my enclosed one, this spring I hope
    Deuces, Tickety Boo, Sharpone and 2 others like this.
  11. lothiandon1940
    lothiandon1940
    ....He's telling the truth.
    pprather and Sharpone like this.
  12. ffr1222k
    ffr1222k
    1956 on trlr2.jpg The day I bought my 56.
    Still have the trailer, wish I still had the dually...
  13. RmK57
    RmK57
  14. phat rat
    phat rat
    P1060608.JPG The trailer I use for hauling projects back from the western states. It's 34' bed, 63" Peterbilt walk in semi sleeper, headache rack, a 12K winch and a 5K electric tongue jack. I've also built a removable stacking system so if I hauling roadster bodies or truck beds I can stack them. I have a system that allows me to carry 2 Model A frames laying on their side behind the fenders on each side and still able to drive a car between them. It has an abundances of D ring tiedown's 76 total https://www.facebook.com/marketplace/item/500858562718127
  15. arse_sidewards
    arse_sidewards
    from Central MA
    That trailer weighs more than the cargo.
    Sharpone and porkshop like this.
  16. phat rat
    phat rat
    ^^ As always keyboard experts^^
    porkshop likes this.
  17. snoc653
    snoc653
    from Iowa
    You do realize nobody has said what their trailer weighs. Car trailers are rated by weight capacity not how much they weigh.
  18. arse_sidewards
    arse_sidewards
    from Central MA
    Y'all are getting might defensive. I didn't say it wasn't a fine setup, just that it was pretty heavy for the cargo pictured.
  19. phat rat
    phat rat
  20. Kerrynzl
    Kerrynzl
    That sleeper cab on the front is a brilliant idea.
    Especially for racers who can take all their tools with them .A tool shed and a rock guard together
    [I'd adopt that idea in a heartbeat except I have an unusual trailer storage situation]
  21. phat rat
    phat rat
    It's not a tool shed, but it is a great rock guard. It's my living quarters when I'm on the road, no motel bills for me that way. This is the second trailer I've had a sleeper on
    Okie Pete, Sharpone, porkshop and 4 others like this.
  22. Kerrynzl
    Kerrynzl
    I built this one [and copyrighted the design]
    It weighed 480kg [1056 lbs] on a certified weighbridge.
    Most Utes and SW's here have a factory tow rating of 2200kg [4840 lbs] so this would allow a 3784 lb payload when towed behind a Falcon / Commodore SW [or Ute]
  23. Okie Pete
    Okie Pete
    IMG_6812.jpeg Here’s a picture of a trailer we use on the farm and haul everything with it . Built extra long ramps . Put 3” spacers between the wheels and hubs so the Hough 30 loader will fit between the wheels. The fenders are held on with 2 bolts . That’s so we can take them off to load the Hough and tree saw . After equipment is loaded the fenders are easily put back on for traveling done the road . Mounted a receiver hitch on the front of the trailer to mount the winch off and on when needed .
    chevy57dude, Deuces, ffr1222k and 3 others like this.
  24. Okie Pete
    Okie Pete
    IMG_5164.jpeg Here’s the winch in the cradle I made for it .
  25. swade41
    swade41
    from Buffalo,NY
    Mine is a 18ft with 3500 lb axles and 8.5 wide, it tows great and gets the job done, I moved the side load ramps to the back as slide outs.
    If I had to buy a new one I'd get a tilt, even with the beaver tail it's hard to load a low vehicle on it.
    20180805_101803.jpg Screenshot_20230803_141215_Facebook.jpg 14046054_10206514786217143_5038052397994196375_n_zpskpt4jyhh.jpg
    chevy57dude, Deuces, ffr1222k and 5 others like this.
  26. mohr hp
    mohr hp
    from Georgia
    A lot of you guys have Been There And Done That! My wife and kids run for cover when asked to help load my trailer. I've got a damaged bed side on my tow vehicle and damaged door on the Studebaker from over estimating what a "helper" is capable of.
    Rod St.Race laid out a lot of important stuff. Towing is a lot of responsibility. Nobody wants to be broke down on the side of the road, but heeding some of these little tips can sure prevent a lot of pain.
    My 2 biggest tips: 1 Slow down! don't tow at 80 MPH!
    2 Spend more on tires than you want to, and do it more frequently than you'd like!
  27. Okie Pete
    Okie Pete
    A wise man once told me :
    A Friend owns a pickup.
    A very good Friend owns a pickup and trailer
    ffr1222k and Sharpone like this.
  28. phat rat
    phat rat
    That's the problem with short beavertails. Look at post 44 and how long the beavertail is on mine. An earlier trailer had a beavertail like yours and it was sometimes hell to load a car because of it. I've never had a problem with this trailer
    Okie Pete, Sharpone and swade41 like this.
  29. swade41
    swade41
    from Buffalo,NY
    That's some overhang, if my ramps were twice as long it'd probably be easier. The last time I towed my 41 pickup I had to remove the front clip to get up the ramps and that was with jacking the trailer tongue up.
    Okie Pete and Sharpone like this.
  30. snoc653
    snoc653
    from Iowa
    You can unhook and raise the tounge if you have some bocks for the beck of the trailer. If you use jacks to hold up the back of the trailer, you could also raise the back of the ramps when the car gets close to high centering.
    Warning don’t unhook the trailer and then move the jacks. This could have very bad effects. It should be either or.
    Okie Pete likes this.
