Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. rod1
    rod1
    I have one here you can have:1956 Olds 324 turns over, needs refreshed.Figure out the shipping and she's yours. I actually love SBCs, but Doane was Blue Oval all the way ,I believe.
  2. HelminenHotrods
    HelminenHotrods
    from Finland
    Why are all the best deals 6000miles away :(
    Thank you for offering !!
    rod1 likes this.
  3. HelminenHotrods
    HelminenHotrods
    from Finland
    360° view of the stainless steel bracket.
  4. Koz
    Koz
    Just caught this thread and I gotta' say that windshield is just the "nuts". Quite possibly the finest piece of craftsmanship I've seen in a long while. Keep up the great work. A true inspiration!
    HelminenHotrods likes this.
  5. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you !
  6. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! Comments like this keeps the motivation up !
    Koz likes this.
  7. HelminenHotrods
    HelminenHotrods
    from Finland
    Heres the steering column and shaft.
    Using pretty basic hardwere shop materials like exhaust tubing, weld-on bungs and oilite brass bushings.
    VideoCapture_20250129-115743.jpg VideoCapture_20250129-115619.jpg VideoCapture_20250129-115600.jpg VideoCapture_20250129-115641.jpg
    Steering shaft is splined borgeson. The flange is old 1958 vespa rear hub flange what i had shelf.
    Also made column bracket and support to dashboard and second mount to the brake/clutch frame IMG_20240816_211115.jpg IMG_20240816_210857.jpg IMG_20240816_211214.jpg IMG_20240827_185314.jpg
  8. HelminenHotrods
    HelminenHotrods
    from Finland
    View of the whole car for a change. Sitting at ride height IMG_20240828_204450.jpg
  9. fordor
    fordor
    from Finland
    Hyvältä näyttää.
    Looking good.
  10. HelminenHotrods
    HelminenHotrods
    from Finland
    Tattista !:cool:
  11. HelminenHotrods
    HelminenHotrods
    from Finland
    Long-awaited part of the build was steering wheel.
    At first i had in mind 50s steering wheels, one buick and one oldsmobile. But the 18 inch wheel diameter is just really big for channeled model a.
    In my taste at least.
    So i started thinking other route, and ended up buying vw beetle steering wheel, because it has 15,5 inch
    Cutting of the wheel off the hub and building my own IMG_20240905_202138.jpg IMG_20240905_202146.jpg
  12. HelminenHotrods
    HelminenHotrods
    from Finland
    20250131_123748.jpg 20250131_123732.jpg 20250131_123714.jpg 20241011_214105.jpg
    Hudson horn emblem looked cool and was avaible in ebay, so thats what im using. Horn ring was broken but does not matter because im only using the emblem. 20250131_124631.jpg 20250131_124616.jpg
    Emblem has crackling efect from ageing, but it looks pretty cool
  13. brading
    brading
    Got to say you workmanship is amazing. Such detail making welded parts look like they have been cast or forged.
  14. HelminenHotrods
    HelminenHotrods
    from Finland
    I had bought this old ( maybe 40s ? ) bicycle headlight from swapmeet past winter.
    That old bicycle headlight and hudson emblem was match made in heaven
    There i had an route to start with.
    Moving on to trim. Made from stainless steel. Same style as the dashboard trim.
    Bits and pieces. Everything made from stainless steel. 20250131_130451.jpg 20250131_130524.jpg 20250131_130556.jpg 20241006_145402.jpg 20250131_130632.jpg 20250131_130646.jpg
    Welding was very tricky because that ribbed piece is made from very thin stainless steel sheetmetal, and has to be grinded and polished. 20250131_130704.jpg 20250131_130716.jpg 20250131_130730.jpg
    And short cut to finished product. Lots of everything in between. Grinding, polishing, fill welding, grinding, polishing this x10. And figuring out how to mount everything.
    That half loop horn ring is also from stainless steel, welded on. For looks only 20250131_130758.jpg 20250131_130826.jpg 20250131_130839.jpg 20250131_130855.jpg 20250131_130910.jpg 20250131_130934.jpg
  15. Happydaze
    Happydaze
    I've just re-found and reread this wonderful thread. Incredible!
    Chris
  16. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks guys ! :cool:
  17. HelminenHotrods
    HelminenHotrods
    from Finland
    And an video of the steering wheel.
    Hope the videos work. I'm posting with phone so everything looks and goes bit different than on computer
    Kreepea_1 and Uncle Ronn like this.
  18. patsurf
    patsurf
    you look like one of those fellas who can tig tin foil together!--nicely done...(tattista?)
    Tim_with_a_T likes this.
  19. Rickybop
    Rickybop
  20. HelminenHotrods
    HelminenHotrods
    from Finland
    It's almost as thin as tin foil, after all the grinding and polishing ! Couple Pinholes left but it keeps getting thinner and thinner every time. Time to let it be :D
    Tattista or tattis :D Old Finnish slang word from swedish, Grattis or Tack, meaning in english Thank you :)
  21. patsurf
    patsurf
    how funny-i guessed (wrongly) that it was norskie for .as we say here,..'tits! when something is a beauty..
  22. Bugguts
    Bugguts
    Wow! Your steering wheel looks amazing,especially after seeing all the work you put into it!
    Thanks for sharing!
  23. HelminenHotrods
    HelminenHotrods
    from Finland
    At final stage i'm going to paint the steering wheel. Maybe ivory white, or maybe some sweet candy.
