Hot Rods Hemi stumbling off idle...
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jan 31, 2025.
  1. flynbrian48
    flynbrian48
    For about a year I've an annoying issue with the roadster. The '52 DeSoto Hemi has an (increasingly occurring) stumble accelerating right off idle. It seemed that it's a "too-lean" issue, and I had tried to overcome it by enriching the choke setting. (I know, I know, that isn't the "right" way, but I figured it was worth a try, right?)
    This morning I let the car idle in the driveway for a few minutes while I did something, when I walked behind the car my new, brushed concrete drive was stained with black carbon from the exhaust.
    So, I thought about the problem for a minute while I drove to the grocery store, increasingly annoyed with it stumbling and coughing, figuring that a 4 year diet of 15% ethanol regular might have something to do with this increasingly noticeable problem. When I got home I looked on-line for a carb kit for the obsolete, 2 year only Carter carb.
    Guess what? Two clicks got me to a supplier, and $95 later on my debit card I have a rebuild kit coming for it.
    I'll have it in a few days, and will be anxious to see if my diagnosis is correct and I can dial the choke back to where it's not flooding to overcome this.
    83FBAB61-08AE-468B-9CCF-568DBE570BF6.jpeg FD1835A7-C2CE-45AE-BE5E-4A3C547EA810.jpeg
  2. RodStRace
    RodStRace
    Check the ignition while you are at it.
    These cars and engines required regular maintenance, and the parts available these days cause a lot of threads on top of that.
    Best of luck getting it back into tip top shape.
    Just Gary, rockable and flynbrian48 like this.
  3. Mike VV
    Mike VV
    from SoCal
    Brian -
    1. Where is your ignition timing ? If..."per the book"... Increase ignition timing 4° then try 6° .
    2. Open both of the idle mixture screws from smooth idle by 1/4 to 1/3 a turn more.
    3. Hard to tell...put the accelerator pump arm in the first (shortest length) hole).
    Mike
  4. flynbrian48
    flynbrian48
    Pertronix, new plugs, wires, cap, rotor. Been there, done that.
    Just Gary and RodStRace like this.
  5. flynbrian48
    flynbrian48
    I can play with the timing a little. I advanced until it kicked back against the starter when warm, then just backed it off a little until it no longer did, so I don't know if there's much left to advance without causing more problems. And, moving the pump am was my first thought, but there's no adjustment on this particular carb. So, I'm going with the pump may be the issue. Thanks for the thought on the issue.
  6. Kerrynzl
    Kerrynzl
    Set your timing to spec [vacuum advance disconnected] then re-connect the vacuum and take anothe reading of the timing with the light [it should pull another 4°- 8° with the vacuum at idle]
    Then disconnect the vacuum and advance the timing so it is the same at idle as before [with the vacuum connected]
    Connect the vacuum to ported vacuum. [or simply try it without vacuum advance]
    I have had a lot of off idle stumble issues fixed by going to ported vacuum [this is because you usually get max vacuum at idle, and zero vacuum when you open the throttle]
    The advance can instantly drop from eg: 14° - 16° back to 8° - 10° when you touch the gas pedal causing a stumble.
    Try it ..... It doesn't cost anything
    alanp561, rod1, osage orange and 3 others like this.
  7. 1971BB427
    1971BB427
    from Oregon
    This type of problem is often a bad diaphragm or cup in the accelerator pump and the ethanol mix gas attacks rubber even faster. If it was a modern carb they make accelerator pump replacements that are designed for this **** gas, but yours being an old carb will likely require you to rebuild it every so often until the carb gets replaced with something modern that accepts the modern accelerator pump diaphragm.
  8. jimmy six
    jimmy six
    You need the accelerator pump squirt right at the crack of the throttle. Holleys are the easiest to set.
  9. Oneball
    Oneball
    Where is your choke heat tube?
    ClayMart likes this.
  10. HOTRODPOWELL
    HOTRODPOWELL
    Add a blower it will never stumble again
    winduptoy, shorrock, Rickybop and 2 others like this.
  11. dart4forte
    dart4forte
    from Mesa, AZ
    330 Hemi?
  12. flynbrian48
    flynbrian48
    276 DeSoto.
  13. dart4forte
    dart4forte
    from Mesa, AZ
    I’d have to lean toward the carb. Probably the accelerator pump. Gas these days is terrible. Basically rots the rubber in the older carbs
    flynbrian48 and 73RR like this.
  14. RAK
    RAK
    I never use ethanol gas in my older cars and we have a house in Florida and non-ethanol gas is widely available there because of boats/golf carts etc........
  15. Rickybop
    Rickybop
    Yeah but you've been running it with the choke partly on. I think it's worth pulling a plug or two to make sure they're not all black and fuzzy.
    I honestly don't think it's the plugs, because usually if the plugs are fouled, it'll idle but won't rev up. But at least you'll know for sure.
    73RR likes this.
  16. 73RR
    73RR
    Have you considered changing to a 'newer' carb? Plenty of big 2bbl from early 70's.
    Carb kits will be cheaper and easier to get a better accel pump.
    Kerrynzl likes this.
  17. dart4forte
    dart4forte
    from Mesa, AZ
    That’s why I like the ole Carter 9636. I’ve never had a problem with those.
  18. flynbrian48
    flynbrian48
    They're clean.
    Rickybop likes this.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The problem with his engine is finding an intake manifold that you could bolt that to.
  20. abe lugo
    abe lugo
    are you running a stock mechanical fuel pump? or electric? If you are running an electric pump, does the PSI does it match with the carb?
  21. dart4forte
    dart4forte
    from Mesa, AZ
    OFFY has a 4 barrel adapter plate. Also Hot Heads has an intake
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I know about 2 bbl. to 4 bbl. adapters. They're the automotive equivalent of shoving a cu***ber down the front of your pants.
    SS327 and loudbang like this.
  23. flynbrian48
    flynbrian48
    I primarily run Rec-gas (non-ethanol) in it down here, but it's mostly been fueled with regular with ethanol. In Michigan, where it's been up until now, when stored I disconnect the fuel line at the tank and run it until it's out of fuel so as to not let the fuel pump and carb set 4 or 5 months with ethanol fuel in 'em. Honestly I don't think that's much of an issue, as carbs needed to be rebuilt and fuel pumps replaced regularly "back in the day".
  24. flynbrian48
    flynbrian48
    Hot Heads offers a 4 bbl intake for these low-deck DeSotos, but it's UGLY. I had gotten a 2-4 bbl adaptor for it back in Michigan to put a new E carb I have on it, but the base of manifold is wildly different than any other 2bbl base those things will bolt up to. So, I'm kinda stuck.
  25. flynbrian48
    flynbrian48
    Whelp, I think I fixed it. My wife had a health issue (actually a Pickleball injury) and surgery, so for the past couple weeks nothing has happened hot-rod wise. I'd ordered a carb rebuild kit, got that then she got hurt and haven't messed with it. Today I took a few minutes after thinking about your post and got after it...
    I was able to bump the timing ahead (it must have moved or I hadn't tightened the hold down), and gave each idle jet a quarter turn.
    VIOLA! It runs like a ****d ape now, NO stumble off idle, idles so smooth I could balance a quarter on a valve cover, and, it starts better. Not that it was bad before, but it barely rolls over now and it lights. I didn't have enough timing before, it seems really happy now, so thanks for making me think about this for a bit. :)
  26. Bandit Billy
    Bandit Billy
    You gave the mixture screws a quarter turn which direction?
  27. carbking
    carbking
    The older carburetors came with LEATHER accelerator pumps, which are totally impervious to ethanol.
    It wasn't until the late 1950's early 1960's that some of the carburetor companies "cheaped out" with neoprene. The neoprene pumps are the ones that don't like to use ethanol, and then dry out. The leather pumps, with a few drops of oil after sitting unused over the winter, will last virtually forever. Perhaps Holley and Rochester wanted to sell more rebuilding kits ???
    Stromberg never cheaped out, and Carter didn't, except on the diaphragm carbs, until the late 1970's (and then only on a few applications, not all).
    Jon
    loudbang, HemiDeuce and 57 Fargo like this.
