The elusive 224/3.7 MerCruiser banger
Discussion in 'The Hokey Ass Message Board' started by tjm73, Apr 9, 2008.
  1. beck
    beck
    Does a BBF (our 3.7) header fit if it is put on upside down. I'm thinking a cheap block hugger 460 exhaust header could be modified easily with a turbo flange if the header could be flipped. I didn't know if the bolts were centered in the ports. I can't just go look at mine since my A460 head has BBC exhaust ports.
    Would the header clear the valve cover if it was upside down? It may take some extra slicing and dicing at the bends coming out of the ports?
  2. 34Phil
    34Phil
    [​IMG] spark plugs would want to be in same space and port not centered between bolts
  3. tjm73
    tjm73
    Did you use a Word Class main case? What clutch did you use? What flywheel did you use?
  4. Flatrod17
    Flatrod17
    tjm73,
    It was a world class case. I already had the flywheel in my pile, it is an aftermarket steel one with a bolt on weight for a small block Ford, 157 tooth. I removed the weight and checked the balance, and it was good to go. The clutch, case and pressure plate all came from MDL. Paul recommended a dual lining disc, it is 10.5 dia. and as I remember was Kevlar on one side and regular martial on the other. I can look back and get numbers if you need them.
    tjm73 likes this.
  5. tjm73
    tjm73
    I would be interested out of curiosity. That clutch sounds very much like a typical 5.0 Ford setup, which would make sense given the transmission/flywheel configuration.
  6. Flatrod17
    Flatrod17
    tjm73,
    the case was listed as GM Muncie pattern WC T-5 case, I used a MD-900-2503-A hydraulic T/O bearing, CA70071 Pressure plate 10.4 dia, and KK-10.4-10 disk. This was all from MDL. To do believe it is all typical 5.0 stuff.
  7. MrCarts
    MrCarts
    from So Cal
    I have been following this thread since 2011.
    I found a rebuilt 470, it is a short block needing to be and assembled but it is complete.
    I am going to put it in a CJ-5 that has been a abandoned project.
    The jeep has been converted into a sand buggy the 4x4 has been remove and a straight front axle with center diff rear axle.
    My question is what is the simplest transmission to use?
  8. beck
    beck
    These have a GM bellhousing pattern except for 1 bolt. The bellhousing is about 5/8" longer than the rear of a Chevy. Many guys take a cut off of the rear of the block to mount GM automatics. Look at the previous page for more information. There are ways to mount manual transmissions without cutting the block. Do you want an automatic or manual?
    arse_sidewards likes this.
  9. MrCarts
    MrCarts
    from So Cal
    I would like to use a GM 350 , 400 or 700r.
    It is a 170 with 2bbl would like to use the stock water pump with the truck manifold and a bolt on Alt.
    Thanks
  10. MrCarts
    MrCarts
    from So Cal
    Where can I get this adapter?
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Looks like a sprint car part. You'll want one for a Ford small block.
  12. MrCarts
    MrCarts
    from So Cal
  13. beck
    beck
    The stock water pump would work, but I would be concerned about water leakage into the block like they are known for. There are some posts here about using a Toyota water pump on a home built mounting plate that would eliminate that concern. Glen Wilson has been using one for quite a while on his '32 Ford.
    I don't know what you mean by "truck manifold"???
    There are kits available to install the big GM alternators. I made my own mounts and installed a smaller Nippondenso
    one. If installing a bolt on alternator I recommend removing the stock balancer and stator so you don't have to fight the loose magnets later. SBF balancers fit. A bolt on pulley is needed with a new balancer.
  14. beck
    beck
    What does that adapter do?
    I installed a manual trans behind my motor which required a pilot bearing bored into the crank.
    I don't know what is needed in the crank for torque converter centering if anything. I had mocked up an automatic behind my motor and had just put spacers between the flex plate and torque converter. That did nothing to align the center of the torque converter. Is that needed?
    I am planning an automatic transmission on the next one, so want to figure this out. If it was as simple as installing 5/8" spacers everyone would do that instead of machining the back of the block.
  15. MrCarts
    MrCarts
    from So Cal
    I do not want to put a Toyota pump on the seals will be new and I will watch for coolant from weep hole. It looks cleaner.
    Truck Manifold for exhaust
    That is for a GM Auto trans lifted from FB 470 site.
    From BAD ZUK on this site:
    I have a th350 bolted to the back of my 3.7. After much measuring and playing with flex plates and spacers and not having a solution I was comfortable with I simply made a bushing on a lath to hold the snout of the torque converter, and then drilled the stock flywheel with the correct bolt pattern for the converter.
    So far it has worked well, I was worried about the excess weight of the flywheel and torque converter together, but the engine still revs up well, and on the low rpm it lugs along like a tractor.
    I use this in my off road buggy, so it is not a screaming high performance drag machine, but it scoots along just fine.
    Total cost? = about 10 minutes of machine time from a friend, and a 2" long piece of scrap tubing.
    Having one of the best performing and most unique rigs on the trails...Priceless.
    Also from this site:
    A Flexplate off a 74 Maverick with a straight 6 fits nicely, and would work perfect by milling the block 5/8". You would still need a pilot adapter for the nose of the torque converter.
    However in my case I didn't have the resources to mill the block, so I reused the stock flywheel off the mercruiser and drilled the appropriate pattern in it to bolt up the torque converter. The spacing was perfect, 1/8" between the two.
    Then I just fabricated my own pilot bushing that indexed off the pilot in the flywheel.
    Ford to GM Flexplate
    https://www.tciauto.com/externally-...transmission-adapter-flexplate-50-oz-cpg.html
  16. MrCarts
    MrCarts
    from So Cal
    I am looking for the easiest way to a Auto trans mounted to the 470.
    170 hp is plenty for my use just cruising around.
    I do not want a multi year project.
  17. beck
    beck
    Was this from a Ford truck? I haven't seen one like this. The collector outlet is shaped differently. I expect this is cast iron and heavy? Weight is my enemy.
    The flexplate you have a link to will not work as it is. It has the counterweight welded on. That would have to be removed. I used this one which isn't counterweighted and is about 1/4 the cost. PRW Power 1830213 PRW Platinum Series High-Inertia Flexplates | Summit Racing
    Does anyone have some drawings or dimensions of the required pilot bushing? Or a link to a commercially available one?
    I like the idea of mounting the torque converter to the flywheel however for my usage weight is critical. I pull custom built 4 cylinder powered garden tractors. The total tractor weight has to be under 1150#. By the time the weight of the transmission and automotive rear axle is added it is getting heavy. This eliminates the usage of the stock flywheel. A Powerglide is lighter than a TH350 but 1st gear is too high (1.8 vs 2.52). Either low gear is slightly adjustable with mods (2.75 in the TH350). The torque converter adds considerable weight also. Currently I have a small manual trans mounted using a small dirt track racing clutch. I realize now my clutch isn't going to survive so am looking at the automatic.
  18. beck
    beck
    You do realize how long these motors are right? If a BBF 460 won't fit lengthwise the 3.7 won't either.
    I like your post about putting the torque converter onto the flywheel. If that works, I think it would be the easiest due to no block machining required. That flywheel is about 30# if I recall so it will take some of the vibration out of the big 4 cylinder. If reducing weight wasn't such a high priority for me, I would like to try that setup.
    The GM automatic is the way to go for you, I think. No clutch linkage and easy shift linkage.
    I'm guessing that you are going to keep the cast iron head also? I threw 3 of those away 2 weeks ago. I may still have a couple flywheels. If you aren't concerned about weight, use that "truck exhaust" manifold. An iron Mercruiser exhaust could have the water passages cut off, but it would give you a vertical outlet instead of downward. I have one of those done here if you want a photo. I see a lot of rat rods with their exhaust sticking up from the engine bay.
  19. tjm73
    tjm73
    That exhaust manifold is from a HD truck (ie... dump truck).
  20. MrCarts
    MrCarts
    from So Cal
    Not worried about length there is plenty of room for the engine.
    PRW Platinum Series High-Inertia Flexplates 1830213
  21. Rootsgroup
    Rootsgroup
    from Indiana
    Haven't been on here for a long time. Made great progress on my dirt champ car in '24. Runs now, I have a video if I can figure out how to get it to post lol
    AccurateMike likes this.
  22. arse_sidewards
    arse_sidewards
    If anyone wants a mostly done project I'd offer a serious discount over my asking price in the for sale section if someone in this thread (i.e someone who would actually build a Mercruiser and wasn't just looking for a discount on some 460 parts) wanted it.
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Anyone have any experience or ideas on building or modifying a Tach drive distributor for this engine?
    I have a really cool old tach that I'd love to use on a project but would need to fab up something and there's not a lot of room to work with.
    Right now I have on original Mercruiser distributor with a vacuum advance from a Corvair.
  24. Flatrod17
    Flatrod17
    Are you wanting to keep it in the stock location? ? What do you have for a intake? The height of it all will be the problem. Right now I am working with a short small diameter VW dist to try to clear my new intake. It is promising. The other options are off set drive, or running off the end of the cam either straight out if room or a 90 degree off the end of the cam.
    Any pics of what you want to use?
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I am open to all options at this time. KISS is what I like. I am using a stock 2 barrel manifold modified for side draft carburetors. Height isn't a Big problem but I'll get a better idea and post that up.
    This might work if I can convert it to 4 cyl. the guy that owns it says, "Ford, but not 302. Maybe 460."
    No vacuum advance :(
  26. Flatrod17
    Flatrod17
    Bruce, I think its doable. That is a Marine 289/302 distributor. If you look back to when I first converted my VW dist I used a MSD small block Ford as a starting point. You will need to get a 4 lobe cam for it, but they were used a lot in Mallory's dual life I think they were called. I might some here somewhere. There is a 4 cyl Mallory dist cap here on the hamb for sale right now as well, it should fit I think.
    If the diameter of the area just above the flange and below the tach drive is 1.280 I think it was, or you can cut it down to that, then make a flange ring to set depth. then check shaft diameter, Stock is .490, I don't remember what Mallory's are, shorten and set gear height and it should work!
  27. Flatrod17
    Flatrod17
    After digging out a small mallory dist from my pile I see the small block advances the wrong way, so rotation would have to change too.. I don't know enough about the mallorys to know if it could be done.
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yep, I'm looking at all possibilities and welcome all suggestions.:D
  29. tjm73
    tjm73
    I'm surprised nobody makes an electrically triggered mechanical drive box for this kind of application. I'm sure plenty of guys would like to use a distributor drive tachometer.
  30. 34Phil
    34Phil
    Nichols had an engine pic where distributor was above intake. Not sure what combo did it.
