Projects 57 Ranchero Fuel Filler neck Needed
Discussion in 'The Hokey Ass Message Board' started by texdesoto, Jan 31, 2025.
  1. texdesoto
    texdesoto
    Have tried C&G Ford and all the others, Drake, Concours, Carpenter, no luck. Anyone else have to replace the filler neck on a Ranchero or SW, any ideas, my old one is rotted. I have a new tank from Drake, but the neck isn't available anymore. Thanks
  2. SPEC
    SPEC
    Try Yogis 800-373-1937.
    hrm2k likes this.
  3. warhorseracing
    warhorseracing
    from cameron wv
    Go to a muffler shop with your old one as a pattern and have them bend you one up. Take everything back home and remove the cap adapter and reweld it back onto the newly bent up filler neck. WALA! A brand new unobtainable filler neck.:cool:
    alanp561, hrm2k, juan motime and 5 others like this.
  4. bchctybob
    bchctybob
    Post a picture of your old one so we know what you need.
    hrm2k likes this.
  5. ^^^^^ This. That's what I did on my filler neck to extend it up taller on my avatar as the new gas nozzles wouldn't fit down far enough with the stock one without spilling. Save the mounting bracket off yours.
    alanp561 likes this.
  6. dalesnyder
    dalesnyder
    The filler necks from 1980s to 1990s f150s have a short metal stub at the cap end and use large rubber hose to drop to the tank. They would seem pretty easy to adapt. If your not looking for o.e.
    hrm2k and abe lugo like this.
  7. drtrcrV-8
    drtrcrV-8
    Would the neck from a '57-'58 station wagon work? They use the same tank.
  8. texdesoto
    texdesoto
    Genius, why didn't I think of that. Thanks, sounds like a plan.
    warhorseracing likes this.
  9. texdesoto
    texdesoto
    Yes, same neck but same issue with finding one. Thanks.
  10. texdesoto
    texdesoto
    Will do, thanks.
  11. abe lugo
    abe lugo
    Post up on the 57 ford forum.
    I came across one a year ago but only got the sending unit to make my own working on. For my wagon.
    if you are on IG fomocochop was just getting some parts for 57/58 so he might have one.
  12. gimpyshotrods
    gimpyshotrods
  13. texdesoto
    texdesoto
    Yep, will salvage the cap end and bracket off my old one, Thanks. C&G Ford, good source for a lot of parts, coll music while on hold. LOL
  14. gimpyshotrods
    gimpyshotrods
    I use exhaust tubing and parts from here for one-off stuff: https://www.fillernecksupply.com/
  15. texdesoto
    texdesoto
  16. gimpyshotrods
    gimpyshotrods
    Yup. Dig around in it.
    I have solved many problematic installs with parts from there.
  17. Dominick Hide
    Dominick Hide
    Call Don Hyde (no relation) at Fordcraft. He has them in stock. No web site, phone# is 972 423 4636. Located in Murphy Texas, a little north of Dallas.
    abe lugo, RICH B and alanp561 like this.
  18. texdesoto
    texdesoto
    Hey, thanks a lot, the HAMB and its members are really the best.
