Projects Uncle Jim’s 32
Discussion in 'Traditional Hot Rods' started by Brian Berger, Jan 23, 2025.
  1. Brian Berger
    Brian Berger
    Found an old cooler for the old girl to have some cold drinks too! IMG_6060.jpeg IMG_6062.jpeg IMG_6075.jpeg
  2. Brian Berger
    Brian Berger
    Working on getting this old quick change in the car. I thought I could keep the stock 32 crossmember and spring ,but not any clearance . So I’m gonna pull the body and swap to model A stuff. IMG_6298.jpeg IMG_6301.jpeg IMG_6302.jpeg IMG_6303.jpeg IMG_6311.jpeg IMG_6308.jpeg View attachment 6334847 View attachment 6334848 IMG_6298.jpeg IMG_6301.jpeg IMG_6302.jpeg
  3. ROADSTER1927
    ROADSTER1927
    Put your spring in the front and it will work fine.
  4. Brian Berger
    Brian Berger
    Spring in front of axle? Not behind? That would make the rear axle back way too far. Wheels would be off a mile on the body,it’s already back a bit IMG_6135.jpeg
    hfh, GlassThamesDoug and Okie Pete like this.
  5. Brian Berger
    Brian Berger
    Also the rear frame has been pie cut at one time as it was close to the crossmember with the stock 32 banjo
    Tow Truck Tom likes this.
  6. SPEC
    SPEC
    What you need is a model A cross member and a model A spring.
  7. Brian Berger
    Brian Berger
    I have one it’s in the pic. I thought it would work without it. This my first 30’s car.
  8. ROADSTER1927
    ROADSTER1927
  9. The37Kid
    The37Kid
    Great car, really enjoy the story, Welcome to the HAMB!
    Bob
  10. Brian Berger
    Brian Berger
    IMG_6347.jpeg Getting ready to pull the body I took the trunk off and washed it with an SOS pad. I’ve never hit it with water yet. Not really sure it’s been washed in a very long time. I think some of this white paint is house paint. Lol. It comes off easy. I’m trying to be gentle. The body is pretty rough on this old thing and has been all torch welded together so I have no plans to restore it. Just continue to improve I hope! IMG_6348.jpeg
  11. A nice survivor.
    Tow Truck Tom and Brian Berger like this.
  12. The37Kid
    The37Kid
    I like the "As Found" look, the world has plenty of shiny finished '32's.
    Bob
    Okie Pete and Brian Berger like this.
  13. Brian Berger
    Brian Berger
    Been a lot of work to swap this rear axle to the quick change. Split the body and frame today so I can swap the rear crossmemeber. It will be worth all the effort ! IMG_6358.jpeg IMG_6361.jpeg IMG_6359.jpeg IMG_6365.jpeg IMG_6366.jpeg IMG_6367.jpeg
  14. ratamahata
    ratamahata
    from Argentina
    Love the patina! Amazing Hot Rod...
  15. alchemy
    alchemy
    Tack lots of cross braces on the frame so it doesn’t get crooked and warped when you remove the 32 crossmember.
    34 5W Paul, Brian Berger and The37Kid like this.
  16. Brian Berger
    Brian Berger
    Got the Model A crossmember mod done and got the old quick change in. IMG_6532.jpeg IMG_6531.jpeg IMG_6535.jpeg IMG_6544.jpeg IMG_6546.jpeg IMG_6545.jpeg IMG_6547.jpeg IMG_6548.jpeg
  17. The37Kid
    The37Kid
  18. Okie Pete
    Okie Pete
    The new stance is going to look great
  19. The37Kid
    The37Kid
    Did they add new drain plugs when the center section got flipped?:cool:
  20. Hollywood-East
    Hollywood-East
    Kool fact...
    The white isn't 'paint' as we know it, It's called White Wash, Which back in the day was common, It was the byproduct of Acetylene generators, People had them in there ba*****t, An plumbed through house for lighting etc.
    Colt, as in the gun company made them also..
  21. Brian Berger
    Brian Berger
    I’m ***uming I’ll just use the quick change end to drain it. Pull the plate. Would have been nice to have a bottom drain
    Tow Truck Tom and Okie Pete like this.
  22. Brian Berger
    Brian Berger
    The stuff came off with just water. Lol. I gave it an SOS bath. I think it turned out killer IMG_6396.jpeg IMG_6397.jpeg IMG_6398.jpeg IMG_6402.jpeg IMG_6401.jpeg IMG_6403.jpeg
  23. ne'erdowell
    ne'erdowell
    Hi, I'm looking at the front end photo you posted, specifically the spring installation. Are you going to install a channel of some sort for the crossmember? In the photo it looks like the spring is connected to angle iron with no support for the for the front of the spring U-bolts.
  24. Hollywood-East
    Hollywood-East
    Damn, That looks Freak'n Awesome..
    Brian Berger likes this.
  25. Brian Berger
    Brian Berger
    That’s how it was done when car was built late 40’s. It’s got a big insert also that’s inside the frame rail you don’t see. It’s actually pretty strong. Car sat since 52. I drove it all summer that way. I may change it down the road.
  26. tubman
    tubman
    With a car like this, I believe the old saw "If it ain't broke, don't fix it" applies. Take a close look at it from time to time. Personally, I don't see much wrong with it.
  27. Brian Berger
    Brian Berger
    Got the dummy torque tube made. I’m re using the front portion but using a different tube for the rear part. This was the tube that came with the rear end. It’s super short and I’ll never be able to use it is why I cut it plus the front part is nicer IMG_6553.jpeg IMG_6552.jpeg IMG_6551.jpeg
  28. Outback
    Outback
    from NE Vic, Oz
    Looking good. How's the angle of the spring/shackles? A friend had issues with the angle of the rear spring vs the spring mounts in a similar application
  29. Brian Berger
    Brian Berger
    They’re level right now with no load. Hopefully it will be about right when loaded.
    Tow Truck Tom, Okie Pete and Outback like this.
  30. Outback
    Outback
    from NE Vic, Oz
    Oh & I must say what an awesome car & thanks for sharing it with us :D
