Technical redrilling 5 on 5.5 to 5 on 4.
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Feb 1, 2025.
  1. '52 F-3
    '52 F-3
    from Central PA
  2. RICH B
    RICH B
    How about the inner side of the hub?
    Hnstray and '52 F-3 like this.
  3. '52 F-3
    '52 F-3
    from Central PA
    It looks like it's going to be close.
  4. FrozenMerc
    FrozenMerc
    Getting the bolt pattern centered is the tricky part. Do you have a mill?
    '52 F-3 likes this.
  5. What the heck is 5 on 4 ?
  6. 1971BB427
    1971BB427
    from Oregon
    My thought also. What uses a bolt pattern that small?
    lothiandon1940 and '52 F-3 like this.
  7. lemondana
    lemondana
    from Lincoln NE
    Those are Mopar A Body wheels. They used the 5X4" from 1963 to 1972. Those small bolt pattern are pretty sought after. You would probably be wise to sell them and find what you want in the size and bolt pattern you need. That small bolt pattern used either 13" or 14" wheels, so they might not even clear big drums. What size are these wheels. The A Body Forum would be a good place to sell them. FORABODIESONLY.
  8. lemondana
    lemondana
    from Lincoln NE
    The Mopar A body is the 63-72 Valiant, 64-69 Barracuda, 63-72 Dodge Dart, and the 70-72 Plymouth Duster.
  9. Alton Stroope
    Alton Stroope
    Lemondana is 100 percent correct, great advice
  10. gimpyshotrods
    gimpyshotrods
    I do it in a manual mill, with a DRO and an electronic probe, all of the time.
    '52 F-3 likes this.
  11. lemondana
    lemondana
    from Lincoln NE
    If you redrill them and find they don't work for you, no Mopar guy will want them, rendering them useless. And it's very doubtful that they fit over disc brakes with the 5.5 pattern or the bigger drums that you probably have.
  12. lemondana
    lemondana
    from Lincoln NE
    And the center register is smaller than most other hubs.
  13. '52 F-3
    '52 F-3
    from Central PA
    Finding 15x4" slotted mags is getting harder, I've been looking for some time now. I've found 3 sets with 5 on 4" small Mopar pattern. (and some chevy patterns) but no 5 on 5 1/2"
    EDIT: not running any brakes, so clearance won't be an issue. (going on an Altered)
    anyway, I figure I have 3 options,
    1. Buy aftermarket hubs with correct bolt pattern.
    2. Re-drill hubs bolt pattern and decrease size of hub for wheel center. 3.125 to 3.00"
    3. Re-drill wheels bolt pattern and fill in existing holes.
    There is an area on back of wheels that will accept 5 on 5 1/2" holes, but will be very close to existing holes.
    I'm leaning towards re-drilling hubs and using screw-in 1/2 x 20 studs. (either double ended or Allen head) BUT, hubs don't have alot of material between bearing races either.
  14. 19Eddy30
    19Eddy30
    from VA
    With out seeing Hub , thats more likely
    What I would do , re-drill hub's.
    Or Slot wheel /Rim
    I remember in early 70s seeing oblong holes , I allways told Unilug / slots?
    Double studs , I would use a High grade studs instead of whats shown , ARP etc.
    On my Altered over 200 ,
    Spindle mounted ,
    '52 F-3 likes this.
  15. gary macdonald
    gary macdonald
    Make sore your center of hub will fit through the wheel . What I found ( too late ) is that the ford hub is too large for most aluminum rims that aren’t made for the larger pattern
    '52 F-3 likes this.
  16. '52 F-3
    '52 F-3
    from Central PA
    Printed 2 of these. After verifying no distortion happened during printing, I'll be glueing to hubs.
    note: this includes "5 on 4-inch pattern" which almost none of the bolt pattern templates do. 045f0bee8e4f2a7c579df9bdba46fe00ef8771c8.png
    turboroadster and COCONUTS like this.
  17. mohr hp
    mohr hp
    from Georgia
    I dunno. Can't just eyeball with a paper template. You might be close enough, but that's still a guess.
    '52 F-3, 1971BB427 and Mike Lawless like this.
  18. Mitchell Rish
    Mitchell Rish
    from Houston MS
    How much for you to print and mail me a couple of those. I have several of the wheel checkers /and paper /plastic disc but I’d like to have one or two of those. I’ve never seen one with the 5 on 4 either. Maybe I am not looking at what I have hanging on the wall but I like what I see that you did.
    '52 F-3 likes this.
  19. Mike Lawless
    Mike Lawless
    I wouldn't use a paper template to locate the holes either. Unless you don't care if the holes are off center or not precisely located.
    If you have a rotary table, find the rotating center of the hub, and move out 2" from there. Then rotate precisely 72° for the rest of the holes.
    Without a rotary table, if you have a lathe or some way to rotate the hub on it's center, scribe a 4" diameter circle, put a center punch mark for the first hole, then use a pair of dividers (comp***) to locate the rest.
  20. 1971BB427
    1971BB427
    from Oregon
    I'd never consider drilling holes with a paper pattern, especially for any vehicle going very fast. I'd want either a jig to perfectly locate holes, or do it with DRO to ensure perfection. Even a tiny bit off will cause big problems.
    '52 F-3 likes this.
  21. '52 F-3
    '52 F-3
    from Central PA
    I do have a Rotary Table on my Drill press that I will use, hopefully just like Mr. Lawless describes above. The template will be on there also. fyi, I have a little lathe I'll use to turn down hub on also.
  22. Jmountainjr
    Jmountainjr
    I am not a fan of the paper pattern idea. Probably easier to find a buddy, or buddy of your buddy, with a lathe. Turn out two slugs sized to correctly fit your inner and outter bearings. Center drill while mounted with the bearing mounting in the lathe chuck. Mount hub in lathe between centers using bearings the bearing adapters. Drive with a lathe dog. Carefully measure for the 2" offset and cut a marking groove. Then mount hub securely in a good drill press and drill.
    seb fontana, deathrowdave and '52 F-3 like this.
  23. RodStRace
    RodStRace
    I get the make it from what you have, but they are still making them.
    https://www.us-mags.com/us-mag-1pc-indy
    Since you are going from the smallest to the biggest, and they are rare, you might try contacting the Co. and see if they can do a pair without the holes or to your desired PCD.
    Worked at a shop that did this for another wheel seller. They had a jig and did them on a vertical mill to ensure no runout issues.
    lemondana and '52 F-3 like this.
  24. '52 F-3
    '52 F-3
    from Central PA
    Thats Very Impressive, I'll probably just remove bearing race and chuck inner ID of Hub
    I may be reading it incorrectly, but the narrowest 15" wheel with 5 on 5 1/2 pattern is 7" wide. I really wanted 3 1/2 wide, but settled for 15x4". I even considered narrowing a pair of wheels.
  25. X-cpe
    X-cpe
    I made my own drill guide to go from 5 on 5 1/2" to 5 on 4 1/2".
    Need a piece of aluminum or steel large enough to cover the larger diameter.
    Center punch it and scribe the two diameters.
    Every 72* around the circles mark the stud locations, offsetting the marks on one circle by 36* from the other.
    Drill out the existing bolt circle so the holes just fit over the studs.
    Drill 1/8" pilot holes in the desired bolt circle.
    Cut out the center to fit over the hub.
    Put the guide over the existing studs and bolt it down.
    Use an 1/8" bit to drill through the pilot holes in the guide to center he new holes.
    Take the guide off and drill away.
    Mine has run good to 75+MPH, although I think you may be going a shade faster.
  26. RodStRace
    RodStRace
    Yes, I did a quick look and your exact desire is not in the standard offerings. That's why I included this
    IF (big if) they are done here in small batches (each offset would be a different set up) and
    IF (big if) they have the ability to pull 2 off the machining line and skip the lug hole part OR drill them to a different PCD, and
    IF (big if) they are willing to do these extra steps for special customer order at a reasonable fee you might be able to get them as you want.
    Just offering another possible solution for you!:D Like I said, I get the 'got something close, let's make it work' ethos.
    '52 F-3 likes this.
  27. Joel W
    Joel W
    I am wondering if there is a machine shop/wheel service around Omaha that would do something similar, have a set of dragmaster rims that are 4.75" pattern and want 4.5". Watching what you come up with.
    '52 F-3 likes this.
  28. '52 F-3
    '52 F-3
    from Central PA
    Should have started with this?
    I like to repair and build things, and don't want to by new parts if I don't have too. I could buy new wheels (even custom drilled to my specifications) I could buy new shiny aluminum Hubs, maybe Willwood or something better. I could take what I have to a local machine shop and do it for me. I could buy a whole new front end. But this is what have chosen to use.
    I cleaned up face of turned down hub to fit wheel hub-centric nicely. I carefully glued template and shortly after noticed the 4" template holes are not offset from original pattern. So that ain't gonna work.
    I'm currently reading reply's and want to thank you guys alot. I'm liking the make a metal template idea. Funny thing, if I didn't have internet I wouldn't have looked for a pre-made template and possibly would be making my own.
  29. '52 F-3
    '52 F-3
    from Central PA
    I put back in lathe and used a razor blade to cut/mark a 4" circle, template looks pretty close.
    gary macdonald and swade41 like this.
  30. goldmountain
    goldmountain
    I think that if you want a skinny 5 on 4" wheel, try a space saver spare from an old Chevy Citation. Stupid offset' but you could probably modify that.
    '52 F-3 likes this.
