Looking for feedback. I'm building a 32 5-window, original body with a 4" chop. I need all my window hardware and asking for opinions on installing a manual rear "roll-up" window verses installing an electric power regulator, such as a SPW unit. Thanks in advance!
Wouldn't a manual window require quite a bit of contorting. Wasn't a big deal when younger, but these days I'd rather not.............
I can easily reach and adjust the back window in my '35 from the driver's seat. '32 is a little narrower so that should easy too. Guess if I was making it power I would use a Nu-Relics '35-'36 Fordor rear door regulator and gl*** channel. I think the dual arm regulator would work better than a stock single arm regulator or a center lift SPW unit.
It kind of depends on the rest of the car. If it's got a generator, all drum brakes etc. then manual. If it's got an alternator, disc brakes, fancy stereo etc. then electric.
My 3 window is manual , wouldn’t dare have it any other way . As far as adjusting when rolling down the road it can be done from the drivers seat . But , why ? It’s either open or closed weather for me . Power I guess you want to power the windshield also ? Just being a wise *** ! Build it what works best for you and enjoy it
I had the same thoughts on my 32 3w but took the lazy route and stayed manual as that's what I had, so less work! I'm happy I did! The window does wind very easily, thankfully! I can roll it down from the driving seat but need to reposition to roll it up. Might be a different scenario if it didn't roll easily! I think that might be the key to it! Chris
Manual — but I'd probably put way more thinking into it than it warrants to position the crank where it's easy to operate while driving, without resorting to electrics.
I have the manual which goes down easy but not easy to raise and being old makes it tough raising the window.
Mine is manual ,No package tray ,seat 1/2 inch from crank , relocated holes in tracks , not bad up & down , & 70 style cup holder that hangs on door
Perhaps you are correct. BUT, I can tell you that in the '50s-'60s I would have used electric if I had know about them. Ben
