Hot Rods 1934 Willys Sedan to Ute build
Discussion in 'The Hokey Ass Message Board' started by 32fenderless, Feb 2, 2025.
  1. 32fenderless
    32fenderless
    I’ve been on this forum for many years and have learned a lot of tricks and tips and gained a ton of knowledge. Build threads are a favourite of mine to visit here. I figured it was time I should start to contribute one of my own.
    My build will be fairly traditional in style of this forum but will not be traditional on the way people expect a Willys to be built. I have always built my cars with a nose down stance and this will not be any different.
    Onto the car, I purchased this sedan out of an estate auction in San Jose about 5 years ago. My high school friend and I made a bonsai trip from Iowa to pick it up. I feel like I bought the front clip and got the rest of the car for free. It’s a solid rust free South African car. And a plus of it being a 34, my favorite year and I like the hood sides the best. IMG_3349.jpeg IMG_3706.jpeg IMG_3705.jpeg
  2. 32fenderless
    32fenderless
    Never a 4 door fan I reached out to my buddy
    @BigJoeArt for a quick scetch which I felt would be the easiest and cheapest way to rid it of the extra doors a raise the coolness factor.
    IMG_4998.jpeg Now that I had something to work towards I started to make room for a small block. I widened the factory K member(in hindsight I should have just make a complete new one).
    I likE the looks of the factory firewall in these cars but the way they follow the rear hood seam would leave the last two cylinders covered so I pie cut it and pushed it back til it was vertical.
  3. BigJoeArt
    BigJoeArt
    glad to see you start a build thread on this!
  4. 1934coupe
    1934coupe
    I grew up with Willys from my earliest childhood. I bought this 36 sedan from a loft in Brooklyn NY. I know 4dr. sed. are not the ***iest but I built this one to travel. My wife and I put on 13,000 miles in 6 weeks driving all over the US coast to coast and north to south. 34's are my favorite also because of those side panels.
    Pat
  5. Pat, you should click full size image
    Li'l Willy 001.jpg 5706417-53d8f7388f1dc349fc30aea7e23afce1.jpg 5706420-d1aeb4b7a47439e03abee3fbe3c471b2.jpg
  6. 32fenderless
    32fenderless
    I started to brace the k member back in trying to tie the stock look of the original crossmember. I built some c channel boxing plates that tie into the k member go past the rear axle and rosette welded them in and later installed hot rivets
    I will be running ladder bars and quarter elliptical springs. At this time I took some time off to finish up an OT project that needed to be finished.
  7. 32fenderless
    32fenderless
    This past fall I was able to start back on the ch***is fab. I have finished up the rear suspension with the panhard bar, bump stops, and the rear shock mounts. I do need to determine axle width but will wait to get the body back so I can make sure I have the right backspace for the wheels I am building.
    I wanted the rear view of the car to be unobstructed as I don’t plan on running a rear bumper. When looking at the rear you can see the 9” housing and the ladder bars mounts-no shock mounts hanging down and no springs.
    rod1, swade41, 1971BB427 and 2 others like this.
  8. 32fenderless
    32fenderless
    For the front suspension I am sticking with the stock Willys axle and parallel springs. I bought a pair of Posie’s drop springs and sent the axle to Sid to have dropped.
    I had a friend of mine machine some bushings to press into my early Ford spindles to adapt to the Willys axle. He also made the kingpins for me as well. The Ford spindles and the Willys spindles share the same kingpin inclination. The Ford spindle uses a much larger kingpin and the ford kingpin is longer as well
    I located a set of 40-42 Willys wheels. They are 16” and have the same pattern as small Ford/Dodge. The Willys wheels are about 3 1/2 wide.
    I wanted a little wider wheel that that for the rear so I ordered a pair of wheel shells from Miller Tire.
    the wheel shell has an ID that was about 1/4 smaller than the ID of the Willys wheel. To correct this welded 1/8 strap to the inside of the Willys center. I had a coworker that had a lathe with a large enough swing that we could mount the wheel center on a Old Ford axle and turn it down so that I could install it into the new shells from Miller.
    I have yet to weld them as am waiting to get the housing length determined to make sure I have the offset correct. The last time I did that was on model a coupe back in 1992. I mounted the wheel center to my front hubs and with the wheel shell on I used a dial indicator to make sure everything was true and then welded up. The plan is to do the same this time around. I was able to locate a set of NOS Willys caps that I will be running.
    rod1, swade41, Tow Truck Tom and 5 others like this.
  9. deathrowdave
    deathrowdave
    from NKy
    Wow that is one big machine . Hate to see him turning with sleeves loose , scary stuff .
    Accidents happen mostly to I have done it for years . Be safe , great build
    Tow Truck Tom and chlsnk like this.
  10. alchemy
    alchemy
    Guys, the feed handles are not up near the spinny parts. I don’t think his sleeves are in danger.
    I really like that you are using original wheels with some mods on your Willys. Reminds me of Jerry Hagens’ 40 coupe from a couple decades ago. Subtle but powerful.
  11. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I get what you are saying .....just being safe and don't want the fella any injuries.
  12. BigJoeArt
    BigJoeArt
    Good stuff Jason. I forgot about the wider rear wheels.
  13. 1971BB427
    1971BB427
    from Oregon
    I'm not a sedan fan, and mid 30's Willys pickups are too tight in the cab. So your plan to make this an extended cab pickup I really like!
  14. 32fenderless
    32fenderless
    I appreciate the concern guys. This is not me running the lathe, but my coworker that owns it. He grew up on a farm and has been around machinery his whole life. I didn’t feel it was my place to tell him how to operate his equipment. I did mention to him that it looked like it could put a hurting on a guy pretty quickly and he said that yes you have to respect the machine.
    Tow Truck Tom and Algoma56 like this.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I also like the '34 side panels the best. Wish my '36 had them.
    Tow Truck Tom and 32fenderless like this.
  16. 32fenderless
    32fenderless
    Funny that Jerry started with this coupe that he bought in Des Moines, a 77k mile original car. And I thought I knew of all the central Iowa Willys
    Tow Truck Tom likes this.
  17. Corn Fed
    Corn Fed
    Knowing your other cars, I'm sure this one will be a knockout too.
  18. RMR&C
    RMR&C
    from NW Montana
    Cool build! Will be following.
    Love the one off or Phantom type builds!
  19. 32fenderless
    32fenderless
    ] I put the body back on and have been working on the steering. Can’t show pics of that here. With little to zero room between the frame and leaf springs I went with a side steer.
    I have also been working on the pedal ***embly. I purchased a c10 style master and pedal ***embly from Cory at RJays. I asked him not to bend the pedal ***embly as there isn’t much foot room in these cars.
    I wanted some detail around where the master bolted to the firewall. So I made a pattern about 1/4 larger than the mc flange and proceeded to cut my 3/16 plate with my trusty angle grinder and cleaned it up with a file,belt sander, grinders and a DA. I rolled the outside edge over and once I weld a patch in the firewall where I had to cut the bump out for the x brace for the radiator I will be able to weld the plate to the firewall. I can then brace the inside mount and then move onto mounting my steering column.
  20. BigJoeArt
    BigJoeArt
    good stuff, are you putting any more bracing behind the firewall?
  21. 32fenderless
    32fenderless
    I got the patch installed last weekend and the p***enger bump out cut out and new piece tacked in before the subzero temps hit.
    I am going to build an 1 1/4 hoop to install behind the firewall and I will attach the bracing for the pedal ***embly to that.
  22. 32fenderless
    32fenderless
    IMG_1674.jpeg IMG_1597.jpeg I’ve been bouncing around on this project. I pulled the radiator apart to prep it to send off to Br***works for a rework. I widened the lower support and side rails to fit the new wider core they will be using.
    I’ve also been working on the bracing at the cowl. I had an old co-worker/ friend that I worked with at the hot rod shop that has a tubing bender. We bent up an 1 1/4 hoop.
    I removed the dash to be able to install the hoop. This needed to be removed anyway so I could install the left hand drive dash. I am adding a stiffener to the bottom of the dash before I weld it back in. IMG_1676.jpeg
    I have the hoop welded to the subrails and a brace to the A pillar. I then built some tabs to attach to the hoop to the pedal ***embly.
    RMR&C, swade41 and Tow Truck Tom like this.
  23. alchemy
    alchemy
    Your car will probably have half as many rattles as a regular Willys, just because of that nice hoop.
  24. 32fenderless
    32fenderless
    I’m hoping it will help. When I get to the body conversion I’m going to run one behind the b pillar up about shoulder height and tie it in in front of the tires and again at the rear of the car. I’m hoping it helps. This car has a ton of flex in the ch***is. I’m going to build a top plate right behind the tail of the trans on the K member.
    I saw you halfway across the swap today but never saw you again. Pretty weak-but I don’t expect much from it. I did find a small base 2cg as a core for the 2x2 intake I’m going to build. Did you find any treasures?
  25. alchemy
    alchemy
    Tools and sanding belts. One vintage coil.
  26. Corn Fed
    Corn Fed
    I spent more on the waitress' tip for lunch at Jethro's than I did at the swap meet. But it was still a good time getting out and seeing friends.
    32fenderless and Tow Truck Tom like this.
  27. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    W0W, dig the vision. The transformation will be solid, as shown to date.
    You are 'growing' a better built car. I sometimes over look that Willys meant low price.
    Plus, You have paid attention, over the years, to following the J.Journal.
    Thanks
    32fenderless likes this.
  28. swade41
    swade41
    from Buffalo,NY
    Some good work going on
  29. 32fenderless
    32fenderless
    Thank you for the kind words. Sometimes I get in my own way when something doesn’t look 100%. There’s a lot of talent out there and it’s hard sometimes to not compare my work to others.
  30. neilswheels
    neilswheels
    from England
    Looking forward to more updates
