Hot Rods My new 57 Chevy 210bu
Discussion in 'The Hokey Ass Message Board' started by Xman, Feb 3, 2025.
  1. Xman
    Xman
    I have a 383 small block with a one-piece rear main seal on order. I will be mating it up to a stock bellhousing configuration. I need to order a flywheel and clutch and not sure what fits. I know I need a flywheel for a one-piece rear main seal but 168 or 153 tooth. And do I need a 10 1/2-inch clutch?
    It has been to many years since I have worked on a tri 5 and with the cost of these parts, I need to order the right stuff.
    Dan
  2. DDDenny
    What's a 210bu?
  3. Xman
    Xman
    JUST 210 TYPING MISTAKE,
    rod1 likes this.
  4. 427 sleeper
    427 sleeper
    168 tooth flywheel and 11" clutch fits the factory bellhousing.
  5. Budget36
    Budget36
    Are you going to post a pic of it?
    427 sleeper and rod1 like this.
  6. J. A. Miller
    J. A. Miller
    from Central NY
    Kind of like a Henway but different. :rolleyes:
  7. Squablow
    Squablow
    I'm the wrong guy to ask about flywheel tooth counts but I would also like to see the car.
  8. Chucky
    Chucky
    Verify internal or external balance requirements before ordering any flywheel. Maybe you already knew that…
    427 sleeper likes this.
  9. lumpy 63
    lumpy 63
    168 tooth , one piece rear seal engines use an external balance flywheel . Aftermarket flywheels are usually drilled for both 10 1/2 or 11 inch pressure plates
    Tickety Boo, 427 sleeper and Algoma56 like this.
  10. Xman
    Xman
    It had been restored just before I bought it and is totally rust free. I pulled the stock 283 and powerglide and will be installing a Blueprint 383 roller and M21 muncie 4 speed.
    The last 57 I had was about 1978, so I'm having fun doing it up right this time
    Dan
  11. Xman
    Xman
    also, has dropped spindles and front springs and 1-inch lowering blocks in rear. I added steel 15x7 front wheels and 15x8s in the rear and TA radials. And the beat goes on.
    guthriesmith likes this.
  12. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Looks like a nice car! :cool:
  13. 427 sleeper
    427 sleeper
    Just make sure you get ALL of the specific to '57 clutch linkage. '55&6 are close but off just enough to cause problems.
    Xman and Tickety Boo like this.
  14. Mr48chev
    Now, that's my style of 57 Chebby. And I might even get to see it one of these days when we cross paths.
  15. My that is pretty
  16. Mitchell Rish
    Mitchell Rish
    from Houston MS
