Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. jimmy six
    jimmy six
    The first one must be just to qualify. Then the average of the two runs needs to be so the driver/vehicle will be the new record holder after certification.
    Don’t know on the head. The one we used with Joe from 1996 thru 2004 was pretty wasted so he used one the new ones he cast up for the one he had in the Ferguson Streamliner. When we partnered up with him he told me the engine we’re using was the same one he used in the Studebaker in the 70-80’s. I don’t know which head George Campbell bought from Joe or when. George (rip) has been gone for quite along time now. I’m pretty sure each of the originals from Tom Skinner had a number stamped on them. Joes new ones do, at least mine does. So does my Arias/Howard.
    Dyno Dave, loudbang, D-Russ and 3 others like this.
  2. Stan Back
    Stan Back
    JD's right. First you gotta break the record, then back it up with an average that breaks the record.
    Dyno Dave, 51504bat, loudbang and 3 others like this.
  3. john mullen
    john mullen
    GMC Engine update
    This thing is finally coming together 20250204_154916.jpg 20250204_154955.jpg 20250204_154928.jpg
  4. john mullen
    john mullen
  5. john mullen
    john mullen
    Finishing up on the Crank Triger and Dry Sump Pump bracket today 20250209_150319.jpg 20250209_150324.jpg 20250209_150327.jpg 20250209_145558.jpg 20250209_145554.jpg
    jimmy six, 57 HEAP, loudbang and 5 others like this.
  6. D-Russ
    D-Russ
    You've seen the intake and carbs, right? Three 55 DCOEs on a sheet metal tunnel ram.
    neilswheels, Jeff34, Mr48chev and 5 others like this.
  7. john mullen
    john mullen
    Russell hose ends came today.i got started making up the return lines to the pump. Only got one done today 20250210_170949.jpg 20250210_150851.jpg 20250210_150849.jpg
  8. john mullen
    john mullen
    I started facbing the upper valve train oil
  9. john mullen
    john mullen
    I got the dry sump tank polished up today and installed the fittings for oil lines 20250217_110801.jpg
  10. john mullen
    john mullen
    I finished up on the top end oil system today. Now just need to flair the outer feed line and it will be completed 20250218_161000.jpg 20250218_161009.jpg 20250218_161002.jpg
  11. john mullen
    john mullen
    ****oned up the dry sump tank mounts today. Now I just need to take it apart and polish 20250227_163800.jpg up everything
  12. D-Russ
    D-Russ
    Where is the stamped number? Is there any kind of database of the numbers to trace a head's history?
  13. Rand Man
    Rand Man
    I need to scroll back a few pages to learn more about that head. Good thread.
  14. D-Russ
    D-Russ
    Finished up the valve cover and side cover so @john mullen can ****on up the motor. I originally has big plans for chrome, but no time for that. valve cover.png side cover.png gmc logo.png
  15. jimmy six
    jimmy six
    If your head was number/letter stamped you would have seen it by now. The ones I’ve seen were on the rocker cover rail at the back. The Inliners International tried to get a registry going but I don’t know how successful they were. It was for each manufacturer, the id # if it had one, and current owner. You could include history if you knew it. I have 2 but both are 2nd generation and I didn’t own them when the Club was doing it. I believe Pat Smith was heading it up.
    chryslerfan55, loudbang and D-Russ like this.
  16. D-Russ
    D-Russ
    Here's the number on my cylinder head.
    chryslerfan55, loudbang and saltflats like this.
  17. D-Russ
    D-Russ
    Header flange for the GMC is done. Those are 2 inch primaries.
  18. jimmy six
    jimmy six
    As I remember Joe had 003 and 007 but no number like that. Tom only made a short run maybe 15 and Joe did the same in the late 90’s or early 2000’s. I went to the foundry he used and saw them stacked up along with the core boxes. I believe there were 25-30 but many were s****ped as bad pours..
    I know at least 2 heads were stamped with owners drivers license numbers so they could identify them if stolen and it was successful in one instance in Utah.
    Are you going to split the exhaust flange?
    chryslerfan55 and D-Russ like this.
  19. AmishMike
    AmishMike
    Jimmy Six question on exhaust manifold: may be concerned steel expands differently then aluminum head & can break studs or bolts. Had same worry but your run time maybe short enough not to be a problem. Maybe, I hope.
  20. D-Russ
    D-Russ
    What material would you suggest for the header on an aluminum head? Stainless? Cast iron? Is there a gasket material that would adequately insulate the combination? I know folks run steel headers all the time on small blocks Chevys with aluminum heads.
    chryslerfan55, loudbang and Just Gary like this.
  21. D-Russ
    D-Russ
    We weren't planning to as there is a stud right in the middle of the two middle cylinders. Do you suggest splitting the flange?
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    How about 2 splits?
    12
    34
    56
    Just Gary and chryslerfan55 like this.
  23. D-Russ
    D-Russ
    I spoke to the boss and he agrees with you guys, so thanks for the input!
  24. john mullen
    john mullen
    Getting closer to fire up on the GMC,
    Should be finished in the next week or two. Just a few things left to do. front water outlet, plug wire looms, starter, flywheel, clutch ***y, prime the oil system, get it on the run stand. Can't wait to here this one come to life. 20250315_111851.jpg
  25. john mullen
    john mullen
    Fitting the intake to make supports that will help hold the intake steadying it from vibration.
    Coming along quickly now. Got the starter mounted as well. Still waiting on small parts and hardware pcs. 20250323_163141.jpg
  26. brett4christ
    brett4christ
    That looks STELLAR!!!!
    D-Russ likes this.
  27. Jeff34
    Jeff34
    WHOA! Show AND go! Beauty.
  28. jimmy six
    jimmy six
    I started by using gasket material from the power plant I worked in at first 1/6” Drabula and it was an off white. At the end Joe said no gasket and just red RTV. The headers were steel.
    Is your only oil filter the l from the one to the tank from the pump?
    If you choose to use a stick on heater on the tank make sure install insulation over it or 90% of the heat would be wasted. I used to make them for guys at EL Mirage and Bonneville when I worked and had access to all the materials and tools it really cut down on oil warm up time prior time to start up.
    Everything sure looks great and well thought out!
  29. D-Russ
    D-Russ
    Thanks, I've split the header flange into 3 pieces. We'll probably use red RTV as well.
    Currently the filter between the tank and pump is the only one. Do you suggest an additional filter?
    Regarding the heater and insulation on the oil tank - John and I haven't talked about this so not sure what his plans are.
    Thank you for all your input and advice JD!
