Bringing an F100 Back from the Dead
Discussion in 'Off Topic Hot Rods & Customs' started by Mike Lawless, Nov 1, 2021.
  1. pprather
    pprather
    Would an earlier version of the Ford distributor work?
    One with electronic ignition but mechanical advance, from early 1980's?
    Or somewhere in between.
    I can understand the difficulty of having an ignition module computer and the efi computer not holding hands nicely.
  2. I have exp. with tfi modules. Not knowing what you are using will make my input somewhat vague. The basis of my exp. has been that the original Motorcraft units are the best. I went through several of the newer units and couldn't find a good unit. If you take them to a tester where they connect to a unit and press a ****on to test, it has to be done many times to create some heat in the unit. The heat has a great deal to do with failure. If your unit isn't 100%, then you will not get the terminator to be effective. Holley sells a unit that is directly meant for the Ford with tfi so they should have adequate info to tell you where to look. It's been several years since I did this but by using only a couple of the outputs on the tfi, you have a stand lone ignition system connected to the coil but no timing control. If you reach the point of having enough of the tfi, you can use the dist, pickup to fire a cd box I believe such as a MSD or similar. I think the pickup is the same function as the older duraspark units. I'm using my not reliable memory for some of this so take it as such. The output that would go to the spout connector on an eec iv wiring is the one that controls timing through the ecu. If you haven't spent time on the Holley forums, I suggest you go and look around. There is some very knowledgeable people there. When you're learning new stuff, it takes time to absorb what is happening and then get an overview of where to go next. I don't know about you but age has made me think way more than I used to. :) If you're not satisfied, why would you quit???? :)
    Ragged Edge likes this.
  3. Mike Lawless
    Mike Lawless
    Thanks @wfo guy
    There is some very knowledgeable people on the Holley EFI FB groups, and I have been getting flooded with idears....mostly about how it make it more complicated, as well as help me spend more money.
    But, because of that, I have some things to try. It's funny you mentioned the aftermarket units vs the Motorcraft units. I bought a Cardone distributor for a 1990. As you can see, it has the module attached to the body of the distributor. The supplied module had cross fire, erratic timing....just wasn't working. My son, who set up the wiring harness and got 'er up and running said it was probably the module, and he picked up a genuine Motorcraft module. Fired right up and ran smooth. At first it showed no timing advance at all. A couple changes to the settings, and it was working normally. Or so it seemed. It was pinging in the low vacuum/high load zones, so we turned the timing down a bit. Later after turning the timing down in the ECU to the point it should have had no more than 25° did I discover that it was still seeing 40° actual timing. I filled the entire table to 12° and then checked actual timing. It should not have seen any advance at all. But yet it did! Idling at the 12° setting but getting to 30° or thereabouts total.
    So now, I have that same 12° table with just a little additional timing in the table in high vacuum/ low load areas. And it works. Now it sees about 35° in the "cruise" area. It runs nice. It seems the is either built advance in the TFI unit, or it's getting a timing input somewhere, somehow through the ECU. I have a another round of things to try before I either learn to live with the ECU just adding X amount of advance to that which is already there, or as you suggested, ditch the TFI module in favor of an external CD box. Whew!
    I think life was easier when I could either just twist the distributor this way or that, and change springs, weights, or advance slots to tailor the timing the old fashioned way!
    Okie Pete and Ragged Edge like this.
  4. Mike Lawless
    Mike Lawless
    It looks like the solution in the event that I can't live with the way it is, is to ditch the TFI module, and run an external CD box, using the distributors shutter wheel as a trigger. I'm hoping to solve this in the software so I don't have to tear into my son's exceptional wiring all nice and tidy), and of course avoid spending money unnecessarily!
    Okie Pete, Ragged Edge and pprather like this.
  5. At the risk of being stupid, is there something in the timing area of the software that specifies how many cylinders the engine has??? If it's of any help, on the oem app of the tfi, you disconnect the spout and set the base at however many degrees you want. 10-12??? When you reconnect the 3rd wire, the ecu takes over. I seem to remember around 20 degrees at idle but I may be way off. :)
    Another thought: does the timing chart not include your base timing so the base and the included would give you the amount observed but not desired????
  6. Mike Lawless
    Mike Lawless
    I brought up the spout wire to my son, who has a far far better understanding of than i do. But in the software, there is a set up box to enable static timing. I did that this morning, and at idle it was 12°, which is what I set static timing to. It had 12° at idle alright. But the timing still advances. Then there is a "crank sensor" value. Supposedly, the amount of the value there can either advance or retard timing. I tried a bunch of different values, and it still advances.
    So, that's all I can do. He's gonna research the spout wire connection and come over and change how it connects.
    I wish I had taken the time to learn this stuff years ago. My original plan was to keep this old school with a carb and conventional ignition. My son convinced me this would be the way to go. So, I'll let him figure it out, and maybe we can bith learn something.
    brEad, Okie Pete and Ragged Edge like this.
  7. Mike Lawless
    Mike Lawless
    On the timing table in the software, I got it to the point that it sorta behaves. I set the entire table to 12°. Logic dictates it should stayed at that value, but it does not.
    Seems like a matter of the left hand doesn't know what the right hand is doing.
    Some Holley experts say the the Terminator doesn't really support six cylinder TFI. Only V8.
    Okie Pete likes this.
  8. 6sally6
    6sally6
    Rip it out !! RIP it ALL out !! (you won't be the first ...or last to say "Gimme a carb and distributor with weights and sprangs and jets ...take all this modern junk and put it on your LS stuff !"):mad::mad::mad:
    You woulda been driving 'old Furd' 3 months ago
    6sally6
    Mike Lawless likes this.
  9. Mike Lawless
    Mike Lawless
    Lol. Let's not get carried away just yet. It runs and drives very nicely. It's just that the actual timing and what the ECU says it is, aren't the same.
    This EFI system has some very desirable qualities aside from that.
  10. I'm sure you have thought of this but you could put the old dist. back in and get the rest of it where it's got the right a/f and then reinstall it. Many times, one problem masks the other. :) I know you have plenty of exp. and you'll come up with an answer.
  11. Mike Lawless
    Mike Lawless
    A little update on the whole Holley Terminator vs. Ford TFI issue....
    It seems that the Holley ECU does not recognize the Ford TFI in 6 cylinder form. Apparently some sort of "handshake" is required, but one side, or maybe both, won't do that. So, no timing control.
    It runs pretty nice as is. But, (big hairy but) there's just too much advance in the high load/low vacuum areas one would encounter, such as hill climbing. The obvious solution would be to back the timing up. But then idle advance and around town, plus flat highway driving take the hit on efficiency.
    The solution, at least I hope, is a coil driver for a single coil, which would by-p*** the TFI module. A place called DIY AutoTune has this coil driver, actually made in the US.
    I can pretend I know what this is all about. But that would be just that. Pretending. My son, who does this stuff for a living has researched this, and will do the wiring an initial set-up. He says we WILL get timing control. Hopefully that is the case.
    Once we have control, I can tailor the timing events to drop timing out in the "Ping Zone" while keeping it where it likes to be in the other areas. That part is something I can do my own dang self.
    But, just in case, I was able to find a rebuilt single point distributor. I will put that in my "Road Trip Box" so in the unlikely event of a failure somewhere deep in BFE, I can get going again.
  12. Mike Lawless
    Mike Lawless
    Finally a solution on the whole Holley EFI/Ford TFI episode! My son came up with, and found the single channel coil driver module. He came by last weekend and wired it into the system. The kid (42yo) really knows his stuff! Very little intrusion into the existing wiring harness, and it looks as neat and tidy as it did before. The existing TFI module on the side of the distributor is still there and acts only as a convenience connector to the pick-up module inside the distributor.
    After getting it wired up, the Ol' Furd fired right up, and we went through a few steps to get the actual timing sync'd with the ECU. I now have timing control!
    Took 'er out for a ride in the Sierra foothills the other day, and put 'er through different scenarios, with wifey writing down info the old fashion way. I coulda done a datalog, but this way was easier for this old coot.
    The most heinous test was lugging 'er up a 12% grade at 45mph in 4th gear. She didn't like that much and there was just barely audible pinging, 1500 rpm, 27° timing and 95Kpa manifold pressure. That is akin to about 2 or 3 inches of vacuum. I certainly won't intentionally do that again, but it is comforting to know the limits anyway!
    That wraps that project up, except for fine tuning. So, bring on some road trips! AMPmodule.jpg
    brEad, Okie Pete, Ragged Edge and 5 others like this.
  13. So do I have this correct: The dist. pickup sends the signal to the Amp in ****og form which sends it to the ecu which sends it to the coil at the correct time?
  14. Mike Lawless
    Mike Lawless
    The distributor pickup goes to the ecu, the spark out wire goes to the Amp, which fires the coil. Petty simple. The box is small. About 4 x 1.5 inches 20250207_175332.jpg
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Kudos Mikey.
    By Golly, you said you and your son were going to get to the botttom of your spark control issues and you did.
  16. Mike Lawless
    Mike Lawless
    Thanks!
    It was due to my son's efforts that this got sorted. He has much more EFI experience than I. But along that same line, it was he that steered me down this crooked and winding road too. Had there not been supply chain issues during covid, the Ol Furd would have been carb'd.
    Thanks to all that had comments and suggestions. It's always great bouncing ideas off others.
    Let the road tripping begin!
  17. Mike Lawless
    Mike Lawless
    20250216_140205.jpg Yesterday, I took Ol'Furd for the 240 mile round trip to Famoso Raceway where my son was running our Karmann Ghia. He did pretty good, reaching the semi-finals, and running great his quickest 1/8th mile run to date. 6.35 at 108mph. That factors out to about 9.90 to 9.96 in the quarter.
    Ol' Furd did pretty good too. No hitches at all and knocking down 20mpg.
    Left the house before sunrise, and got back well after sunset.
    Seems the most efficient cruising speed is around 62-63 mph. Perfect for the backroads! But it'll still do 70 easily for interstates. Pushes a lot of air, so I'd lose a couple mpgs doing so.
    They even had a car show in Famoso Grove, so I parked 'er there. I was informed that I won! Even with the "large number of entries" (See photo for how many cars were in the car show).
    Nice sunrise shot out the front window about Midway to the track! 20250216_065027.jpg
  18. To not take advantage of today's tech in a daily driver isn't for me or I suspect you either. You could have had a carb and wondered how different it could be with efi. :) I was at bakersfield in the mid 90's and all of those trees in your pic were just planted. It was a barren place back then. While I was there, the Dago Red backup P51 buzzed the strip. That was my 1st up close exp. to the Doppler effect. I was impressed. Enough off topic. That Karmann is quick. Which engine is in it?
  19. Mike Lawless
    Mike Lawless
    That Dago Red plane is very cool!
    I've been coming out to Famoso since the early 70s, and made my first runs there in 1975. Yeah, in those days, the grove didn't even exist, and the restrooms were a couple of shipping containers, with a plank to sit on with holes cut into it. No dividers between holes, so you got to know your neighbor!
    Nowadays it's the premier track on the west coast. They've done a lot of improvements under the current ownership.
    The Ghia motor is 2332cc, with CB Compe***ion Eliminator heads, 48mm intakes and 40mm exhaust. The big feature is mechanical injection on methanol, with a T3/T4 hybrid turbo with TurboSmart waste gate and blow off. The intake is my own manufacture, as is the rear suspension.
    It runs through a Type2 bus trans that has been heavily modified with a custom gearstack and ring & pinion. It's a tough trans.
    The car is technically street legal, although not practical. I have driven it to a couple local car shows, and it gets about 1 mile per gallon of methanol!
    It has made nearly 500hp, but it will start lifting the heads at that power level. The crankcase really flexes there. My son had the boost at 18psi, at which point it makes about 420. It'll live at that. We keep it to about 12-14psi for the most part, running in a 10.60 (1/4mile) index, or 6.70 in the 1/8th. This weekend it was a 6.50 index.
    This photo was about 10 years ago when I still drove it. My son is standing behind, arms folded with tan shorts. I handed it off to him a few years back, and he continues to refine it. WKRatIrwindale.jpg
    brEad, Okie Pete, 41 GMC K-18 and 6 others like this.
  20. Are Autocraft cases not an option or even available anymore?
  21. Mike Lawless
    Mike Lawless
    They are...i think.
    We are using a CB Performance case. It holds up fine under 400hp. Beyond that the four head studs start to complain as well as the main studs. The Autocraft case can be fitted with six studs per hole and cross bolted mains.
    It is a chunk of change and make other big money changes necessary.
    If we keep the performance level to the mid 10 second zone, it lives for three or four seasons before needing service, and doesn't break stuff. To run quicker than 10 seconds flat also requires a whole bunch of other big money changes. All to satisfy NHRA safety requirements.
    But every now and then we can release the beast and let 'er eat!
  22. Greg Rogers
    Greg Rogers
    Mike, what rear end ratio in your F100? Do you have a O/D? I am curious as my 56 F100 w 300 YF Carb has a 3.92 with a M5r2 O/D works out to about a 3.20 effective rear ratio. Sounds like you got your FI/ Ign system all dialed in, 20 MPG is pretty impressive!
    warhorseracing likes this.
  23. Mike Lawless
    Mike Lawless
    Hey Greg
    The end goal with this project was to able to road trip it without breaking the bank. A rig that gets 10mpg on the road would be intolerable. At my age the definition of street performance to go the farthest possible, within reason, with the fuel. Along with a 22 gallon tank, this gives a range of over 400 miles. And the farther I can get between fuel stops, the better I like it!
    The rear end is a 3.54 Dana 60, with a 0.63 OD in the Tremec T5. That works out to a final drive of 2.23, and with 30.5" tall rear tires. I honestly think it would be better on fuel if the final drive ratio was 2.75 to 3.00. The manifold vacuum (pressure) is around 60-65Kpa at 65 mph. Currently at 65mph, it's turning 1650rpm. I think it would like it better if it was about 2000rpm. manifold pressure would likely be closer to 50-55Kpa. Idle is 32Kpa or close to 20-22 inches. Atmosphere is normally 100Kpa as a reference.
    I reckon I could always put shorter tires on it, and I may do that once these rot off....if I'm able At the rate I'm putting miles on this truck, it'll take more than 10 years to wear 'em out.
  24. 6sally6
    6sally6
    I was at Famoso this summer (a bucket list item) We were at a "M-word" get together with some fellas from all over the US. I flew from SC...not drive ! (First trip to So Cal too)
    You are right... Famoso is a really nice strip....wish I coulda caught the Bakersfield Smokers !
    That is a "healthy" V-dub fer sure. Did you do a build thread on it ?!
    Nice !
    6sally6
  25. Mike Lawless
    Mike Lawless
    Thanks!
    I did do a build thread on it....25 years ago on a forum that no longer exists. It has always been a work in progress. From 13 second street car in 1999, to what it is now.
    In the VW world, it's pretty well known. It had a feature in two VW magazines, and a HotVWs magazine cover car.
    Also, it has the distinction of being the only VW to win at the Bakersfield March Meet. Ever.
  26. Mike Lawless
    Mike Lawless
    Road trip time coming up quick!
    I have a 2500 mile route from Fresno/Clovis coming up very soon. It'll be south on 99 to Delano, then cut east on 155/178 past Lake Isabella to get to 395. Then it's north along 395 into Washington. Take Highway 12 east to Missoula to stay with my sister in law for a couple days, then on to Yellowstone, Grand Tetons and then return. We will try to keep this all on backroads and minor highways, only using the interstates when there's no other way.
    And yes, of course I'm a bit apprehensive. She's a 60 year old truck. But everything, and I mean everything has been gone through. There is nothing "unfresh." But of course, parts quality today isn't what it used to was. I'm putting together a "trouble tub" with tools and parts for common roadside maladies.
    The Ol' Furd is running really nice. I've been making refinements to the EFI tune and there's only one thing that is a bit of a bother but easily fixed. The coolant temp sender location.
    In stock form, it's on the p***enger side of the block at the rear, about three inches below the deck surface. No ther place to put it as is. No port in the head.
    When driving in cooler temps, particularly at freeway speeds, the coolant temp reads low due to cooled liquid being pumped in from the bottom of the radiator. Even though I have a 180° T-stat....and I've tried several, taking the temp from that location gives a misleadingly cooler reading. No problem except that the EFI uses coolant temp to hit the proper AFR. Below 140° and it is still into cold enrichment. Even a little below 160° it still sees a little.
    Soooooo.... I picked up a cast iron t-stat housing that has a threaded bung for the outbound heater hose. It has kind of an angled tee for a coolant temp sender. It was used for a temp actuated vacuum tee. But I can put my EFI coolant temp sender there to get the coolant temp right at the outlet of the head to the upper rad hose. I just need to make up a 30" extension for the electrical connector.
    Y'see, about a month and a half ago, I drove 'er down to Famoso raceway, 100 miles from my house. It was a cool morning and the temp sensor was reading about 140° all the way. As a result, my fuel mileage suffered a bit. I got 18.5mpg for the trip there and back. I know the Ol' Furd can do better.
    I've had the radiator partially blocked with a plexigl*** sheet after that. That has been a good short term solution. But that won't fly later on in the spring when conditions can range from cold to hot. Plus hill climbing.
    So perhaps I'll post progress reports and photos and we go along our way, stopping frequently at points of interest. We will be in no rush, no schedule, no set in stone route and no reservations.
  27. I had to relocate a temp sensor once also. I'm not concerned about you or the truck. Your wife might have a different view point of the trip once completed. :)
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Safe travels. Enjoy the journey.
    What if you hooked up some kind of localized heater (electric?, exhaust heat?) that you could turn on manually when/if you wanted to operate in a warmer region of the fuel map?
  29. AmishMike
    AmishMike
    Cut top radiator hose, insert short piece tube with welded in bung for temp sensor. Will always see hot water
  30. gene-koning
    gene-koning
    Concerning your temp sensor for the EFI, can you add an extension with a sensor bung into the heater hose, just off the thermostat housing? Then install the EFI temp sensor into the heater hose bung? Generally, the temp sensors for EFI do not go very deep into the coolant to function correctly, and they are usually pretty small sensors. Even if the coolant flow through the heater is stopped during the summer, its close proximity to the t stat housing should work well for the EFI sensor.
    My 49 Dodge pickup gets just under 20 mpg on the highway @ 70 mph (on cruise control), increase the speed and the mpg drops. It has an EFI V8, auto OD trans, and 3:55 gears, with 235 75 R 15 tires (2200 rpm according to the instrument cluster tach), but it is also a 4x4 (adds 950 lbs & a diff & transfer case to turn). I believe the rather poor aerodynamics of the old truck body (and my 4x4) is the cause of my under 20 mpg.
    We (my wife and I together) do an average of 8,000 miles a year in the 49 pickup, the fun factor overrides the need for a few more MPG. We fill the tank when we get near a specific miles per tank, when we are on the road (we use a 180- 200 mile mark on the highway). She uses her "gas buddy" app to find the best price when we start getting close to the 180 mile mark (or 3 hours driving time, keeps the wife happy to get out of the truck a few minutes). Gas prices can very a lot over a 5-10 mile space on the road. A 10 cents difference per gallon (I've seen 20 cents or more differences in a 10 mile driving distance) on the direct path you using, can have more effect on the cost of the trip then 2-3 mpg can have.
    I did need to add a few creature comforts (a cup holder and easily for her to reach 3" x 5" holding tray for her phone or whatever are biggies a**** them) to have a happy wife joining me in our travels. Our 49 Dodge pickup. 100_1148.JPG
    brEad, Thor1, '28phonebooth and 2 others like this.
