I donno about all being the same 52" is whats in the 38 coupe in my garage I think the later rears would be wider
Since this board has been going on for a while now, you can find answer to most questions of this kind. DO A SEARCH like this for instance http://www.jalopyjournal.com/forum/showthread.php?t=55439 Paul
I picked this off either here or the MSN V-8 site. Model thru '34 = 57" measured at wheel mounting surface of the drum. '35 thru '41 = 59.25" measured the same way. '42 thru '48 = 61".
Thanks guys, i got a banjo in my 36 ford pickup but its not home yet. So is the 36' rear worth using if its behind a 303 olds, will it holdup?
