Art & Inspiration Just Louvers////////
Discussion in 'The Hokey Ass Message Board' started by Stogy, Aug 1, 2016.
  1. Sky Six
    Sky Six
    from Arizona
  2. 69fury
    69fury
    from Topeka
    That's pretty slick. I've never had louvers in the plan for my build, but now i'm looking for a reason to do those...
    -rick
    Stogy likes this.
  3. Sky Six
    Sky Six
    from Arizona
  4. Sky Six
    Sky Six
    from Arizona
  5. Sky Six
    Sky Six
    from Arizona
  6. Sky Six
    Sky Six
    from Arizona
  7. Sky Six
    Sky Six
    from Arizona
  8. Stogy
    Stogy
  9. Stogy
    Stogy
  10. Stogy
    Stogy
    https://www.jalopyjournal.com/forum...s-on-a-plastic-trunk-lid.312877/#post-3340030
    :rolleyes:...Many of you may remember the Late Hamber @langy, he was a high bar Hotrodder/Fabricator from across the pond...snooping around I came across this in a Thread on louvers on gl***...he did work in gl*** perhaps due to costs and availability of real steel but he was a force...another fave of his was stainless steel...
    Hope you get some go fast in up there Hamber...
    RIP Langy
    rod1, wcben, dana barlow and 6 others like this.
  11. Sky Six
    Sky Six
    from Arizona
  12. Sky Six
    Sky Six
    from Arizona
  13. Sky Six
    Sky Six
    from Arizona
  14. Sky Six
    Sky Six
    from Arizona
  15. Tricky car right here. Rear fenders are widened, and skirted, front fenders are skirted, suicide doors with hinges and handles, door tops rolled into dash like a 36 Ford, 36 Ford dash, rear rolled pan with exhaust cutouts, frenched taillights and license plate, I'm sure there's more. Great car.
    Stogy and Sky Six like this.
  16. oliver westlund
    oliver westlund
    Just finished making my hand punch and getting it dialed in today, by the last 4 louvers I was rollin! 20250219_093420.jpg 20250219_103343.jpg 20250219_114028.jpg 20250219_121137.jpg 20250219_164245.jpg 20250219_175822.jpg 20250220_101106.jpg
    Ended up adding a guide after seeing how hard it was to locate and be consistent. Also used strips of rubber to prevent tearing.
    20250220_103603.jpg 20250220_103606.jpg 20250220_103726.jpg 20250220_115506.jpg 20250220_115511.jpg 20250220_115642.jpg
  17. AmishMike
    AmishMike
    So to understand how your punch louvers: you measure, mark where, cut a slit in metal, insert base with guide through slit, then punch down on other side. Correct?? They look good.
    Stogy and oliver westlund like this.
  18. oliver westlund
    oliver westlund
    Exactly. It is a little more work but its also kind of nice to be able to do my layout on top of the hood first to see where they should go. Plus its how they did it back in the day, at least some of em
    wcben, Stogy and AmishMike like this.
  19. The37Kid
    The37Kid
    Do you know what this hood was on originally? Louvers look good. [​IMG]
    wcben, oliver westlund and Stogy like this.
  20. Stogy
    Stogy
    @oliver westlund, hammer pounded or top die is in a hand or hydraulic press?
    There are a few tech articles in the archives on these more primitive but effective Louver Dies. They sure do work but hand hammered must rattle the ears, so muffs or plugs are well warranted.
    Nice work Hamber...
  21. oliver westlund
    oliver westlund
    Top die is in my hand and Im hitting it with a 3 lb mini sledge, only about 3 whacks to seat it and because I put rubber in the bottom of the female side, its not terrible on the ears. Once I added the guide it got a lot faster and easier. Thanks for the kind words!
    wcben and Stogy like this.
  22. oliver westlund
    oliver westlund
    No
    Not positive but I believe we figured this one to be REO, it has been cut down a bit to fit my roadster but then my engine ended up being M***IVE so it really doesnt fit. May end up reusing the sides on my model a roadster when I get there, they are really neat looking!
    Stogy likes this.
  23. Sky Six
    Sky Six
    from Arizona
    At local cruise night last night.
    20250221_175105_resized.jpg 20250221_175113_resized.jpg 20250221_175152_resized.jpg 20250221_182609_resized.jpg
  24. Sky Six
    Sky Six
    from Arizona
  25. Stogy
    Stogy
  26. Sky Six
    Sky Six
    from Arizona
  27. oliver westlund
    oliver westlund
    Heres a video of that loyver punch in action for those interested in it!
  28. Jalopy Joker
    Jalopy Joker
  29. Sky Six
    Sky Six
    from Arizona
  30. Sky Six
    Sky Six
    from Arizona
