Hot Rods NEW ILL-ADVISED RPU MODEL T PROJECT
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Feb 6, 2025.
  1. ALLDONE
    ALLDONE
    I've got a 26 rpu stocker... and a restored model A ch***is... the scope of work is to put the T- RPU on the A ch***is... GOW job type build....My idea is to stay kinda period correct. what I wanna do is Z the frame front and back... and probley go with a 36 front axel...I want the frame under the body, but want the body lowered.... I don't mind the tunnel as I have a set of WW2 bomber seats that I can't give away, also have a set of green wire wheels, same ,. can't give the away... the ch***is is all restored, with the A banger.. new trans clutch and such... can't give that way either... so my idea, put all the junk on one rolling ch***is , paint the body army/air force satin green... put the bright green wires.... Z the frame to get it low... bob the bed... and have a looks goods banger model a powered model T RPU...
  2. alanp561
    alanp561
    Sounds like you've got it all figured out, except the army/air force green:eek:. I believe the color you're referring to is Olive Drab. My Dad's first car after he got out of the Army was a surplus Chevy staff car painted that color. My Dad referred to that car as "Old Gangrene".
  3. ALLDONE
    ALLDONE
    there's army ranger green and air force forest green.... what ever looks best with my ugly *** wires that are green...
    LCGarage, chryslerfan55 and Outback like this.
  4. ALLDONE
    ALLDONE
    might have to go to home depot to get some green paint chips to see...
  5. alanp561
    alanp561
  6. ALLDONE
    ALLDONE
    got no idea why those wheels were powder coated that color green, migh look good w/ satin black???? or???
    alanp561 likes this.
  7. ALLDONE
    ALLDONE
    as always... red looks good..
  8. ALLDONE
    ALLDONE
    what color would go with the green wheels....
  9. ALLDONE
    ALLDONE
  10. Dave G in Gansevoort
    from Upstate NY
    No idea. I’m colorblind… blue green to be specific. I like red and black. I see them just fine…
  11. spudshaft
    spudshaft
    similar here. All the green stuff looks brown.
  12. pprather
    pprather
    What period are we talking about? Putting a Z in the frame is from the 1990's or later. I don't remember it back in the pre-mid 1960's.
    chryslerfan55, clem and ALLDONE like this.
  13. In the late '90s when the retro theme was first starting to take off I remember seeing a lot of green, blue and red wire wheels at the big shows here on the west coast.
    It seemed like it was always a Track T style roadster or maybe a Model A roadster.
    I don't know if green wheels are necessarily my color but I've definitely seen worse.
    chryslerfan55, Outback and ALLDONE like this.
  14. ALLDONE
    ALLDONE
    my dad said him and winfield Z'd his 36 ford....and put a carson top on it...he used to tell me about cops in modesto checking your cars windshield and scrub line with a pack of cigs... and that they used to run dual straight pipes, when they got wrote up they had holes drilled in the pipe and would steel wool in the pipe and drop a sixteen penny nail to hold it... get the ticket signed off and pull the nail...
  15. ALLDONE
    ALLDONE
    I'm not getting warm and fuzzy about them either, I 've got a bunch of other wheels... don't know what else to do with them... could mount them on the wall for garden /air hoses...
    chryslerfan55 and Moondog13 like this.
  16. ALLDONE
    ALLDONE
    I am thinking they look best with satin black...
  17. ALLDONE
    ALLDONE
    so I got the body out of the trailer,... milked that job long as i could IMG_4439.jpg IMG_4529.jpg IMG_4578.jpg IMG_4579.jpg IMG_4580.jpg IMG_4581.jpg
  18. ALLDONE
    ALLDONE
    gotta say,... this is the nicest roadster body I've ever seen.... un touched... look at the doors the way they fit... not a spec of rust through...and so far not one dent...
  19. ALLDONE
    ALLDONE
    it's going on a restored Model A ch***is...
  20. snoc653
    snoc653
    from Iowa
    You learn the darnedest things on the internet. I was in the Army just shy of 30 years and never heard of Olive Drab called Army Green. The vehicles were OD green, Desert Tan, or some variant of Camouflaged green black and brown or tans and browns. And the Air Force tactical vehicles were the same colors. Ours just got out to the field more often. What time frame does Army and Air Force Green come from?
  21. gene-koning
    gene-koning
    Those bright green powder coated wheels can easily be painted any color you choose. The scuffed up powder coat makes a great spray bomb, or sprayed paint base. At least, that was what I read here on the HAMB.
    chryslerfan55 and vtx1800 like this.
  22. ALLDONE
    ALLDONE
    I got a yard full of wheels, that need paint, and some that don't...
  23. The wheels are fine It's just the color is a little to in your face In my opinion. The plus side is powder coating is an excellent base coat for a different color paint. Just lightly break the surface with some 320 grit sandpaper and then spray away either using a urethane or an aerosol.
    chryslerfan55 and Squablow like this.
  24. I never had any military experience outside of vintage military vehicles but I always liked The Air Force "strata blue" color, ODG That you would see on many Marine corps vehicles also doesn't look too bad when it's new and fresh, The colors I struggle with is "Al-Qaeda" AKA "sandbox" tan or camouflage from any era.
    Here is a 1952 to 1971 M38A1 like a CJ5 Jeep but more robust) painted up in it's original Air Force blue It's not my Jeep I just stole the picture off the internet.
  25. ALLDONE
    ALLDONE
    so my idea is step the frame behind the cab... run the sub floor to the step. and make it level for the bed to sit on,... and yes shorten the box..
    LCGarage, Okie Pete and Outback like this.
  26. ALLDONE
    ALLDONE
    seems there's a lot more sheep then herders on this site.... I was hoping for some.... if this pile of parts was mine here's what I'd do post's...T's and A's are pretty much played out...Jimmy has to do his like Johnny or no rain deer games..
    don't really wanna do another RPU,,, I think this is #8
  27. Your first post you seem like you had it all figured out You want to build a banger hot rod.
    They are fun and relatively cheap to do.
    Build it the way you want it I wouldn't worry about any of our opinions. Myself I'm not a hater I'm all about driving your old cars and I'm really big into build your own hot rods and customs from all eras and as long as you are doing that I'm not going to complain.
    I am doing the same thing but I don't have a nice Model T body instead I got A Hupmobile Model R (1918 ish) and a Model A wide bed along with a 30-31 Model A truck (painted) grill shell, some scaly 1935 Ford wires and a model A frame and a dropped axle.
    This was it rough marked up about a week ago It needs to go way lower, I don't have any intention on a Z'ed frame but it I would like it to get a lot closer to mother Earth. 0131251732.jpg
    LCGarage, Okie Pete and chryslerfan55 like this.
  28. ALLDONE
    ALLDONE
    is that a 4'' drop??? wires look like 19's or 18's... I have 10 or 15--- 16'' wires...some nice some scaly...yours will come down a good amount dressed out...back in the day i use to stack rock salt bags in the car to see how far... yours will be cool when done, and fun build...
  29. ALLDONE
    ALLDONE
    I don't have anything figured out...just try'n to see all the options... I hate when your all done and people say,... you should have***** -----... try'n to hear all that before ...
  30. ALLDONE
    ALLDONE
    one thing that keeps my wife more on the happy side is piece of fake gr***, or an old area rug under the car... then I can pressure wash every thing and it traps the dirt and grease... she says it get tracked into the house and the yard
