Technical Polishing burnt hubcaps???
Discussion in 'The Hokey Ass Message Board' started by Kumquat, Jan 29, 2025.
  1. Kumquat
    Kumquat
    Hi
    I’ve got a set of stainless steel hubcaps that were removed from a burnt car. Apparently the fire was so hot the metal emblems melted off them.
    What’s the best way to make them a little more presentable?
    Cleaners/ advice/ methods appreciated
    Thanks
  2. Clydesdale
    Clydesdale
    Various increasing grades of sand paper, then increasing grades of polishing soap/mops will get them back.
    Its only metal after all.
    Check they aren't too distorted first though and still fit the desired wheel.
    Kumquat and arse_sidewards like this.
  3. twenty8
    twenty8
    Vinegar and Baking Soda......and rub, rub, rub.
    Kumquat and flatheadpete like this.
  4. Are they blueed or are they charcoaled?
    Kumquat and SS327 like this.
  5. Happydaze
    Happydaze
    Polished stainless that has been subjected to welding takes on a variety of hues. I've found that this polishes off easily with final stage buffing compound, so no need for grinding, sanding etc. I'm not sure about the difference, if any, between being hear affected and burned. It could well be a matter of degrees for all I know.
    Chris
    Kumquat likes this.
  6. Clydesdale
    Clydesdale
    kinda impossible to advise without pictures of their condition tbh
  7. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    You don't know it yet - but you may have just started the next "hottest" look.....Burnt Bluish Stainless.
    Seriously.
  8. ....Hmmmmmm.
    Kumquat and Spooky like this.
  9. downlojoe33
    downlojoe33
    It’s just the process involved to get the metal to that burnt bluish state that could be the problem.
    oldsmobum, Kumquat and lothiandon1940 like this.
  10. nrgwizard
    nrgwizard
    from Minn. uSA
    :D :D :D .
    OK... ;D .
    I would try a good metal polish 1st, before course rubbing compound, & sandpaper/grinding. Think of blued headers.
    Marcus...
    Kumquat likes this.
  11. quickchangeV8
    quickchangeV8
    A buffing wheel with blue or white compound on it will make quick work of those stainless hubcaps. I have restored stainless headlights before that were in a fire and they came out looking like new. No need for any sanding just buff thoroughly and all that black or blueish color will disappear. Don't forget that heat rises and if those hubcaps were on the car when the fire took place, the hubcaps would be closer to the ground away from the intense heat and they may turn out just fine.
    Kumquat likes this.
  12. twenty8
    twenty8
    Harley guys been doin' it on their 'zorst for years.....
    Kumquat likes this.
  13. Pontmerc
    Pontmerc
    from Finland
    Friend has very good looking 1/2 breaker bar with gold and blue tones.
    Many have asket is it expensive to get and he answers yes, you have to burn your old carage.
    NoSurf, leon bee, SS327 and 1 other person like this.
  14. tim troutman
    tim troutman
    a lot of 50's caps & trim are flash chromed over the stainless you have to sand it off to metal finish
    Kumquat likes this.
  15. Kumquat
    Kumquat
    Thanks everyone for the replies. I will try the easiest method first and work my way up to the most labor intensive method.
    Here’s a picture of one of the hubcaps.
  16. SS327
    SS327
    Mid 70s Eldorado hubcaps. Pretty easy to find.
  17. Kumquat
    Kumquat
    Yeah I know, but I like a challenge lol
    SS327 likes this.
  18. Kumquat
    Kumquat
    Any recommendations on the metal polish?
  19. Kumquat
    Kumquat
    Care to elaborate? Thanks!
  20. Kumquat
    Kumquat
    Picture added. Let me know your thoughts.
  21. Kumquat
    Kumquat
    Mostly blueed
  22. Torana68
    Torana68
    from Australia
    I wouldn’t do it by hand, buffing wheel and compound.
  23. I am going to have to agree with white buffing compound would probably be the best approach after a thorough cleaning.
    I had some Model A headlight buckets that made your hubcaps look good and they came out to a pretty nice shine without too much fuss.
  24. As far as the blue is concerned..... Try an acid bath (use about 1/4 cup citric acid per gallon) with a baking soda rinse. The blue should disappear, saving a lot of polishing work.
    Good luck!
  25. nrgwizard
    nrgwizard
    from Minn. uSA
    Sorta lost this thread, if any interest, I ran across an old polisher, who had some good product.
    He concocted it for his own use, & eventually offered it up due to demand. Rarely does car shows. I got lucky. I like the polish enough I bought it. FWIW.
    Michiana Metal Polish
    574/340-1868
    Marcus...
