Technical 50’s dash compass
Discussion in 'The Hokey Ass Message Board' started by 1930artdeco, Feb 7, 2025.
  1. 1930artdeco
    1930artdeco
    from Lynden, Wa
    So while on vacation I ran across this 1950’s dash compass. I took a chance on it as it looks like some of the water leaked out. Does anyone know if there is a way to top it off or refill it?
    thanks,
    Mike
  2. BJR
    BJR
    I believe that they were filled with alcohol or very thin oil. Otherwise it would freeze.
  3. Ned Ludd
    Ned Ludd
    Glycerine. It's often used in fluid-filled instruments.
  4. earlymopar
    earlymopar
    Many compasses used "Varsol" which was a mixture of alcohol and distilled water.
  5. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Anyone ever taken one apart to refill one?
  6. Sandcrab
    Sandcrab
    Aircraft Spruce sells compass fluid by the pint and kits to repair them.
    LOST ANGEL likes this.
  7. I've seen those things but never really examined one closely regarding how they are sealed.
    Are you seeing a bubble or are there other signs of leaking, such as a very low fluid line and old water stains, etc., on the carton?
    I've never seen one of those that didn't have a bubble at the top so if that's what you are seeing, I wouldn't be concerned. It is what it is.
    41 GMC K-18 likes this.
  8. Matt Dudley
    Matt Dudley
    from New York
    I know boat compasses have a plug to fill them and the oil is available for them, and they are the same type of compass.
    I bought a new old stock Airguide compass for my boat ( 1966 StarCraft Holiday )and it leaked out and caused the vinyl on the dash to wrinkle
  9. 1930artdeco
    1930artdeco
    from Lynden, Wa
    This one still has fluid in it but enough has leaked out so the compass sticks in one position until you jar it loose to float again.
    I will check out Aircraft Spruce or a marine supply store.
    thanks.
  10. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Here is a pic of the compass finally.
