Customs Rand Man’s 49 Ford
Discussion in 'The Hokey Ass Message Board' started by Rand Man, Jan 24, 2025.
Tags:
  1. I'd check driveshaft angles
  2. Tim
    Tim
    from KCMO
    They make some shims/ wedges for adjusting your pinion angle if the blocks have changed it enough to cause issue. Very easy to find. Also curious of when it does this, my first thought was the new axle placement could have caused the yoke on the trans end all the way to bottoming?
    Just thoughts. Car looks great.
    Rand Man and The Chevy Pope like this.
  3. Rand Man
    Rand Man
    I think it has the stock 49 rear end. I think this driveshaft sticking into the transmission too far is a good idea. It just acted like there was a rubber band under their winding up wanting the bust if you put too many revs on it. They probably had to shorten that driveshaft to install that 350 trans and they never thought about maybe needed more clearance in the future.
    The Chevy Pope and guthriesmith like this.
  4. Rand Man
    Rand Man
    I have my new skirts painted. Gonna change the tires and put on my new hubcaps. I’m wanting to show those off, No pictures yet so that’ll be in another post.
  5. Rand Man
    Rand Man
    Also, I ordered some 2.5 degree pinion wedges just in case.
    The Chevy Pope and Tim like this.
  6. guthriesmith
    guthriesmith
    Good thought on checking the yoke into the transmission. It may have been right on the edge of being too long before you lowered it and then bottomed it out with lowering it. I had one do that in a 52 Chevy and blew up my transmission before I noticed it.
  7. Tim
    Tim
    from KCMO
    Yeah even settling springs could do it. Would be easy enough to check when the car is up getting wheels and tires swapped around
  8. pprather
    pprather
    Disconnect drive shaft from differential.
    See how far it can be moved into transmission.
    See where old seal mark is on the yoke, compared to where seal now rides yoke.
    Etc.
  9. Rand Man
    Rand Man
    Finally an update; my son helped me get the car jacked up, took out the driveshaft and found the problem. The angle was extremely messed up. I bought wedges, but I’m thinking now those 2 inch blocks might have had some angle built into them and this is backwards. The yolk was hitting the driveshaft at the transmission. You can see where it hit IMG_8834.jpeg
  10. Rand Man
    Rand Man
    Cut out upholstery to glue to the new door panels. My tip for the day: check check double check again which side gets the glue and the direction of the pins. It’s easy to waste upholstery on something like this. IMG_8922.jpeg
  11. manyolcars
    manyolcars
    I love the 49-51s and have 9. Driving a 50 Crestliner and a 51 Victoria. the rest are parts cars
    seb fontana and Rand Man like this.
  12. Chevy Pope is right, angle should be 3 to 6 degrees no more no less. Lowering it takes degrees out.
    Rand Man likes this.
  13. Rand Man
    Rand Man
    I bought some 5° wedges. I’ve gotta have help to put that driveshaft back in. I’m doing it the old-fashioned way crawling around on the ground.
    Okie Pete likes this.
  14. Rand Man
    Rand Man
    Is there a trick to getting the interior door handles off? It looks like there is a little pin that needs to be driven out is there a special tool for this?
    I can come up with a small punch And a pry-bar or two I just wonder if there was an easier way.
  15. Tim
    Tim
    from KCMO
    Nope just push the echlin down so you can see the pin and drive it out with whatever’s handy
  16. Rand Man
    Rand Man
    Yeah I can do that. It looks like the previous owner stuck a thick washer behind there maybe to keep it from rattling just a hassle.
    I put in some new sound deadening material. Was going to put in at least the rear panels. I might not have the right clips, might just be a two man job. IMG_8928.jpeg
    Squablow and Okie Pete like this.
  17. Tim
    Tim
    from KCMO
    Yeah the washer is probably in place of the door panel that would have kept it snugged up
  18. tubman
    tubman
    IIRC, the pins may be tapered and will only come out one way. Or, that may have been some other make of car. Anyway, check it out.
  19. Use a small punch then a nail that fits the hole.
  20. Put the drive shaft in the trans with it in neutral, then skoot down to the differential put the "U" joint caps on and rotate till they line up with the rear end side of the "U" joint, slip them in and bolt them down and you're done , a one man operation.
  21. Rand Man
    Rand Man
    Yes I think I can do that. My trouble is getting up off of the ground by myself: old injuries.
    lothiandon1940 and Okie Pete like this.
  22. Rand Man
    Rand Man
    Is this the stock 1949 Ford rear end? I thought that would’ve been a Dana 44, which has the bolted cover on the back. This looks like an 8 inch Ford rear end to me. Opinions? facts?
    Also, I have to loosen those U bolts to install my wedges. Turns out that’s quite a chore with a regular combination wrench.
    What do they call those hex head air ratchets that would slide up onto that nut?
    It would take an extra deep socket to get onto that thing.
  23. ididntdoit1960
    ididntdoit1960
    from Western MA
    Stock rear - Ford used it '49-'56 - only wagons and t-birds got the Dana....
    seb fontana likes this.
  24. Leave an inch of threads and cut off the extra threaded length of the U-Bolts. Then you can use a standard deep socket.
    Rand Man and VI Lonewolf like this.
  25. Rand Man
    Rand Man
    After a ridiculous delay, I have the five degree wedges installed for the 2 inch lowering blocks. I have the driveshaft put back in with brand new u joints. Possible test drive tomorrow
    That high back bench seat wasn’t right for this build. I found some 65 Mustang bucket seats that I think will look pretty good in there. I better do that test drive before I start pulling out seats.
    Did anybody see my new post about interior door handle interchange?
    Squablow, Tim and guthriesmith like this.
  26. Rand Man
    Rand Man
    Turns out I have 1950 and above round shaft with splines and a pin. How far up in years does FoMoCo use that style handle?
  27. Rand Man
    Rand Man
    No, the interior door handles and cranks don’t have splines. They’re just square shafts. I don’t know what I was thinking, but IMG_1747.jpeg when you look inside the door handle it looks like it has some splines on it.
  28. Rand Man
    Rand Man
    I need to bleed the brakes because we had to unhook the brake lines to put in the new springs. Is there any trick to getting the top of this master cylinder off? Jjust an odd angle to get a 3/4 wrench down in there. IMG_1746.jpeg
  29. There are actual 4 AND 8 corner sockets for that job. Old gas stations actually had a T handle wrench for that job back in my younger days.
    dwollam and BigRRR like this.
