Anyone use heat shrink hose clamps ?
Discussion in 'Off Topic Hot Rods & Customs' started by TA DAD, Feb 8, 2025.
  1. TA DAD
    TA DAD
    from NC
  2. leon bee
    leon bee
    I guess to cut one off might be tricky if you like your hose.
    RmK57 and TA DAD like this.
  3. TA DAD
    TA DAD
    from NC
    I have not researched them, but was looking them over at the part store this week.
  4. kabinenroller
    kabinenroller
    I have use them for certain applications but not on my Cyclone. They hold tight and become tighter as the warm coolant heats them.
    TA DAD likes this.
  5. mad mikey
    mad mikey
    I used to see them on big rigs radiator hoses when I worked for a CAT dealer. To remove you have to cut them with a razor blade, VERY CAREFULLY or you will slice the hose. They do work, never saw one leaking.
  6. 6sally6
    6sally6
    I used them on my (M-word!) car and they were flawless. No leaks and I ran them many miles with Zero problems. I had them on the radiator hoses AND heater hoses. I bought mine at a local electrical supply store.
    I did carry 'emergency' hose clamps in the trunk though. (never used them....)
    6sally6
    TA DAD and klleetrucking like this.
  7. Sandcrab
    Sandcrab
    I used one on the lower hose of the Devon to avoid multiple gear clamps. They blend right in. I used an aluminum inner sleeve to connect two bends so I could clock them to get the correct fit and orientation.
    As mentioned above they are a one time use and must be left on their cardboard sleeve until final mount.
    RICH B and TA DAD like this.
  8. 65type1
    65type1
    I ran them for a bit on my truck and they worked well. Needed to remove the rad at one point and realized how much of a pain they'd be to deal with on the side of the road.
    Made the decision to ditch them and go back to standard clamps.
  9. RodStRace
    RodStRace
    Like any new solution to an old usage, you have to weigh positives to negatives and figure WHY it's been adapted.
    I see it as simpler install and cheaper. That answers OE. You could include more positive clamping when installed properly and easier to QC/inspect during ***embly.
    I'd guess they also split the difference between the metal screw clamps that hold a certain diameter, relying on the hose to deal with varying temps and pressure and the metal spring clamps that continue to exert inward pressure. It's also a clean look.
    Downsides are more difficult dis***embly and roadside repairs where it's not clean, dry and well lit. Likely more difficult install to exact specs without correct tools and conditions.
    It makes complete sense to OE, but the DIY guy will have concerns. Choose your poison.
  10. TA DAD
    TA DAD
    from NC
    Well good, I was curious as to how well they sealed. Thanks for the input. IMG_1810.JPG I think I will use them to splice this lower hose. BBC into a 60 F100 .
  11. ronzmtrwrx
    ronzmtrwrx
    They actually seal really well and will adapt their shape to a slightly irregular diameter if that happens to be the case. I have used them on off topic stuff before when going for a clean look. But, as has been mentioned, it’s tricky to remove them without getting into the hose. I have used side cutters to snip away slowly across them before to remove. Good ole hose clamps are much simpler.
    mad mikey likes this.
  12. TA DAD
    TA DAD
    from NC
    I will use them on the splice and put regular clamps on the ends.
  13. Sandcrab
    Sandcrab
    That is what I did. I made a tool to put beads in a short piece of aluminum tubing for the splice since I didn't have a long straight length where the two elbows connected. And like you mentioned hose clamps on the ends.
    RodStRace likes this.
  14. Gasser 57
    Gasser 57
    from New Jersey
    The splice definitely seems like the best place to use them on a Hot Rod.
    dogwalkin and loudbang like this.
  15. arse_sidewards
    arse_sidewards
    from Central MA
    This pretty well sums up how well the heat shrink hose clamps age:
    SS327 likes this.
  16. arse_sidewards
    arse_sidewards
    from Central MA
    The real money maker is that it keeps the genius UAW employees from screwing up the install.
    You give that brainless **** a calibrated computer controlled inductive gun, you put a QR code on each clamp. The gun scans the code. The gun runs the right amount for the clamp. The gun sends it to a database to be recorded, stops running and beeps if the code moves out of sight, etc, etc. No way for him to screw it up.
    Pretty much every "why the F would they create this un-servicable design" you see in the modern automotive industry can be traced back to somebody trying to prevent the idiots on the line from screwing it up. Stuff like push lock fittings that can be quality-control tested with a quick tug, etc.
  17. RodStRace
    RodStRace
    Well, I'd agree with a great deal of that, except the part where the derogatory comments apply to the workers. They are in a high stress environment and timed to the second. They are cogs in a big machine and must fit right into the design. Not a pleasant place, even if it's lit, temperature controlled and generations better than it used to be. One should walk a mile in their shoes.
    BTW video is not showing.
    MCjim, A 2 B, '28phonebooth and 5 others like this.
  18. TA DAD
    TA DAD
    from NC
    What do you even say to that ?
    Dick Stevens, Fordors and leon bee like this.
  19. Fordors
    Fordors
    How to win friends and influence people ^
    You must be a great neighbor.
    TA DAD, MCjim and SS327 like this.
  20. SS327
    SS327
    Or management.
    TA DAD likes this.
  21. arse_sidewards
    arse_sidewards
    from Central MA
    I've worked in manufacturing at various points in my life. It's not 1920 or even 1960 anymore. There are manufacturing workplaces out there that bring out the good in workers. Automotive ***embly, doubly so if unions are involved, brings out just about the worst. It turns people into hose connecting door hanging wire harness securing toddlers. While some people could perhaps be decent if they went elsewhere it's got a lot in common with prison in that once someone has been there long enough they can't really function anywhere else.
  22. TA DAD
    TA DAD
    from NC
    I posted the finished hose on my CV install thread but here it is for those who may not have seen it . The finished hose, worked out pretty slick. I used a aluminum tube made for the purpose. IMG_1829.JPG IMG_1827.JPG
