Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone
    Sharpone
  2. pila38
    pila38
    Crossmember welded and painted. Didn’t get anything else done because I had to clean the shop up.
  3. lumpy 63
    lumpy 63
    20250209_111446.jpg Here's a side view. The wheels are only mock ups. It will have steel wheels with dog dish caps.
  4. guthriesmith
    guthriesmith
    Installed some Posies 3” dropped springs on the rear of my car. I was hoping to lose the 2” blocks but ended up leaving those in too so it would sit where I wanted it.
  5. Mmmmmmmmm
  6. The stance is just right.
  7. atch
    atch
    It's just about impossible to know how much old springs have sagged. About 20-25 years ago my friend Johnny (RIP) wanted to replace the leaf springs on the front of his '56 F-100 to lower it a bit. He ordered reversed eye springs and installed them. Raised the front of the truck 2".
  8. 402BOSSMAN
    402BOSSMAN
    Been trying to wire my new shop toy up. Been looking for a lathe for around 5 years and finally found what would cover my needs. Basically a German design 15x34 Toolroom Lathe.
  9. saltflats
    saltflats
    from Missouri
    Nice looking lathe Nick.
  10. 1pickup
    1pickup
    A complete waste of time, I'm sure, but since I'm waiting on parts for the current suspension rebuild on my '47 Buick, I'm turning this old aluminum lunch box into a heater for my chopped '36/'37 Chevy pickup. Need to put some louvers (louvres?) in the front & bottom so the heat has a place to escape. It's got a Chevette heater core that fits inside. Debating on trying to hand form the louvres or find somebody to punch them for me.
  11. Speed Gems
    Speed Gems
  12. chevyfordman
    chevyfordman
  13. wilkinson
    wilkinson
    Looks great! These days, I don’t have much time for new projects, unfortunately. We’re in the middle of a complete refurbishment of our house, and it’s taking up a lot of time and energy. I’ve been spending most of my free time on the bad boy furniture website, picking out pieces for the interior. It’s a lot of fun, but also a bit overwhelming with all the options! We’re trying to balance comfort and style, so it’s been a lot of browsing and decision-making.
    mad mikey and Sharpone like this.
  14. 427 sleeper
    427 sleeper
    I've always been in awe of machinery like that. Even more so with the people that know how to use them. :cool:
    Baumi, mad mikey, Tickety Boo and 3 others like this.
  15. Baumi
    Baumi
    Spring is around the corner , so I worked a little on the 55 . The radiator had been leaking since when I got the car in 2015 and for about 80k miles it did what it had to. But last fall the leakage grew worse and my go to radiator man quoted me both my kidneys and our firstborn. So I shopped around and found that US Radiator had a sellout on Tri5 I6 radiators, around 300$ each. Fitment is perfect and it looks better than a chinese aluminum radiator IMO.
    New bumpstops were also necessary, I wonder if the new ones will also last for 70 years , Hahahaha
    05AD2EA7-03B2-4B74-B564-E85F9E0D661B.jpeg FC0EE853-B44A-4D40-A5F6-9D8F217301C3.jpeg 0737A695-00E1-4BAA-8A3E-9AF13E82A7C7.jpeg EFEAE58A-0B23-4C3F-9420-16DAAC37E3E4.jpeg 47E3FC91-8F05-49D0-8102-8C0CF422C593.jpeg
  16. swade41
    swade41
    from Buffalo,NY
    I killed some brain cells painting the Eastwood rust converter on after I had cleaned up the lower sheetmetal, whew boy that stuff is strong.
  17. pila38
    pila38
    Got the long dowels and pilot bushing in, and installed the mid-plate, ****tershield, flywheel, and bellhousing. Didn’t index it yet. I do most of my work after everyone goes to bed, so after a couple hours I’m pooped and it’s late. I’ll get to the indexing later.
  18. Paul
    Paul
    Editor
    the achingly slow process of piecing together a blower setup on a shoestring budget.
    bought a diesel blower a few years ago, a manifold not long after.
    had the blower converted to gas last fall,
    bought a lower hub a few months ago,
    started fabbing adapter plates to fit the late 371-394 Olds a few weeks ago, bought a single V belt accessory pulley and recently after chasing a Delta drive setup for way too long opted for an easier to put together typical drive setup, got the idler bracket and pulley the other day and cut the stand offs down to tuck it all in close today.
    also ordered a crank and blower pulley today.
    when those show I can order the snout.
    going with the 1/2" pitch 2" belt and and keeping it all as close as practical thinking it might eventually go in the T.
  19. kasselyn29
    kasselyn29
    Still working on it!
  20. lumpy 63
    lumpy 63
    IMG_20250212_085226.jpg Found some poverty caps that will fit the steelies on the tempest
  21. Lumpy, those are perfect!! I love them.
  22. lumpy 63
    lumpy 63
    Pulled the dash- engine compartment harness out of the donor car because the harness in the red car is fried. The donor harness had a toasty ign. wire tied in with the resistor wire ... I removed all that and ran regular 14 gauge wire to replace it. Tomorrow I will do a generator to alternator conversion on that part of the harness.
  23. fastcar1953
    fastcar1953
    porkshop, Sharpone, lumpy 63 and 2 others like this.
  24. snoc653
    snoc653
    from Iowa
    Nice lathe. Being German is it three phase? I’d love to find some a mill and lathe but I can’t get three phase and don’t want to run everything on converters.
    porkshop and Sharpone like this.
  25. pila38
    pila38
    Bell is dialed in. No need for offset dowels, Lakewood did a nice job. Unfortunately, the project manager forgot to buy pressure plate bolts. What a ****.
  26. Moondog13
    Moondog13
    I’ve been trying to figure out what this is out of, if anyone recognizes it. It came installed in a ‘48 Ford I just got and it looks pretty viable so I’m trying to save it if I can. IMG_2047.jpeg
    Sharpone likes this.
  27. vtwhead
    vtwhead
    ^^^^^looks like a gm product similar to the one I used from a 66 Nova
    Sharpone and Moondog13 like this.
  28. For you guys who use CLR to de-rust parts, do you reuse the CLR after you take the parts out?
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Color code of wires isn’t GM in my eye’s.
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Maybe :) IMG_3845.jpeg
