Hot Rods The Underslung Chassis, Dead Forever ?
Discussion in 'The Hokey Ass Message Board' started by Art Gertz, Feb 7, 2025.
  1. chrisp
    chrisp
    I'm very slowly building an underslung special, minimum diameter wheel I can use is 21" because of the factory axle drop. A straight I beam or tube axle is almost necessary if you don't want the frame below wheel diameter. The scrub line is definitively the most difficult on such a build.
  2. theHIGHLANDER
    theHIGHLANDER
    I'm dealing with a guy in his early 90s, still out in the shop every day, over the phone the only way you can tell he's that old are his euphemisms and occasional slang. Past that he's still as sharp at his chosen directions taken more than 70 years ago and is still the head judge in a Marque specific club. Met a guy in October who is 94. Has a stunning and important car collection, still sharp, candid, and bought a new 2023 Vette. **** age, it's a number. Older means you've seen and done more (or sure as hell should).
    Now that we got that cleared up I never much cared for the concept. I give quarter to the American Underslung from the teens because it represents a daring and brave departure, or in today's vernacular they're just kool as ****. As fillibustered above scrub line and actual use have to be considered but sometimes what works just, well, works. 20" Kelsey Hayes wire wheels would look funky...o_O
    2OLD2FAST likes this.
  3. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    You belong here,just expect to find some negative feedback from the peanut gallery
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Blah , blah , blah , blah , negative , negative , blah , blah ....
  5. RodStRace
    RodStRace
    @Art Gertz Your initial post give a quick sketch of an idea and asks for opinions.
    You got 'em!
    Your later posts covered even more ground, all of it more "What If's". With any project, you need to be able to walk before you run. I didn't go back through your old posts, but judging from the other comments, they didn't see any previous builds of even regular skills, let alone advanced stuff.
    As said, underslung has been done a few times, but it's very rare, due to the issues mentioned.
    A V16 project can be done, but it's a huge undertaking. I'd suggest youtube channels Greg Quirin and Alan Milliard for engine stuff in this area.
    A T bucket is the light, open, anything goes basis, and it or a Speedster are most likely to be a decent basis for the offbeat thoughts. This part of your premise is the most reasonable.
    Aluminum frames have been discussed here many times. The main consensus on them seems to be while it's lighter, it requires greater fab skill, superior design skill and can fatigue without as much warning. I'd suggest looking at trailers with all aluminum construction to gauge what the typical over the road ch***is looks like.
    Finally, torsion bars are great but why use 2 different springs? A lever shock makes more sense.
    There are solid reasons why traditional hot rods are built using the systems they do. We all have "What If" thoughts, but if you are really wanting to build this, have a firm understanding of what is common, why it's the standard choice, apply the same parameters to your new design and figure out what it's going to take in research, money, fabrication, and inevitable rework to make it do the same or better. If it is just to get an argument going, ask why sinks are positioned under faucets!
    Kerrynzl and 41 GMC K-18 like this.
  6. partsdawg
    partsdawg
    from Minnesota
    My Dad is 89 and out in his shop every day restoring tractors. If it's a International or Farmall he can quote any spec from 1939-1964. He would laugh in he face of anyone saying he is too old or doesn't have enough time to be doing what he enjoys.
  7. RodStRace
    RodStRace
    Let's talk about a t frame with standard 2x3 tubing (aluminum here, proper thickness size). A limited suspension movement of 2 inches up, 2 inches down (very small, but this is a light, minimal rod). Half the diameter of the axle.
    3 inches of frame, 2 inches of compression, say an inch of axle radius. That's 6 inches below axle centerline IF the spring is not taking any of that space. Spring can be mounted inboard or outboard of frame or on top of axle. It would probably be a good idea to have a bump stop, too.
    This gives a minimum of a 12 inch wheel to prevent scrub. Good so far, frame limits droop, spring can limit rise. What will the corner weight be to calculate spring rate? 1200-1800 total? 300-400 each sound good? Will it need additional locating links? How will steering be incorporated?
    At this point, what is going to be part of the frame design to counter twist? Those kickups you are avoiding help counter this, although only a small bit. Using the engine as a stressed member helps, but adds NVH and adds new concerns, especially with the different material choice.
    You can worry about shock design and mounting later, but it would be a good idea to research what is available to work with that weight and travel.
    Let us know what ideas you have for these concerns.
    hfh and 41 GMC K-18 like this.
  8. Kerrynzl
    Kerrynzl
    This is the very reason I suggested buying a Hot Rod and then personalizing it.
    There is nothing wrong with dismantling it and changing a few things to make it HIS car
    What Art hasn't mentioned here is his fabricating experience [or lack of] and starting out at 75 trying to build a "complicated car disguised as a T bucket" would probably never see the light of day.
    We all know of people who are elderly and playing with tools and equipment until they die. They probably have been doing this since their teens , and not just starting out now.
    Personally a hotrod with twin alloy V8's and a rear transaxle, plus underslung stressed member frame, rising rate suspension with composite components is way off topic here and is more like an immature schoolboy dream.
    He might as well stack supercharger casings on top of each other while he's on a roll.[to impress the kids]
    The OP sounds like a 13 year old boy daydreaming about cars
    I'm done with the mentality of this thread
    I'm going through the same process now with a friend [who is now 72] trying to help him build a Bucket.
    The real challenge is he doesn't want to spend $$$ [he makes Ebenezer Scrooge look like Santa Claus] and he goes off on a tangent and takes on other projects and never finishes them.
    Clydesdale and 41 GMC K-18 like this.
  9. 41 GMC K-18
    41 GMC K-18
    firstinsteele and Kerrynzl like this.
  10. twenty8
    twenty8
    Don't let age prevent you from starting a project. It doesn't matter in the end if it gets finished or not. Whatever the outcome, it is far better than sitting around waiting for the reaper to call your number.
    I do agree that your build is not really HAMB appropriate, but don't let that stop you. Maybe, for a start, this should be moved to the off topic section...???
    Ned Ludd and mohr hp like this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    RodStRace likes this.
  12. RodStRace
    RodStRace
    Good catch, @2OLD2FAST !
    T based (26-27, not 25), underslung. Even looks like it's got room for a V16!
    Depending on OP's desires for rolling stock and springs, this would be valuable to get if for no other reason than to take a lot of measurements and swap over parts to their AL frame.
    41 GMC K-18 likes this.
  13. RMR&C
    RMR&C
    from NW Montana
    If you are not using parallel leaf springs, the frame does not need to be "under" the axles at all. It could end just short of them. 1/4 elliptics or torsion bars would let you set the frame height wherever you want.
    But I'm not sure how the aluminum frame will work with any of this. Seems like the biggest hurdle
  14. Art Gertz
    Art Gertz
    Even without FIA oversight, It's the safer way to build a ch***is. On the flipside, how many over-slung cars out there, with oil pans, transmissions and other components, would fail this criteria ?
  15. Art Gertz
    Art Gertz
    True, plan is a solid axle in front. Rear mounting point of 1/4 elliptic is mounted for safe ride height with respect to axle drop. Aluminum can be adequate as a frame material. It takes a sound design to make it work. A simple torsional deflection test, will prove this. Could even measure front/rear deflection. I will measure before rigid mounted drive train and roll bar ***embly.
    Thanks for all the positive inputs, Art.
    RMR&C likes this.
  16. seb fontana
    seb fontana
    from ct
    I remember some of that build, not the alum frame though and I remember some kind of top. I remember for some reason he had the king pins/axle upside down, never could figure out why. Maybe to clear underslung ch***is.
  17. chrisp
    chrisp
    I seem to remember a company years ago at the GNRS who was manufacturing I believe '32 ch***is out of aluminum, didn't they stop because of cracking issues?
  18. seb fontana
    seb fontana
    from ct
    Boyd built a couple cars with alum frames [Alumatub] but I don't think he had them [frames] for sale. Maybe same place that had alum axles and rad rods.
  19. Adriatic Machine
    Adriatic Machine
    I remember a famous race car incident where the car had a simple flat tire and the bottom of the car s****ed on the asphalt so badly that the driver didn’t survive. I think it was at Indy. I like the look of underslung but I also like having my balls intact.
  20. Mr48chev
    The first WSP officer who saw you with that car in Washington would give you a scrubline ticket and I wouldn't be surprised if they had it towed. To me it is strictly a pro fairground car to unload in the back lot at Goodguys and cruise around the grounds and then take back to the trailer at the end of the day.
    I thought about running my late 20's early 30's Chevy framed boat tail roadster as an underslung but it would mean coming up with a straight tube axle and some stiff and pretty flat front springs. I finally figured out that even with the 18 inch Chevy wires I wouldn't have the scrub room to be legal and I have already had too many scrub line tickets with my 48 just as you see it in my avatar.
  21. Mr48chev
    Building a car all depends on your personal skills, depth of wallet and desire to build it. Then facilities and equipment come in to play.
    Then comes in to play the thing about how you plan to use it. If it is a driver on the street and road you have to make sure that the lowest part of the ch***is will not touch the ground if you pull all four valve cores out and let all the air out of the tires. I don't think there is one state where that is not the law.
    Otherwise if it is lower it is what I call "Pro fair ground" and is trailered to all events that it is taken to and driven from the trailer that is parked out back with the other trailers and only driven from the trailer to the place it is parked and maybe every two or three hours fired up for a lap around the fair grounds to get the attention of anyone who didn't stop and look at it and then taken back and parked.
    It sounds 99.9% off topic for this board but it is your call on how you build it.
    Beanscoot likes this.
  22. Ned Ludd
    Ned Ludd
    I suspect that packaging considerations militated against the underslung front axle fairly early. The impracticalities are e.g. the radiator having to sit either behind or ahead of the axle, fender inner valances having to have holes for the axle to go through, headlight posts becoming convoluted, etc. etc. In other words, there is a moving axle between the frame and everything that needs to be attached to the frame in that region. By contrast an underslung rear axle is comparatively easy to do. That is why overslung front axle + underslung rear axle was close to the norm for cars of more sporting persuasion for many years. Morgans were that way (except with their traditional sliding-pillar ifs) right up to the new aluminium-composite cars.
    That V16: don't abandon a dream if it's something keeping you alive. There's enough in my life preventing me from actually building anything, but I don't know how I'd live without all that's constantly going on in my head. One thing I've found, though: the further out of reach my dreams get, the more fanciful they become. Whenever it looks like there is an actual practical chance, they come down to earth quite rapidly — but that doesn't mean they suddenly become something else. The pie-in-the-sky stuff does inform the semi-realistic stuff. I learn a lot that way.
    KevKo, RMR&C, rod1 and 4 others like this.
  23. mohr hp
    mohr hp
    from Georgia
    On the scrub like stuff, realistically, if you can maintain control with just any single tire blowing out, you are good. I mean the only time I could imagine all 4 tires failing simultaneously is if you drive over one of those spike strips. So that buys about another inch or so of low. Aaaaand you can use really tall skinny tires....
    Also depends on where Art drives. Here in Atlanta, I think you could run around I285 in a Formula 1 car and not raise su****ion.
    BigJoeArt and 2OLD2FAST like this.
  24. Thank you SIR.
    Ben
  25. chrisp
    chrisp
    It wasn't Boyd, It was a small booth with 2 frames around 2005, at least one was polished and bare. I believe they talked about them in Street Rodder.
  26. FrozenMerc
    FrozenMerc
    I was going to suggest someone ask Ayrton Senna about the importance of scrub line, but you beat me to it.
    Adriatic Machine likes this.
  27. Adriatic Machine
    Adriatic Machine
    Yea I believe that incident prompted a whole new set of design standards.
  28. RodStRace
    RodStRace
    Which is strange, racing stuff has been blowing past that hard fast rule for a while.Maybe F1 got the message, but the drive for suction is strong.
    1986
  29. GZ
    GZ
    from Detroit
  30. GZ
    GZ
    from Detroit
    Underlung works well for me. And it's matched with a lowered rear cross member. It's about stance. Even for a pre-WW1 car and this is how they did it. 20200910_215324.jpg 20210526_185928.jpg 20210526_191702.jpg 20200910_215059.jpg 20200910_215230.jpg
    porkshop likes this.
