History Alcohol instead of antifreeze?
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Feb 4, 2025.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    While we're on the subject of antifreeze, who remembers Zerex, the wonder antifreeze that was advertised as stopping radiator leaks on its own? All I know is that it did a good job of plugging up the heater core in my father's '67 Caprice, and it was a very cold couple of weeks before he got all of it blown out of there!
    seb fontana and jet996 like this.
  2. nrgwizard
    nrgwizard
    from Minn. uSA
    Yup...
    Marcus...
  3. Harv
    Harv
    from Sydney
    Of course you can use alcohol for antifreeze. Crown Royal has been preventing our Canadian brothers from freezing solid each winter for decades :D
    (with respect and a smile to our mates from the Great White North :cool:).
    Cheers,
    Harv
  4. krgdowdall
    krgdowdall
    from Alberta
    My grandfather said that they used a salt water mix in the fall up until Xmas, before it got really cold.
    It would get slushy but not freeze solid. After the holidays it was back to hitching up the Clydesdales until spring thaw
  5. deathrowdave
    deathrowdave
    from NKy
    Kerosene in the cooling system , start the diesel with a couple shots of gasoline on a shop rag held over the intake . Old antifreeze in the rear tires for weight . That was it for my Dad for years . I remember the old diesels sounded rough with this hot fuel start up , but the kept going and going . If you don’t think oil cold oil will slow the process down , you need to try to kick over an old Harley at about 35* . The starter will hold you up in the air , and Harley’s are a dry sump oil system . Always found a way to park on the hill and roll start the old girl to life
    Truckdoctor Andy likes this.
  6. chrisp
    chrisp
    My grand father used alcohol antifreeze at least up until he bought his new car in '86.
    rod1 likes this.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'll bet that did wonders for the water jackets and core plugs!
  8. seb fontana
    seb fontana
    from ct
    Eh you hoser. From the movie with J Candy.
  9. BJR
    BJR
    Given a choice I would pick alcohol over antifreeze for my drink of choice, but that’s just me.
    Driver50x likes this.
  10. mike in tucson
    mike in tucson
    from Tucson
    My pop bought a new Chevy in 1950. Antifreeze was an option and cost something like $6. It was dealer installed
  11. Driver50x
    Driver50x
    This is the first I’ve ever heard of using diesel for antifreeze. That kind of makes me want to pull into a busy gas station, open the hood, and add a little fuel to my radiator. :po_O
  12. Rand Man
    Rand Man
    There is a high tech product called Water Wetter, that is supposed to vastly improve your cooling system. Guess what’s inside that secret formula — Isopropyl, alcohol.
  13. dwollam
    dwollam
    Not something I would run today as a daily driver but back then as a broke *** youngster feeding the kids came first, and draining the water out of a flathead Ford is pretty much impossible without a wrecker to stand the car on it's nose to empty it, I went with diesel to save the engine. It worked. I have lost a flathead to thinking I could drain it safely.
    Dave
