Projects 1957 chevy exhaust manifold clearance problems
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Feb 11, 2025.
  1. Huckster59
    Huckster59
    installed motor 283. had prev bought some center dump manifolds ram horns. hoping to fit better at steering box. 605 box. it’s right next to it. might even be touching. what fits better? does 500 box give more clearance? patriot headers? anybody installed a rack and pinion. need some ideas for the Hellair. IMG_0600.jpeg
    e1956v likes this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    can't really see the problem from that picture. Maybe the gasket surface could be machined to bring it closer to the engine? 55-56 exhaust manifolds dump out the front, so they would work. Rack and pinion steering is off topic here. this is a traditional hot rod forum that focuses on 1965 and older style builds 56man.jpg
  3. Dooley
    Dooley
    from Buffalo NY
    sharp little motor. a pic on the driver's side showing the interference would help.
    swade41 and Johnny Gee like this.
  4. Huckster59
    Huckster59
    i’ll get pic. local guy has these. i think would fix my interference problem
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, those are 55-56 manifolds like I pictured above. would also allow you to put the generator or alternator on the drivers side where it belongs on a 57
  6. RodStRace
    RodStRace
    @Huckster59 as you can see, even though it's outside HAMB style, the members are willing to help.
    I'll mention this as a constructive suggestion, Please take it as such. The ***le "1957 Chevy" is going to get curious people opening this, but it's too generic. It isn't defining what you are talking about or asking.
    Something like "1957 Chevy exhaust manifold interference" will get the right eyes and be able to be searched/found in the future.
    Just Gary likes this.
  7. Huckster59
    Huckster59
    ok thanks.
    RodStRace likes this.
  8. Huckster59
    Huckster59
    how do i delete this thread
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    there is no need to delete it, simply edit the ***le
    click on thread tools in the upper right, then click edit thread, then change the ***le and then click save changes
