Projects 32 3 Window build "Cinderella”
Discussion in 'Traditional Hot Rods' started by Tuck, Aug 16, 2024.
  1. panhead_pete
    panhead_pete
    That windshield frame will probably confuse a future owner ... Love what you are doing with this. The mellow channel is great. We all have different tastes and as I get older the less appealing to me are those heavy east coast channels, except maybe on a Model A coupes with a heavy haircut too. For my mind you nailed it here.
  2. BrerHair
    BrerHair
    Love it. Wheels and tires are ***s!
    chryslerfan55, Stogy, Tuck and 3 others like this.
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Man,. I ended up matching a complete set of early for 5 on 5.5 chrome reverse! This is the way- that way I don't have to redrill the hubs or rear banjo and can run early 40 wheels too if I want. I ordered a drill guide to drill the drums for the Buick to 5.5" bc. And I'll just run a cone in the center like they did back in the day... and swap the www's onto these.
  4. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    IMG_4035.jpeg IMG_4032.jpeg I welded up the holes on the Buick drums I drilled for the small bolt ford and redrilled for the 5 on 5.5"... I machined the ford hubs to fit snug into the Buick drums. I need to order the studs and then I can clearance the drums on the brake lathe for the backing plates and turn the drums. Can't wait to swap the white walls to the 5.5" 15x6 reverse wheels and get axle setup with 40 brakes.
    Studs to do this are: Dorman 610-039. Knurl dia. .625", shoulder length .719" Thd. 1/2" 20, under head length 1.625
  5. don colaps
    don colaps
  6. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Anyone have a single 46-48 ford hub? Putting in the studs I ****ed one up... it bent it- I didn't have it supported right in the press and it happened so fast I was like DaMnIt!!!!!! Anyway... **** happens.
    A pal sent me this pic- it's *****en!
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Non sequitur... but check this out, My buddy Sam Nelson found me this *****en Tree CNC mill-! Hauling it home here soon. The control works great. Im so excited, this is going to be fun to make hot rod parts with and prototype dies etc.
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    This is a good example of what happened to the majority of these old *****en channeled 32 3 windows and other cool hot rods.... people changed and updated them and they're still here in plain sight its just they look lame now... LAME. haha-
    VIEWER DISCRESSION IS ADVISED!
    Example of the above car Copied from Kustomrama-
    Only the body, grille shell and rear nerf bar still existed from Conrad's creation when Kim went to check it out in 2000. Dudley had gotten rid of the Chrysler Hemi and replaced it with a 327 Chevy smallblock. "His reasoning was the lack of speed parts available for the Hemi. Dudley unchanneled the body filled the roof and placed it on a reproduction frame with a Kugel independent front end, 327 Chevy w/ Turbo 350, and a Maverick rear. A machinist friend was making billet parts to accent the coupe." Photo courtesy of Kim Jordan.
  10. A Boner
    A Boner
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Still looking for a single hub... this is going to look good. IMG_4109.jpeg IMG_4111.jpeg IMG_4112.jpeg D0509682-E586-4655-AE9E-05221147C3C3.jpeg
  12. brady1929
    brady1929
  13. alchemy
    alchemy
    I’m sure I have one laying around here. Send me a box to put it in.
    chryslerfan55, Tuck, Stogy and 3 others like this.
  14. Unbelievable... Dudley should have done what he wanted with a new kit car instead of butchering a gennie hot rod with history. Advertise this hot rod here on the HAMB so this original hot rod has the excellent chance to be preserved the way it was back in the day!! Just my 2 cents...
  15. Tim
    Tim
    from KCMO
    Looking good man! New wheels, new brakes and new tools! You’re killin it!
  16. Rolleiflex
    Rolleiflex
    Man the car is coming along really nice, can't wait to see it in its full glory.
    Congratulations on the Tree mill. Does it have the conversational programing?
    While I could write my own code, conversational is so nice for quickly banging out parts.
  17. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    thanks Brady
    Thanks Bennett
    Thanks Tim, stoked on this. I also found some nice 40 backing plates for this car I had squirreled away and a steering hoop. Little more work and I can check the basic front end stuff off the list.
    Thanks Jeff and 10-4
    Thanks man and yes Sam said it did have conversational and it's supposed to work great, he was telling me how awesome it was to do some quick operations- looking forward to this.
    I had different motivations when I was younger... but as I get older I wish I had heeded the advice of a great uncle who tried to get me to buy a mill and learn machining when I was 17... I've had my Bridgeport for about ten years now and can't imagine life without it. Looking forward to having new capabilities.
    Tuck
  18. KansasMade
    KansasMade
    from Wichita KS
    Man it's coming along!
  19. Outback
    Outback
    from NE Vic, Oz
    @Tuck any movement on the coupe?
  20. It's been a while - hopefully we will shortly...
    Outback and porkshop like this.
  21. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Life has been good but busy, I'm working full time at the college and part time at the high school and still slinging dies... so I just havent had a lot of time for this. I did get some parts for it... a REAL steel firewall surround, I'm running a polished firewall but I hate the fibergl*** lip so much, I'm really stoked I got it..., I also ordered a real windshield for a 3window. I'm still hunting for hinges. I got more parts but I can't remember what all I picked up for it besides the hub for the other side. I finished the conversion and added the Buick drum to the other side.
    I did however acquire another project (I traded a project for it though so I don't think it counts??) and ended up with a Canadian 34 pickup. It all but runs... brakes have been rebuilt all the way around and work perfect... the flathead looks like it would fire up but its stuck. I'm going to swap it out with a running engine and just drive it. Its so cool.. It came with a couple boxes of NOS parts and casting patterns for the V8 emblems on the side which you know I'm gonna cast a few sets! :) It came from an estate north of Duluth.
  22. porkshop
    porkshop
    from Clovis Ca
    cant wait to see picture of you hauling the kids, chickens and rabbits around, on IG....
    chryslerfan55, 31chevymike and Tuck like this.
  23. Tim
    Tim
    from KCMO
    I can see some
    Tuck industries board sides on that thing….
    porkshop, 31chevymike and Tuck like this.
  24. JimSibley
    JimSibley
    I love a chopped and channeled 3w coupe! You are doing it right. IMG_3286.jpeg
  25. Moriarity
    Moriarity
    SUPER MODERATOR
  26. Tim
    Tim
    from KCMO
    Oh man a single axle car trailer behind it with a roadster ch***is would be amazing.
  27. Outback
    Outback
    from NE Vic, Oz
    A very cool pickup, did you get rid of one of your projects covered on here?
    chryslerfan55, Tuck and porkshop like this.
  28. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    No, no worries I traded a lifted 77 square body Chevy pickup.
    Hijacking my own thread haha... I got some new wheels/tires and a 59ab and started to buff it out!
  29. 59sedandelivery
    59sedandelivery
    Im just gonna hit that subscribe ****on right there!!!!! Im lovin it!!!!
