Hot Rods The car I've been waiting for
Discussion in 'The Hokey Ass Message Board' started by wheeldog57, May 8, 2024.
  1. wheeldog57
    wheeldog57
    Yessir @Jacksmith I am looking forward to long, smooth, smoky burnouts!
    porkshop, Jacksmith and swade41 like this.
  2. wheeldog57
    wheeldog57
    I stole @flamedabone technique for making home made sub rails. I studied his pictures carefully and came up with a plan to make it work on my ch***is. Very little done and lots to do but I think Mr. Abones system is the way to go, thank you sir. 20250211_202844.jpg 20250211_202858.jpg
  3. RodStRace
    RodStRace
    I agree, a 500 Cad motor is amazing 0-75 in a big car. In a light rod, it will be blistering.
    I haven't messed with them, but have read that those super low rise (drop) intakes are a choke point. Swapping them out makes a big difference.
    porkshop, Stogy, saltflats and 3 others like this.
  4. Rand Man
    Rand Man
    Good thread.
    porkshop, Stogy and wheeldog57 like this.
  5. wheeldog57
    wheeldog57
    Adding more sub rails. Both sides done back to frame kick up. Measuring for original holes in the frame to hold everything together. Funny how ALL the holes were plugged and then the frame was boxed. I'm sure they had a plan in place. . . . Frank brought me the extra large specification sheet so I don't mess up. Thanks bud. 20250214_200540.jpg 20250214_200534.jpg 20250214_200516.jpg
  6. wheeldog57
    wheeldog57
    Fitting and mocking. Transmission linkage, brake master, cowl foot, floor support all must coexist.
    If you fail to plan- you plan to fail 20250215_113928.jpg 20250215_113938.jpg
  7. wheeldog57
    wheeldog57
    VANDENPLAS, bchctybob, hfh and 4 others like this.
  8. wheeldog57
    wheeldog57
  9. wheeldog57
    wheeldog57
  10. wheeldog57
    wheeldog57
    Wasn't sure about the "mid floor area" but I figured what the hell, it's made already. . . 20250225_175710.jpg 20250225_175721.jpg
    Subrails made through 'b' post area. Now I'm ready to put body back on
  11. patsurf
    patsurf
    can you show a quick and dirty shot of forming that 'cone'?-nice!
    porkshop likes this.
  12. wheeldog57
    wheeldog57
    @patsurf do you mean the transmission tunnel? It came with the car. I bent it, cut the support piece off of the end, and trimmed the flanges. So far I think I'll use it.
    bchctybob and porkshop like this.
  13. patsurf
    patsurf
    thanks!
  14. wheeldog57
    wheeldog57
    Are these 4 bars and bat wings installed correctly? Parallel to the ground but not to each other when you look down on them. Any insight would be appreciated 20250301_200443.jpg 20250301_200452.jpg 20250301_200506.jpg 20250301_200443.jpg 20250301_200452.jpg 20250301_200506.jpg
  15. The37Kid
    The37Kid
    Just wondering are Bat Wings made Left and Right sided?
    wheeldog57 likes this.
  16. wheeldog57
    wheeldog57
    Handmade floor and sub rails took mucho hours and patience but I am happy with the results. If the body fits over it snugly then I'll be really happy with the results!
  17. RodStRace
    RodStRace
    Currently, they are like the angled rear 4 bars. I'd see if swapping them as @The37Kid mentions gets them aligned.
    As with many rods, the limited amount of travel hides flaws, but I'd try to get them in the same plane. That has got to be putting them into some side twist forces they aren't designed for. Rear bars are almost always in double shear.
    Also, on the left side, I'd have the shackle bolts go front to back (like the right side) for servicing. They may need a bit of a trim to clear.
  18. adam401
    adam401
    The floor looks awesome Ron. You’ll be driving before you know it
  19. wheeldog57
    wheeldog57
    Thanks for the replies, all hardware was installed by previous owner (nylock nuts everywhere) and most just mocked up.
    I'll try swapping sides and see if anything changes.
  20. wheeldog57
    wheeldog57
    Mocked up the vega box etc. Everything seems to fit pretty well 20250302_180931.jpg 20250302_181051.jpg 20250302_180956.jpg
  21. Jacksmith
    Jacksmith
    from Aridzona
  22. wheeldog57
    wheeldog57
    Been working on front brakes, namely trying to get the brakes ***embled but steering components are trying to occupy the same space. Tomorrow I bring the steering arms to work to give them the blue wrench drop treatment. Also I need one tie rod end and one outer wheel bearing- P.O. had two different sizes installed, yikes. Anyway I shortened rear sway bar end links and dry fit them. Also mocked up steering column with twine. 20250309_201414.jpg 20250309_201425.jpg 20250309_201524.jpg 20250309_201614.jpg
    VANDENPLAS, bchctybob, NoSurf and 3 others like this.
  23. wheeldog57
    wheeldog57
    17416299668848262397798924945500.jpg 20250310_121551.jpg 20250310_122347.jpg 20250310_122900.jpg
    Senter auto parts Plaistow,NH
    I bring them random parts. They ask me the usual. . . "What are they off of?" What year car?" I don't know I'm putting a hot rod together from spare parts. "Ok, no problem" everytime, they always have what I need. In stock!!
    I heated and bent the steering arms at work today too. Mint
    VANDENPLAS, bchctybob, Thor1 and 3 others like this.
  24. RodStRace
    RodStRace
    A smart man would do***ent each correct, sourced part and application. You may need to rebuild in a few years!
  25. wheeldog57
    wheeldog57
    Neighbor Steve came over he said " hey what are we doing today?" I said hopefully some guys show up and we can put the body back on this ch***is. Well, dontcha know. . . . Everybody came by today e81a820d-2adf-45fe-88ac-e9fc85de9a40.jpg 20250316_152827.jpg IMG-20250316-WA0004.jpeg IMG-20250316-WA0006.jpeg 20250316_163731.jpg
  26. wheeldog57
    wheeldog57
    What a huge difference an inch and a half makes 20250316_180904.jpg 20250316_180825.jpg
  27. wheeldog57
    wheeldog57
    Down more in front but not today, I'm beat- shower and beer time
    VANDENPLAS, porkshop and adam401 like this.
  28. wheeldog57
    wheeldog57
    After mucho adjustments I think this'll be the ride height 20250320_204447.jpg
    VANDENPLAS, bchctybob, hfh and 6 others like this.
  29. wheeldog57
    wheeldog57
    The body was very difficult to control while trying to get ride height UNTIL I welded the doors closed. Within 5 minutes I had what I wanted 20250320_205207.jpg
  30. wheeldog57
    wheeldog57
    Yup, that'll work. And I have headroom
    It will look way bettah once I roll it outside
