Technical Understanding Threads (at least a little bit)
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Feb 10, 2025.
  1. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I have been sorting through fittings I have and trying to put them in some sort of organized grouping. They are mostly AN type fittings, but many of them are also "adapter" fittings that combine two types of thread systems. I have a pretty good understanding (IMHO) but admit that sometimes I still have to check some of them out. It occurred to me that many people have little understanding of our American thread systems, so I decided I would try to explain the basics of the different American thread systems in a manner that would hopefully help others to get a basic understanding of them. Hopefully I didn't screw it up trying to get it explained (to the best of my knowledge) in a fashion that might help some others. So here it is..........
    EDIT CORRECTION.......I referred to AN as meaning Army Navy and it should have been Air Force Navy as @DDDenny reminded me below. Just a brain fart from a frazzled old brain......but the correct AN is Air Force/Navy.:)
    Some of the charts or kinda small, so click on them and see if they enlarge.
    EDIT
    There is a line on page 3 that says "Look at this TAPERED Pipe Chart and notice the Straight Pipe Threads. While editing I put that in the wrong place. It should have been on page 2 above and sjust below the picture of two fittings. It should have said "Compare the tapered and the straight fittings"
    vtx1800, Driver50x, warbird1 and 9 others like this.
  2. Motorwrxs
    Motorwrxs
    Appreciate the time it must have took to write this thread Feel I have a better understanding about the AN fittings and tubing size for sure.
    seb fontana and ekimneirbo like this.
  3. atch
    atch
    Thanks Mike;
    I'm saving these charts to my computer so I can find them the next time I need to refer to them.
  4. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Great explanation, thanks for providing this valuable information.
    KK
    ekimneirbo likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    @ekimneirbo , Thats a easier understanding for those that do not know fittings A&N ,Jic & pipe.
    Then comes Real complicated when trying to Navigate The catalogs from
    Eaton , Parker & 5 or so of
    Aroquip's catalogs.
    All the different hose's & Application and usage,
    Then you have the British / European
    Section
    ekimneirbo and Just Gary like this.
  6. DDDenny
    Pretty sure the AN callout equates to Air Corps/Navy.
    Toms Dogs, ekimneirbo and 19Eddy30 like this.
  7. Harv
    Harv
    from Sydney
    It's one of the curses of living Down Under. We started out using "imperial" units of measure (inches, pounds etc) and most of the stuff I work with uses those types of thread.
    We inherited some delightful threadforms with our British heritage - Whitworth, British Standard Br***, British Standard Cycle.... as Mater says "they ain’t metric, they ain’t inches, you never can find a wrench to work on them”.
    Then we went metric (metres, kilograms etc). When I pick through my parts stash, a bolt could be any type. I bought one of these tools, which really helps identifying:
    The AN fitting stuff has similar challenges. My fittings can be AN (37 degrees), SAE (45 degrees) or the weird 30 degree stuff used on some Lucas piping. Never a dull moment.
    Cheers,
    Harv
    nochop, vtx1800, Deutscher and 2 others like this.
  8. seb fontana
    seb fontana
    from ct
    ""We inherited some delightful threadforms with our British heritage - Whitworth, British Standard Br***, British Standard Cycle.... as Mater says "they ain’t metric, they ain’t inches, you never can find a wrench to work on them” I had a old 250 BSA engine that was perfect example! Bought a few of them thread checkers, come in handy..!
    nochop, ekimneirbo and alanp561 like this.
  9. Harv
    Harv
    from Sydney
    A youth spent playing with beezers (BSA's) is a youth well spent. As punishment for my sins, I am adapting three Amals to a Holden grey motor (similar to a Chevy Stovebolt 6).
    Cheers,
    Harv
    nochop, vtx1800 and ekimneirbo like this.
  10. ekimneirbo
    ekimneirbo
    from Brooks Ky
    You'd be correct.......thanks for pointing that out...............its just one of those things that my old brain forgot.:)
    I'll make the correction.
    19Eddy30 likes this.
  11. Boneyard51
    Boneyard51
    Thanks for the info! Working with huge ( think 75 foot rams) hydraulic systems and Firetrucks for 33+ years and dealing with farm tractor hydraulic systems for sixty years, I have a good understanding of threads , fittings and adaptors. But I did learn one thing! That is about the JIC vs AN! Back in the day, we had fitting that were called “ areo- quip” , I might have misspelled it. I believe it is the same as JIC. JIC fittings also had a taper on the inside of some of the male fittings that would seal on the swivel fittings! The first time I ran into this, I didn’t believe it! My dealer ***ured me it would seal…..and it did!
    Working with hydraulics most of my life I also had to deal with “ flange o’ring “ fittings a lot!
    In my youth I dealt a lot with feral fittings, don’t see much of those any more.
    They are coming out now with a lot of new fittings that will probably make the old fitting obsolete!
    Progress , I guess.
    Bones
  12. DDDenny
    I was a machinist for thirty years for a company that built machinery for the wood products industry, we had our own hydraulics department with bins upon bins of JIC fittings and related adapters, every one was made of steel.
    Having used AN hardware in drag cars and shifterkarts, the only difference I saw was that AN components were made from aluminum.
    Over the years some mfg's in the AN industry started offering their fittings and adapters with larger bores and radii, especially in 45 and 90 degree adapters for less restriction, not a real issue for general hydraulic applications where achieving higher pressures were more critical than volume.
    Driver50x and Boneyard51 like this.
  13. '29 Gizmo
    '29 Gizmo
    from UK
    In HAMB world we also have to deal with USS threads.
    dogwalkin likes this.
  14. Thanks for that information, it's the kind of stuff that can save you a lot of fiddling around for hours.
    When I was an apprentice one of the first projects we made were thread/clear/tap gauges for "American" (8/32 ect) and "British" (Whitworth) as we worked on both U.S. and British / European aircraft. I still use these gauges nearly 50 years later. I should make some for that "Tool of the Devil" (Metric) stuff, as it is creeping in everywhere here.
    Boneyard51 likes this.
  15. Harv
    Harv
    from Sydney
    JIC and AN are very similar, though AN is made to tighter tolerances. From memory, one of the two has a radiused thread root whilst the other is sharp-rooted. Can never remember which one though.
    Cheers,
    Harv
  16. Eh. Army/ Navy is correct. An fittings were invented during WW2. While air force didn't become a branch till 47
  17. DDDenny
  18. The Op is what most will deal with. I cant find much that isn't metric now. I have a metric and a SAE pitch gauge. The metric is used quite often. With a history in race cars and braided hoses, you quickly get used to dash - numbers and what threads accompany them. I have chosen to be adept at all that I mentioned. I still have Whitworth wrenches from my British bike days. Looking at the sizing on them will make you wonder what we missed out on. LOL.
  19. Driver50x
    Driver50x
    The “Army Air Corps” later became known as the Air Force.
  20. ekimneirbo
    ekimneirbo
    from Brooks Ky
    That's actually a really good source of info. I'd suggest that Hambers print a copy, especially the chart about AN thread size and put it in the drawer where they keep their threading and fitting stuff................
    Would like to clarify one thing.
    "Note that AN threads are different for bolts and fittings. In bolts the number refers to the diameter of the bolt whereas in fittings it refers to the OD of the tube and thereby have different threads.
    For example, AN6
    bolt has a 3/8 -24 thread.
    whereas an -6AN
    fitting has a 9/16-18 thread."
    That is a correct statement but people should realize that whether a 3/8-24 Thread is being used or a 9/16-18 thread is used.........the thread itself is "essentially" the same whether they are on a bolt or on a fitting. 3/8-24 is 3/8-24 and 9/16-18 is 9/16-18 . It's the AN designation that has a different meaning between nuts/bolts ...........and fittings.
    Even a a common Straight Pipe thread which is a different thing altogether uses the same thread sizes ...............but its a similar situation to the AN explanation. In a common pipe the designation 3/8 pipe refers to the approximate size of the hole in the pipe, not the external thread. So a 3/8 pipe could have a 9/16-18 thread on it.
    Where the common pipe varies is that most of the time when using that common pipe, they also have a "tapered thread" in addition to the straight thread version. The tapered thread is the more common type. So while it may also have a 9/16-18 thread on it outside, the taper makes it incompatible with straight threads of any other fitting.
    Here is a picture to show what I mean. Look at the silver fitting at the top. It"s left side is 1/4 STRAIGHT PIPE. Has nothing to do with the AN (JIC) system, but the thread on it is a 9/16-18 and it screws into a 9/16-18 nut.
    The Blue fitting screwed into the nut has 9/16-18 threads but its left end has 7/16-20 threads and they screw into a 7/16-20 nut and a thread gage.
    The two pipe taps in the lower part of the picture should say 1/4 inch pipe tap.......9/16-18 thread.
  21. DDDenny
    Get a copy of this book (he has others) by Carroll Smith.
    David Gersic likes this.
  22. Boneyard51
    Boneyard51
  23. Boneyard51
    Boneyard51
    Mike…how much would you charge me to come to your shop and look around and take notes? You are the most organized guy I ever saw ….with some cool stuff!
    Bones
    vtx1800 likes this.
  24. ekimneirbo
    ekimneirbo
    from Brooks Ky
    No Charge, you are always welcome. Why not attend the Street Rod Nationals this fall and you can come by my place.......but you will be welcome any time.:)
  25. Boneyard51
    Boneyard51
    Thanks , Mike! We have some family matters, I am caring for my 101 year old mother, so my travel options are limited at this time!
    Don’t feel sorry for me, though! Yesterday, we took here to a doctor and hearing aid appointments and ended up with a couple of hours to kill in town! So what did we do? We took here to a to our bar for a drink! Introduced her to some of the regulars, had a great time! Just don’t tell my sister!
    Bones
  26. deucemac
    deucemac
    I've been doing automotive and aircraft plumbing since Orville and Wilbur were young. I recently went into an aircraft hardware store and was corrected by the counterpart. I was told that AN was no longer valid. It was now MS! When I asked what the difference was, he replied that AN stop for Army/Navy and MS stood for Military Standard! When I asked what the difference was, he told me that they were still the same but now are politically correct! I guess I am getting too old!
    HemiDeuce likes this.
