Technical Help needed identifying 9" wheel cylinders!
Discussion in 'The Hokey Ass Message Board' started by Mr. C., Feb 8, 2025.
  1. Finally got some info:
    Drums are 10"
    Shoes 2.5" wide
    Brake cylinder casting number 29608
    Axle width to wheel mounting faces 57.25"
  2. swade41
    swade41
    from Buffalo,NY
  3. gary macdonald
    gary macdonald
    Need pics of the bottom front of the 3rd member , where the bottom studs come through.
  4. swade41
    swade41
    from Buffalo,NY
    I put this in Google
    Mr. C. likes this.
  5. swade41
    swade41
    from Buffalo,NY
    You could maybe do the same off the part number on the backing plate.
    There were some 57.25 wide rears but with your dimpled housing and no oil drain/fill hole it doesn't correspond to the correct years.
  6. nobby
    nobby
    you have 10 inch brakes so that is nice
    go on ebay and buy two rear cylinders of a 65 to 70 mustang from john woolfe racing, they are about 23 pounds each.
    they are 7/8ths though
    they may be alright......
    oh and what will really confuse you now is
    I think you have a heavy duty case, that NEVER came standard with
    SMALL BEARING housing ends. ford never made a heavy duty case that narrow stock
    these bearings are 2.88 inches around
    big bearings are 3 and a smidge inches - -
    so you do not have big bearing axle ends
    early or late style
    the actual t-bolts that hold the back plate to the bearing housing on yours are 3/8 10mm rather than 1/2'' big bearing versions, you have the aftermarket t-bolts
    anyways worth noting here is if you are pulling the shafts and your bearings are 2.88'' w202 - -is
    you will need to buy two paper small bearing gaskets and two oil s****er gaskets
    so your axle was a lets say a 60 inch wide heavy duty case axle and someone narrowed it
    what the perculliar thing is - why is it axactly 57.25'' wide
    i.e. that is 65 to 67 ford mustang width
    BUT
    you have what appear to be 31 spline big bearing half shafts
    now I only know because I had some that a 1971 mustang big block car runs these same shafts and brakes
    i think its 59.25 width though
    they are 31 spline shafts with the bigger drum register
    the innner diameter at the bearing IS the same as the 3 inch big bearing at 1.5 inches
    but its a 2.88 outer dimension
    so there you go.
    what i cannot fathom is how you get a wheel on when the leaf spring is so close to the narrowed axle
    oh and the brake rotor on the floor looks like a volaire or 74 charger disc
    and your rear drum looks like a 1980 ford ltd
    or simply
    in 1967 ford take a 8'' axle fit the tubes and bearing ends into a 9'' centre
    take 31 splined shafts cut to 57.25, fit the adaptor rare beearings 1.5'' to 2.88
    run the 2.5 backplate
    fit a 10'' 2.5 drum
    fit it into a 67 shelby cobra something or other that 1. needs the axle tubes to be 2 3/4'' rather than 3'' so they can run the stock leaf springs/saddles and stuff
  7. This may well confuse you further. If it has indeed been narrowed then the width will have been to suit the A-Body Mopar it's sitting under (photo removed by Admin - no idea why?).
    The rear tyres are 245 and are very, very close, to both the leaf spring and the wheel arch trim.
    The half-shafts and diff are 28 spline.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. No problem, thank you for the explanation. I knew I'd seen later stuff on here but I now see there is an "Off Topic" section so was probably there. Apologies for posting the photo.
    Moriarity likes this.
  10. [​IMG]
    There you go, by way of retribution for the '71 model photo. Here's my '38 instead :)
  11. DDDenny
    You are forgiven.
    seb fontana, Mr. C. and Hotrodmyk like this.
  12. :D
  13. Just FYI. These are the correct cylinders:
    swade41 likes this.
  14. BJR
    BJR
    Meant something totally different in the late 60's and early 70's. :p
  15. ^^^^ Yeah, I remember those days. Was not my thing though.
