History BBC finned aluminum oil pans
Discussion in 'The Hokey Ass Message Board' started by mohr hp, Feb 13, 2025.
  1. mohr hp
    mohr hp
    from Georgia
    I'm hunting for one, to go with my Big Block Cal Custom valve covers. Looking at reviews, it seems the chinese one that Summit and Amazon carry is pretty awful fitting, but I haven't had it in my hands. So I've been searching the web for an oldie. Trouble is, I don't know who made them? Cal Custom? Eelco? I don't like the Mercury Marine one so much, kinda weird shaped. Any insight?
    Tow Truck Tom likes this.
  2. Jmountainjr
    Jmountainjr
    I belive your correct that Cal Custom, and perhaps Elco made cast aluminum oil pans. You didn't mention what ch***is. I have a collection of cast pans, mostly marine, but they hang on the wall. Cast pans shatter when hit. A protection plate helps, but they typically only protect a portion of the bottom. Depending on the ch***is, the Mercury marine pans have some advantage with the elongated sump area. The pans are very good quality, have good baffling, and a good windage tray. I know you mentioned you were not attracted to the Mercury pan. But if it fits your ch***is, it would be a good choice if you are really set on wanting a cast pan. Bead blast with used gl*** beads and spray with some Gibbs.
    Tow Truck Tom, mohr hp and Deuces like this.
  3. I think the other thing to think about is that every one that I've seen as of late have no windage trays, no baffles, etc.. If you like to flog the thing a bit - having some oil control isn't a bad thing.
  4. mohr hp
    mohr hp
    from Georgia
    Lets call it a T-bucket. Plenty of room for sump.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Since you said "plenty of room for sump", some big block powered boats had finned aluminum oil pans...in fact, I've got one somewhere.
  6. swade41
    swade41
    from Buffalo,NY
    I've got one of those cast marine pans I plan on polishing one day for a wall hanger.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    If mercury pans are shallower , do they have a special oil pump ?
  8. mad mikey
    mad mikey
    I had one of those from Summit years ago, did not fit well at all and leaked . Don't bother trying one of those.
    Tow Truck Tom and SS327 like this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Baffles , windage trays & crank s****ers can be added attached to main studs & pan rail , not mandatory to be integral to the pan ..
    mohr hp likes this.
  10. Jmountainjr
    Jmountainjr
    Perhaps the term shallower was misleading. The Mercury marine pans take a standard depth pump. The sump is elongated and relative to the front portion and have a bit more capacity.
  11. Jmountainjr
    Jmountainjr
    Mercury marine cast pan showing internal cast baffles and conventional windage tray.
    mohr hp, mad mikey and kadillackid like this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    IMG_E6274[1].JPG IMG_E6275[1].JPG IMG_E6275[1].JPG Here's another Marine one. And it's available! Stout enough to serve as a girdle.:D
    P.M. me if interested.
