Art & Inspiration Chrysler long ram measurements
Discussion in 'The Hokey Ass Message Board' started by SuperKONR, Feb 12, 2025.
  1. SuperKONR
    SuperKONR
    from Earth
    Anyone know the overall width of a Chrysler long ram intake setup, with and also without the factory air cleaners? Trying to figure out if they'd fit between the fenderwells of a different car...
    Sharpone likes this.
  2. Deuces
    Deuces
    Bump!......
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  4. Rickybop
    Rickybop
    My setup isn't on an engine, it's sitting on my dresser in my bedroom lol. But if I position it as it would be on an engine, I can get you close. Center of carb to center of carb is right about 3 feet. That's to say 36 inches. Carburetor bodies stick out roughly four to five inches each side. Depending on if you're using a Carter or a holly. Also a little difference between a 650 CFM and a 750 FM. Air cleaners aren't real big. Maybe 10 inches in diameter? So about the same as the carburetors themselves.
    36" + 10" = 46" total
    Be aware that many if not all big block Mopar engines were mounted a little bit biased to the p***enger side. I don't know, an inch or two?
  5. Rickybop
    Rickybop
    Many guys who want to use the long ram intake on a car that isn't quite wide enough will actually cut a portion out of one or both of the inner fenders.
    Deuces, Just Gary and Sharpone like this.
  6. Rickybop
    Rickybop
    Seems to me I found this information on the internet a while back. But I'm not sure now.
  7. TCTND
    TCTND
    When I sold my '40 pickup 30 years ago the kid who bought it dropped in a 413 with a cross ram. He butchered the inner panels, the fenders, and the hood to make it fit. I wanted to shoot him.
    Deuces likes this.
  8. Rickybop
    Rickybop
    Can you tell us what you're wanting to put it in? I've heard they won't fit in a b-body Mopar without t******* the inner fenders. The amount needed to be removed for clearance isn't usually very much.
    Just don't get shot. :rolleyes:
    SuperKONR, Deuces and Sharpone like this.
  9. Rickybop
    Rickybop
    Btw... the dimensions I gave you would be if the long ram is mounted to an RB engine. 413, 440. If it's mounted to a narrower B engine such as a 383, the overall width of the long ram would actually be an inch or so more.
  10. 57Fury440
    57Fury440
    I had a setup on my 57. I did not have to trim anything, and they fit with fender well headers.
  11. SuperKONR
    SuperKONR
    from Earth
    @Rickybop You da man, thank you sir!!
    It's a far-in-the-future project, I'm thinking of putting a 413 with a crosss ram and an A-833 into a 57 Chevy sedan. Just wondered if it would be feasible before I started spending money gathering parts.
    I had a 454 on the shelf for the car but decided it wasn't an early enough engine for my "period correct" brain. Want something closer to 1959-60 if I was going to do an engine swap. After seeing a post on here about a Nailhead in a '57 I've decided I either want to do a 401/425 dual quad or the 413 cross ram setup. The 413 would certainly be easier to fit a 4 speed to vs the nailhead. I have pictures of a BBM powered 57 drag car from back in the day so I know the 413 would fit but I wasn't sure if a cross ram setup would fit.
    Thanks again for the info guys I appreciate it!
    Deuces, Sharpone and Just Gary like this.
  12. Sharpone
    Sharpone
    Sounds cool to me,keep us posted when you build
    Dan
  13. Rickybop
    Rickybop
    No problem putting the long ram in a '57 Chevy.
    Big problem when the ******** Chevy and Mopar guys all decide to kick your *** at the same time.
    :D
  14. Deuces
    Deuces
