Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
  2. justabeater37
    justabeater37
  3. justabeater37
    justabeater37
  4. Tim
    Tim
    from KCMO
    Looks slick!
  5. hiboy32
    hiboy32
    from Omaha, NE
    I too ran simple toggle switch and a pushpull cable for many years. It isnt hooked up presently for any real reason
    Algoma56 and Tim like this.
  6. Rand Man
    Rand Man
    I have not kept up on this thread. I opened it up, and I think “wooa, he’s gone with a flathead now?
    mad mikey, Stogy and Tim like this.
  7. Tim
    Tim
    from KCMO
    @highboy32 you and Jay running the overdrives is partially what got me excited about this one. I had one in my 53 ford but I never managed to get it working before I got rid of the car.
    Algoma56 and nochop like this.
  8. Tim
    Tim
    from KCMO
    @hiboy32 @Rocky @justabeater37
    most of these seem to be in six volt cars, any issues putting 12 through it or should I just step it all down for the over drive components?
    Algoma56 likes this.
  9. justabeater37
    justabeater37
    They make all of the parts in 12v
  10. Six Ball
    Six Ball
    from Nevada
    I think the only volt sensitive part is the solenoid. 12 volt ones are out there and if you had to you could have a 6v re-wound. As far as I can tell all of the solenoids are physically interchangeable except for the Saginaw 3 speed which has a longer plunger rod and a flat spot on the cover. Don't EVER throw a solenoid away. They can be repaired and the most common failure is a simple fusible link under the cover that can be re-soldered. A very important feature is the reverse kick out switch, lock out switch in the diagram above. It is on the back of the case and activated internally when the trans shifts into reverse. Some older units don't have this and it is necessary to manually disengage the OD before backing up. These things do not tolerate being turned backwards. They are fun to drive and pretty trouble free if cared for. Studebaker published an overdrive booklet fully explaining them.
    Lots of parts listed on eBay.
    Algoma56, Thor1 and Tim like this.
  11. Tim
    Tim
    from KCMO
    Cool might have to see if I can find that booklet. Thanks for all the info guys :)
    Six Ball likes this.
  12. nochop
    nochop
    from norcal
    I did something similar, added a momentary switch to the throttle pedal for the t400 kick down solenoid and added a wot stop at the same time Seems like those little tiny projects take more brain cells than setting up steering, suspension and brakes.
  13. Tim
    Tim
    from KCMO
    @nochop at least they don’t weigh 700 lbs to move around lol
    Six Ball and nochop like this.
  14. Six Ball
    Six Ball
    from Nevada
    I have the booklet, maybe two? I'll check.
    Tim likes this.
  15. Rocky
    Rocky
    Classified Editor
    Like justabeater37 said...solenoids are available in 6 or 12 volts. I always used 12 volts in all my projects.
    Six Ball and Tim like this.
  16. 05snopro440
    05snopro440
    I believe this RPU has the 32 grille and splash apron idea you were seeking, but maybe not so much on the section.
    brEad, mad mikey, Thor1 and 6 others like this.
  17. Tim
    Tim
    from KCMO
    Slick looking truck!
    got delayed by the weather but the fan showed up today. I bet it’s no more than 1/8” thick, I need to enlarge the center hole and then I can mock it up. Just need the shop to get above freezing. Maybe next week. IMG_8408.jpeg
  18. Tim
    Tim
    from KCMO
    Should be above freezing in a couple days. Untitled_Artwork.jpeg heres that truck with the grill sectioned in the mean time
    brEad, Thor1, mad mikey and 4 others like this.
  19. Seeing your new fan made me laugh. I got a 13" Derale fan two days ago. I put it in place and now know that I'll need a one-inch spacer to move it forward so that it doesn't conflict with the crank pulley but it looks like a good fit. I wanted to have a larger fan but really couldn't go much larger than 13" without taking out the transmission cooler lines. I'll see how well it cools and, if necessary, fabricate a shroud to pull air through the upper one-third of the radiator.
    Thor1, Stogy, mad mikey and 2 others like this.
  20. Tim
    Tim
    from KCMO
    Yeah I’ve yet to mock it up but I’ve got my fingers crossed. I think I could “in theory” fit the 18” but went with 15”. Seems a pretty standard size and I had concerns about an 18” fan swinging into who knows what, or compromising spaces for hoses and etc. should be above freezing Sunday so we’ll see!
  21. 05snopro440
    05snopro440
    Does that give the look you were seeking?
    osage orange likes this.
  22. Tim
    Tim
    from KCMO
    @05snopro440 yup pretty much what I had in my head when exploring that option :)
  23. Tim
    Tim
    from KCMO
    Well sitting it on the water pump pulley I’m gonna say I’ll have room. IMG_8423.jpeg also saw this Stude powered hotrod I think @Stogy found online. IMG_8421.jpeg
    Thor1, Tim_with_a_T, Stogy and 2 others like this.
  24. I saw some Studebaker heads listed on our local CL today, if you're considering some extras.
  25. Tim
    Tim
    from KCMO
    Stogy likes this.
  26. Six Ball
    Six Ball
    from Nevada
    There are a few different heads. He sure to check the numbers. The heads were a limiting factor for these engines at the top end. John Erb was woking on a New head. He showed one to me and said it was Studebaker on the outside & LS on the inside. I don't know where those went when he died and I doubt that anyone is following up on that project. He had all of Lionel Stone's stuff too.
  27. Tim and Stogy like this.
  28. Tim
    Tim
    from KCMO
    Thanks @osage orange
    @Six Ball yeah seems a lot of this odd ball stuff that has had neat stuff coming down the pipeline ends up having the original guy die, stuff moved onto the next guy where it sits in their shelf til they die and then it sorta just disappears into the haze. Bummer for what has to be a pretty crazy amount of time involvement on a lot of these things.
    Thor1, Stogy and osage orange like this.
  29. Six Ball
    Six Ball
    from Nevada
    Even guys like me who are far better at gathering pieces for a project than putting them together & out the door. At this point I need to bundle the components for each project so they can stay together rather than be re-gathered. :D
    I hate to think of all the good, even rare, parts that my friends' families have s****ped.
    Thor1, Tim and Stogy like this.
  30. Stogy
    Stogy
    @Tim...I've been in and out here and was back tracking a bit on your Thread and saw Rand's mention of Flathead. I thought you redirected again but your still Stude bound. Good on you...there was a fella our way here that p***ed a while ago and he was a Stude guy through and through. I know a another car friend who bought one or more of his cars. Parts? Not sure but I can ask...if he doesn't have maybe he knows...so if you have specific needs share any previous posts with the list or pm and I'll send an email. There's a chance the family may have stuff I'm not sure...
    The fella that p***ed was well aware of hi-po Stude as he has multi carb set up with other details on one he had that I saw at a show...
    I know your a distance away but it may be budget friendly, never know...
    Since we're talking Studebaker here's some vintage pics from Perth...a small town 20 minutes away from me...don't know what the celebration was that day but these cars were part of it...I get a chuckle about seeing fido enjoying the farm fresh droppings by older transportation on the road in the first pic...:D
