Hot Rods Thermostat housing leaking???
Discussion in 'The Hokey Ass Message Board' started by jeff47wl, Feb 15, 2025.
  1. jeff47wl
    jeff47wl
    from sunnyvale
    Question on thermostat housing gasket. (pictures)
    Should I use the rubber O-Ring only (with or without gasket sealer?)
    I have never used an O-Ring before.
    Use the Fel-Pro gasket only?
    Should gasket sealer be used?
    Any input would be welcome.
    jeff
    bob b. likes this.
  2. bob b.
    bob b.
    from peoria az.
    I have offen wondered the same thing
  3. abe lugo
    abe lugo
    I put good stuff if I have it. But the orange one works too. Always use sealer.
    Check if your housing is flat once cleaned
  4. BJR
    BJR
    The gasket with the O ring will keep the O ring from compressing. So no gasket with the O ring.
    chevy57dude and CSPIDY like this.
  5. deathrowdave
    deathrowdave
    from NKy
    Have to have good clean mating surfaces for oring . Dry no sealer . I have seen where is no mating surface on the intake to mate to oring
    Sharpone likes this.
  6. David Gersic
    David Gersic
    from DeKalb, IL
    If it came with an o ring, it’s designed to seal with an o ring. Use that, not the gasket.
    chevy57dude and 2OLD2FAST like this.
  7. alanp561
    alanp561
    I've never used anything but a gasket and Permatex II. Never had one leak.
  8. MCjim
    MCjim
    from soCal
    Use some Oring grease, if you're really conscientious...
  9. squirrel
    get rid of that housing, get one that's like the original, one piece of cast iron or aluminum, designed to use only a gasket.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, squirrel is right. Those chrome O ring housings are junk. They warp when you tighten them. Get a normal one and use a gasket
  11. DDDenny
    Yep, you will never distort one of these GM cast iron thermostat housings.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    You mean I've gotta take off the Oring type that's been on & off many times for manifold changes , etc & has never leaked a drop in 25 years , that seems silly . How about don't buy junk & learn to install things properly . Too bad some have had problems .
    Mr48chev likes this.
  13. squirrel
    yours isn't leaking, why would you change it?
  14. chopolds
    chopolds
    from howell, nj
    I always use an original iron one, and get it chrome plated.
    Moriarity and Tow Truck Tom like this.
  15. lothiandon1940
    lothiandon1940
    ...Not only do they warp when tightened, but the chroming process itself tends to warp them. Ditch the chrome one. I try to keep a few GM ones around in different configurations. 20211114_164808.jpg
  16. lumpy 63
    lumpy 63
    If you need a straight up type housing a Mopar one will work.
  17. 19Fordy
    19Fordy
    2/16/25 If your thermostat is warping, your probably over tightening it. You might want to try installing it using both the O-ring and paper gasket together along with some non-hardening Permatex Gasket Sealer.
  18. DDDenny
    Or you can whittle one up!
  19. squirrel
  20. vtx1800
    vtx1800
    It is easy to say to use an "original" when the "original" will point it the correct direction. That is not always the case and I don't have the equipment nor expertise to fabricate one from scratch. I don't like the O ring style and always fight them to not leak but in my case that is the only way to get the coolant to the radiator. I use "just a dab" of silicone gasket to the o ring after running a flat file on the mating surface.
  21. guthriesmith
    guthriesmith
    I have had nothing but bad luck over time with the o-ring style. Even if they seal when new, I have had the chrome corrode bad enough that they start leaking. I run original thermostat housings anymore as has been mentioned. I’m sure there are decent ones. But, cast iron ones always work great with a gasket and some sealant.
  22. MCjim
    MCjim
    from soCal
    Just to add to the confusion:
    Great for low mounted radiators
    swade41 and Sharpone like this.
  23. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Maybe the gasket is there to keep from overtightening it and warping it when the o-ring is in place..........:D:D:D
    Since you already have it, try it out and see how much gap there is when you just set it in place with only an O-ring.
    If its very much, try it with both the o-ring and gasket or just the gasket. If it doesn't work and does leak, its not that hard to replace it..............
  24. If the new one is all you have at the moment, use it with your choice of O-ring or gasket. Don't be skeered. If it doesn't leak, you're done. If it leaks, it's right there in your face. Take it off and do something else. Don't overthink it.
    It shouldn't warp from bolting it down. If it does warp or leak, you've done something weird.
    MCjim and guthriesmith like this.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    According to the x-spurts here. They're all junk , I wouldn't want junk on my car , right?
  26. squirrel
    you can run that junk on your car if you want. That's your problem.
  27. i7083
    i7083
    If you use it, take any chrome off the mating surface and be sure it's flat.
  28. 2OLD2FAST
    2OLD2FAST
    from illinois
    It's your advice column ....
  29. 19Eddy30
    19Eddy30
    from VA
    My self I over years have used OEM ,
    & all the other mentioned above & more, Some leak , trued up with file ,
    Intake & housing .
    Unless cracked ,some can weld , some not.
    Something I just experienced in the last two weeks, My cars are garage kept,
    In one of my Blown engine I run water with weepier, Its been under 30 degs @ night here , when I wanted to test , So I did not want to take a chance of freezing up radiator while driving / testing @ night , temp was staying @ 160-170 engine block with a 195 thermostat, shocking but So ,
    I have 3 temp gauges One on each side of heads , & One near thermostat.
    So I drained all water & even @ bottom of block both sides , 3 plugs .
    Filled up with 50/50 , after change I did not get to test Rain & snow ,
    Car setting in shop , afew days later
    Coolant puddles under car , started looking around to see where leaking,
    Then see leaks from several places ,
    From pipe threads , I run lines from back of intake to front to a thermostat box I modify and made before thermostat, & hose clamps ,
    Shocked / puzzled . No leaks with Water , but with 50/50 leaks .
    So thinking Antifreeze thinner & oily.
  30. Mr48chev
    I'd have to say from what I have seen personally the number of people who have trouble with those particular thermostat housings may be larger than the number who have never had a problem with them. I have never had one but know several guys who have had them and gave up on them because o leaks.
    I'd say the key to success is having a perfectly smooth flat mating surface on the manifold, having a thermostat that the shell isn't too thick on and sticks up above that surface on the manifold and the housing is in perfect shape and not one you got at a swap meet for three dollars that had already been on someone else's engine. Plus the correct O ring and not just an out of the O ring selection box one.
