Customs I need to knit a Stromberg single barrel to a Thickstun dual manifold
Discussion in 'The Hokey Ass Message Board' started by Semmerling, Feb 15, 2025.
  1. Semmerling
    Semmerling
    Friends,
    Is there a good source for single barrel carburator adapters to move between the earlier 1 1/2" Stronberg throat to the later wider manifolds? I appreciate any help that could be provided.
  2. tubman
    tubman
    Speedway Motors makes a couple they say go the other way (one barrel to 97/94 pattern). I would think any clever Hot Rodder could figure out how to run one upside down.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Are you talking about one barrel carburetors?
  4. Semmerling
    Semmerling
    20250215_130330.jpg Yes, Single barrel carbs, just like the ***le says.
    In this case these restored older Strombergs with 1 1/2" id throat to the later Thickstun Dodge dual manifold with the slightly larger 1.65"
    Thanks for the help, didnt see an offering on the Speedway Motors site.
    1952henry likes this.
  5. tubman
    tubman
    Sorry. When I see Thickstun, I think flathead Ford unless specified otherwise.
  6. 1952henry
    1952henry
    No help from me, but have to say those carburetors look nice. No spray can wizard touched those.
    RodStRace likes this.
  7. Joe H
    Joe H
    When I went from a larger based carburetor to the smaller Carter W-1, I used some Garolite sheet material from McMaster Carr ( Bakelite ) and an offset stud I made. I used one of the original holes, cut the Bakelite to match the Carter base and bolt spacing, then put the offset stud in the other hole. The Bakelite had one elongated hole for the offset stud. I simply welded one stud to the other with the correct offset. The Bakelite is 3/8" think and has held up for years with no issues. I radiused the lower hole diameter of the spacer to blend into the larger bore of the intake. It you used a much thicker Bakelite, you could make a really nice blend area, my 3/8" only allowed for a small radius. For the offset stud, I used two bolts with the heads cut off. With an offset stud, I didn't need to change the manifold spacing or elongate the holes in the carburetors.
    37StudeDictator likes this.
  8. Kevin Pharis
    Kevin Pharis
    from Califunny
    I make several sizes of Winfield to 2 bolt adapters, and have made 2 bolt to 2 bolt adapters too. Some setups need the additional height, while others are better off with a flat plate style. Minimum height for this “drop flange” style is about 1-3/8”, but could be shorter if the flanges are not inline.
  9. ALLDONE
    ALLDONE
    speedway sells the W1 2 bolt to 3 bolt stromberg/holley....30 bucks
  10. ALLDONE
    ALLDONE
  11. tubman
    tubman
    It helps if you read a thread before replying to it.:rolleyes:
  12. ALLDONE
    ALLDONE
    yeah, I see where you messed that up also...
  13. ALLDONE
    ALLDONE
    In this case I would just weld up the holes and drill and tap the new holes...I'm putting 2 hi-performance jeep carbs on all my bangers... so I was in the w1 to holley stromberg mode...that and I'm not familiar with the mount size of a stromberg 1 barrel, or even which one is being used
  14. tubman
    tubman
    Yeah, but I had a good reason since he didn't specify the make of car he has.
    What's yours?
  15. ALLDONE
    ALLDONE
    the 97 /94 are 3 bolt...now I'm total confused... the W1 are 2 3/4 bolt centers...2 bolt..... whats the bolt centers on the stromberg 1 barrels???
  16. ALLDONE
    ALLDONE
    I have nothing...lol... this is nothing like what I pictured....
  17. ALLDONE
    ALLDONE
    what CFM are those... and what do they go on????
