Technical Ok, Ford FE gurus let’s talk
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 18, 2024.
  1. birdman1
    birdman1
    be sure to clean all the oil p***ages and the rocker shafts. They store sludge.
    Roothawg likes this.
  2. 53 effie
    53 effie
    I've been told they will work.. if you notch the frame rail a bit on the p***enger side. I haven't done it myself. 2wd only I believe..
    bchctybob and SilverJimmy like this.
  3. Roothawg
    Roothawg
    I need to go and pick up the 360 I scored. It's in Fort Worth and the weather has been ****.
    bchctybob and Jeff Norwell like this.
  4. 2devilles
    2devilles
    How the p***enger side points straight back would be my main concern with it pointing straight at the firewall, but if it's short enough might be able to connect the exhaust and bend it down toward the ground right away. Most the aftermarket headers for the 2wd '67-'79 fit and function great, been running the ****** headers on my daily '74 for about 100k miles, and it gets driven from -20 to 100+ degrees year round. No leaks, no fuss.
    Roothawg and bchctybob like this.
  5. Roothawg
    Roothawg
    Just bringing this up for my FE fix. No hot rod time for me.
    I retired in May and still haven't driven the 3 hours to DFW to pick up the 360 block my buddy has. This house/shop build is consuming my every waking minute.
    bchctybob, Boneyard51, NoSurf and 2 others like this.
  6. Beanscoot
    Beanscoot
    That's good that you are spending all the time on the buildings, it will pay off in the end.
    Boneyard51 and Roothawg like this.
  7. Roothawg
    Roothawg
    Man I hope so…
    Boneyard51 likes this.
  8. sidevalve8ba
    sidevalve8ba
    You know the nice thing about retirement? Every day is Saturday!!! :)
    Boneyard51, Deuces, deadbeat and 2 others like this.
  9. NoSurf
    NoSurf
    Time for the drive down there. Just bite the bullit and go.
    sidevalve8ba and Roothawg like this.
  10. Roothawg
    Roothawg
    Trying to work a deal with Dan Hay. He frequents DFW and OKC.
    bchctybob, Boneyard51 and NoSurf like this.
  11. Roothawg
    Roothawg
    So far it seems like every day is Monday…
  12. 53olds
    53olds
    Here's some inspiration for ya..it's just mocked up but I just got some aluminum heads brand new off marketplace!
  13. Roothawg
    Roothawg
    Nice!
    Deuces likes this.
  14. Roothawg
    Roothawg
    bchctybob, Boneyard51, Deuces and 4 others like this.
  15. Beanscoot
    Beanscoot
    Holy Moly! You're shipping that ****er by air?
    Boneyard51, Roothawg and Oneball like this.
  16. Oneball
    Oneball
    Those 4 pistons don’t look like anything bad has happened to them.
  17. Oneball
    Oneball
    :D:D:D:D
    I’m more worried what’s in the barrels!
  18. Roothawg
    Roothawg
    Ha ha….no . I just retired from the FAA. That is one of our C90’s in the background. It’s going to s**** as we speak. The big storm in FTW caused the hangar door to fall on it. IMG_1863.jpeg IMG_1116.jpeg
  19. Roothawg
    Roothawg
    That’s just Jet A fuel. They are defueling it, so they can s**** it.
  20. Beanscoot
    Beanscoot
    A real shame, it looks like it could be fixed, but of course 'plane stuff is very strict.
  21. Roothawg
    Roothawg
    They were reducing the fleet size anyway. They will part it out.
    bchctybob likes this.
  22. Sharpone
    Sharpone
    Turbine car
    Dan
    bchctybob and Roothawg like this.
  23. Roothawg
    Roothawg
    The eagle has landed.
  24. saltflats
    saltflats
    from Missouri
    My brother had sent me a picture of the brake for the jet he fly's. $50,000.00 for one wheel exchange
    bchctybob, Sharpone and Boneyard51 like this.
  25. Roothawg
    Roothawg
    Yup.
    bchctybob and Sharpone like this.
  26. Roothawg
    Roothawg
    Here she is in all her glory. Thanks to @Dan Hay for getting it here.
  27. Looks like some I have started with. If you're lucky, it won't need bored. :)
    Sharpone and Roothawg like this.
  28. Dick Stevens
    Dick Stevens
    He has stated that he is going to build it as a 445 stroker motor, so that isn't a concern! See post #303
  29. Roothawg
    Roothawg
    It doesn’t have a much of a ridge, if any, but I would guess it is somewhat egg shaped. I just need the block and a few odds and ends. I’ll buy the aftermarket aluminum heads and a stroker kit, so it should weigh in about the same as a sbc.
  30. Boneyard51
    Boneyard51
    IMG_2010.jpeg IMG_2011.jpeg Root, I know you were checking on the Kugel shorties , real nice manifolds! I didn’t go all the way back on the posts , but I believe you are putting the 445 in a 56 Ford pick up? Those years seem to have the steering box right in the way of everything! We put a 312 in a 56 back in 65 and had to use a p***enger side exhaust on the drivers side, kinda Frankestien rig , but that was all the was available to us at the time! Might want to check into a set of center dump FT exhaust, big and dump in the right spot, usually cheap when you find them! You have to weld up a port on each.
    Just some more things to think about!
    Bones
