Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    IMG_20250217_174905.jpg I did this 390 caddy crank at work
  2. patsurf
    patsurf
    well,then it looks pretty straight forward--get to it anthony
  3. saltflats
    saltflats
    from Missouri
    I can show you what I'm not working on. :(
  4. Damn Snow. I need Springtime in the worst way.
  5. saltflats
    saltflats
    from Missouri
    I hear you Andy, this car needs to be done for racing season. The good deal is I have my ba*****t that is nice and warm to work on the 37 when weather gets bad.
  6. fastcar1953
    fastcar1953
    It's suppose to be in the 50's next week. Hang in there , it is Missouri.
  7. fastcar1953
    fastcar1953
  8. When I bought my Kaiser at Gene's Winfields liquidation auction a year or so ago That car had been parked probably it since the 1960s in the desert (at gene shop in the back 40 so to speak) out past Muroc (Rodgers now) dry lake. Anyways that car was so dirty, I have literally gotten on the creeper underneath it with it on jack stands with the garden hose and the spray nozzle and of cleaned out probably shovel loads of fine silty desert dust out of all the cracks and crevices... Every time I think I got it all I end up with more dirt in my eyes when I am wrenching on it.
  9. vtwhead
    vtwhead
    ^^^^^^^certainly envious of those temps! High of 19 today same as yesterday but with 30 mph winds.
  10. Slow down
    Slow down
    Just staying warm and having fun way better than watching the tv IMG_1761.jpeg
  11. neilswheels
    neilswheels
    from England
    My 348 'seized' due to the lube going hard on the rods, literally locked up. All ok now though after a rebuild..
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    Putting F100 brakes on my 40
  13. Mark, that should make a big improvement. Your original brakes remind me of the Huck type on Papaw. I’m putting the Bendix type on, like yours.
  14. chevyfordman
    chevyfordman
    porkshop and Sharpone like this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    The stock 40 spindles. Needed to grind them a little on the top for wheel cylinder clearance
  16. lumpy 63
    lumpy 63
    After putting F100 brakes on my roadster I would probably never use the 48 and older brakes again :D
    Sharpone and Truckdoctor Andy like this.
  17. 57 Fargo
    57 Fargo
    What no disc brakes? Don’t you know you will die driving an old car with drum brakes? :)
  18. deathrowdave
    deathrowdave
    from NKy
    You guys on the west coast really have it made , NO RUST to deal with . Lookin good my friend
  19. DDDenny
    You obviously haven't been to The Great Wet North, you know, North of California!:D
    No salt used on the roads here for snow but we know rust.
    JD69, Tickety Boo, Sharpone and 3 others like this.
  20. silent rick
    silent rick
  21. jimmy six
    jimmy six
    Replacement pistons with my favorite rods have finally installed in the GMC after the mishap at Bonneville last year. I had to wait quite a few weeks for the rings. Pan has been cleaned will be installed tomorrow.
    While waiting for parts the cylinder head I used the first 5 years had to be recalled from under the bench where it’s been since 1981. It needed a lot of upgrading to match the last one since it was junked (see photo). The parts were made into a trophy for the driver, my grandson, for a Christmas present. Still a ways to go but no parts left to purchase. Racing oil sure has gone up $$$. Fire bottles need their bi-yearly inspection and there is a possibility of a rear gear change but the whole crew will make that decision. IMG_6619.jpeg IMG_6618.jpeg IMG_6799.jpeg IMG_6875.jpeg
  22. 1pickup
    1pickup
    Decided that 28 louvers @ $5 or so a hole, ain't happening on this stupid heater project for a vehicle that may never see the road, so I did them by hand. Cut by hand with an air cut-off wheel, cleaned up a little with a hacksaw blade, and hand punched with a wooden die (male) & a piece of steel tubing (female). Not perfect, but I don't care. I think it will work, and that was main objective. It's supposed to be a shop truck, not a show car.
    and a shot of the backside, before I bolt the fan back on:
  23. Sharpone
    Sharpone
    IMG_1991.jpeg View attachment 6326068 IMG_2713.jpeg IMG_2893.jpeg IMG_2895.jpeg IMG_2930.jpeg IMG_2931.jpeg IMG_2937.jpeg IMG_2951.jpeg IMG_2952.jpeg IMG_2953.jpeg Dirt Cheap Dart engine transplant, spray bomb overall, removed from donor, cleaned, replaced freeze plugs ( that’s what they’re listed as at the part store - so don’t shoot me:eek:) Cleaned the oil supply galley to rocker shaft on drivers side, didn’t look to be getting as much oil as p***enger side. Had the bright idea to remove transmission then remove torque converter so I can run on stand HA! This ain’t no SBC Toto, ring gear is on the torque converter not the flex plate on Mopars. Waiting on Distributor, wires, valve cover gaskets and true roller timing set.
    I’m sure I’ll have this in and out of the Dart as I make mounts, exhaust etc.
    Dan
  24. chevy57dude
    chevy57dude
    Rattle can rebuilds powered some of my favorite cars over the years!
  25. lumpy 63
    lumpy 63
    20250220_162502.jpg 20250220_162424.jpg Stripped the front end off the donor, wire brushed the backsides and brushed em with rustoleum.
  26. Sharpone
    Sharpone
    What engine in the donor?
    Dan
    porkshop and chevy57dude like this.
  27. lumpy 63
    lumpy 63
    It has the oddball trophy 4 which is half a Pontiac 389:cool:
  28. Sharpone
    Sharpone
    That’s what I thought, the car @corncobcoupe bought has one those, never had one but they intrigue me, I’m thinking you use some of the performance stuff from a 389 to make a good running banger. Might be fun in T bucket.
    Dan
  29. lumpy 63
    lumpy 63
    20250220_180617.jpg 20250220_180614.jpg I am kinda doing a copy of what Mickey Thompson did with a brand new 62 tempest. Yanking the slant 4 and installing big honking Pontiac V8
