Projects 1940 Willys Coupe Gasser Build
Discussion in 'Traditional Hot Rods' started by Inland empire hot rods, Jul 22, 2022.
  1. Inland empire hot rods
    from so cal
    Well the car is home for a month or so, I'm mounting the dash and fixing an issue with roof at rear corner and rear window 20240825_194911.jpg 20240825_194923.jpg 20240826_205108.jpg 20240826_205112.jpg 20240825_194911.jpg 20240825_194923.jpg 20240826_205108.jpg 20240826_205112.jpg 20240826_205733.jpg 20240826_205259.jpg 20240827_193427.jpg 20240828_163532.jpg 20240828_183524.jpg 20240828_183537.jpg 20240828_183553.jpg
  2. Inland empire hot rods
    from so cal
  3. 55 gasser pickup
    55 gasser pickup
    from utah
    Man, if I saw that rig heading down the interstate going the other way, I might break my neck trying to get a better look!
    -Brent-, slayer, Thor1 and 8 others like this.
  5. Inland empire hot rods
    from so cal
    Thank you
    mad mikey likes this.
  6. Inland empire hot rods
    from so cal
    Haha me too! Thanks!
  7. Inland empire hot rods
    from so cal
    Well the progress has started again, slow but steady, firewall is in. 20250205_115840.jpg 20250205_120706.jpg 20250205_120714.jpg
    60'shotrod, brEad, -Brent- and 13 others like this.
  8. patsurf
    patsurf
    Thor1, 31chevymike and 427 sleeper like this.
  9. Inland empire hot rods
    from so cal
    Neck and neck to see who can take longer lol. Thanks!
  10. Inland empire hot rods
    from so cal
  11. ASBO
    ASBO
    from KERNOW
    Amazing work
  12. Inland empire hot rods
    from so cal
    Thanks!
  13. X2!!
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Dash is looking good. I tucked my cage as close to the upright as possible also. Which means you either notch the dash ends or two piece the dash. And neither is easy. But once done it looks good. Cool ramp truck too
    mad mikey and loudbang like this.
  15. Inland empire hot rods
    from so cal
    Thanks! Yeah the dash was 3 pieces basically.
  16. Inland empire hot rods
    from so cal
  17. rod1
    rod1
  18. mad mikey
    mad mikey
    Mind Blowing. Fantastic, incredible. WOW! Amazing. Not enough words to describe it.:)
  19. Inland empire hot rods
    from so cal
    Thanks very much!
    SOHC427, 31chevymike and mad mikey like this.
  20. Inland empire hot rods
    from so cal
    Moon tank mounted, MC mounted, next up pedals and clutch mc.
  21. Inland empire hot rods
    from so cal
  22. No_Respect
    No_Respect
    from So-Cal
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I like how the engine is set back. G***er legal
  24. oj
    oj
    I'll guess the RH location of the barrel valve is due to the magneto front drive? the fuel tank is lower than the pump?
  25. Inland empire hot rods
    from so cal
    thanks!
  26. Inland empire hot rods
    from so cal
    This is an efi conversion, 8 injectors in hat, 8 in manifold, the front tank and appropriate mech fi stuff is just to "sell the look" the efi stuff will be hard to see
  27. lippy
    lippy
    from Ks
    Wish I had that kind of money and talent. !!!!
  28. patsurf
    patsurf
    i'd be glad to have EITHER! --i'm not going to be greedy....
  29. RodStRace
    RodStRace
    Are those coils under the dash?
  30. Inland empire hot rods
    from so cal
    Yes, coil on plug, these are high voltage coils, all going thru dash thru "mag" and onto plugs
    brEad and Blown Red Ram like this.
