Alcoa Ansen domed pistons for a '56 265 engine
Discussion in 'Off Topic Hot Rods & Customs' started by David Neese, Feb 18, 2025.
  1. David Neese
    David Neese
    I have a set of pistons that are what the ***le says. There is a number 40 cast in the inside bottom of them. How do I know if that's forty over or what does it mean?
  2. Fordors
    Fordors
    Stock bore 3.750 + .040 = 3.790 - a few .001’s for clearance.
    Measure them 90* to the pin bore and below the ring lands.
    Pictures would be nice, it won’t help with the size, we just like to see them.
    RodStRace and Deuces like this.
  3. David Neese
    David Neese
    Here is a pic of them
    Deuces and Fordors like this.
  4. Fordors
    Fordors
    Alcoa forged the blanks and Ansen did the machining on them. Looking at them I suspect they are about 12-1 compression, maybe even a bit higher. Not a lot of demand (I’d say less than zero) for 12-1 265 pistons but cleaned up they would make cool garage art.
    Deuces likes this.
  5. David Neese
    David Neese
    I'm actually going to use them in my 265 and run E85 with them.
    Tim, TA DAD, Dick Stevens and 3 others like this.
  6. Fordors
    Fordors
    Wow, didn’t see that coming. Sounds like an interesting project, keep us informed.
    Deuces and TrailerTrashToo like this.
  7. David Neese
    David Neese
    Yeah I'm using them along with a Comp Cams 285B-6 solid lifter cam.
  8. David Neese
    David Neese
    Do you have any idea what size rings these make take as in 1/16", 1/16" & 3/16" or???
  9. Fordors
    Fordors
    Chevrolet originally used 5/64 and 3/16 but I don’t know what Ansen machined their pistons for. They’re most likely 5/64 but you can measure with a decent ruler to make sure.
  10. Deuces
    Deuces
    I'd use Jo-blocks or feeler gauges.....
    TA DAD and Dick Stevens like this.
  11. chicken
    chicken
    from Kansas
    That should stir your soul when it idles! That cam is gonna be rowdy in a 265. ;):cool:
    David Neese, Tim and Dick Stevens like this.
  12. David Neese
    David Neese
    I'll have my engine guy check them for me.
    Deuces likes this.
  13. David Neese
    David Neese
    Yes sir it'll sure hit pretty hard. I originally bought it for a 283 I was gonna build for my '55 but the block turned out to not be good so I got the 265.
  14. chicken
    chicken
    from Kansas
    Looking at those pistons I'd guess the rings are 1/16 1/16 3/16. Pretty common back then.
  15. David Neese
    David Neese
    That's what I was thinking also but someone said they could be 5/64", 5/64", & 3/16".
  16. chicken
    chicken
    from Kansas
    And they could be since that's a popular option,but I think it looks like the two upper rings are thinner than 5/64.
  17. Dick Stevens
    Dick Stevens
    And the smart thing to do is measure them so he gets the right rings instead of going by what you or anyone else thinks they look like.
    Deuces and SS327 like this.
  18. Fordors
    Fordors
    They could be 1/16 but I think 5/64 was still pretty common in that era. I believe it wasn’t until the ‘70’s when race pistons started using 1/16 compression rings and Chevy was still using 5/64 into the 1970’s.
  19. David Neese
    David Neese
    I'm not just gonna buy any ring set until I know what they are. I appreciate the reply.
    Deuces and Dick Stevens like this.
  20. David Neese
    David Neese
    I have the original pistons from my engine. I will pull one of the rings off of one of them and check thwir fit.
  21. chicken
    chicken
    from Kansas
    Well, obviously. o_O
  22. Fordors
    Fordors
    The point of my comments is that a ring set for a
    3.750 +.040 bore could be hard to find. Chevrolet used 5/64 compression rings on the early SBC’s but the suggestion was made that Ansen may have machined their pistons for 1/16. I believe it was later that 1/16 came into use and if I understand your comment you want to check the original rings from your 265. You can take a top ring off one of the original pistons and use it as a gauge to verify what ring set will fit your Ansen pistons.
    You don’t want to buy a scarce HTF ring set that won’t work with your forged pistons.
  23. Deuces
    Deuces
    Is Egge still in business????...
    They might have ring sets for the 265 +.040" pistons....
  24. David Neese
    David Neese
    What are these pipe plugs for? Do they go into the water jacket??
  25. Fordors
    Fordors
    Yes, they go to the water jackets. They were put in at the factory and holes there were used to remove the casting sand. The factory used pipe plugs because it would be troublesome to access a leaking core plug there. Leak in a plug in the side of the block? No problem. Leak at rear of block? Pull the trans but still not that big a deal.
  26. David Neese
    David Neese
    So they could be pulled out so I can wash out the water jackets really good then huh?
  27. Fordors
    Fordors
    Sorry, I failed to mention that they will not need to be removed. In fact they would be a real bear to get out.
    Do you plan to get the block cleaned by the machine shop or attempt to do that yourself?
  28. David Neese
    David Neese
    Have the machine shop do it.
    Fordors likes this.
  29. Deuces
    Deuces
    Removing and replacing those can distort the block a couple of grand.... I'd leave those alone....
  30. David Neese
    David Neese
    I am going to. I'm gonna wash it out the best I can prior to it going to the machine shop.
    Deuces likes this.
