Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Six Ball
    Six Ball
    from Nevada
    Good thing about old Chevys they are made of firewood.
    282doorUK, J.Ukrop, Outback and 3 others like this.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Just like that, we're back! I've been on the move as of late, but tonight I was able to climb on down to the garage and make a little bit of progress.
    First, I dis***embled, cleaned, and re-***embled my master cylinder.
    Then, I bolted the pedal mount into position. I have some hardware arriving on Thursday so, with any luck, I should finally be able to wrap up the pedals this weekend.
    While I was OOO, I scored a pretty neat old chrome coil mount from a fellow H.A.M.B.er. It's set up for dual coils, so it will require a little bit of modification. Nonetheless, it'll look right at home on this project.
    Like I said, it's a brief update, but it's better than no update at all!
  3. Tim
    Tim
    from KCMO
    Very nice. That boot fits well
    Stogy, Six Ball and 41 GMC K-18 like this.
  4. RodStRace
    RodStRace
    Just get another coil. Rods and race cars sometimes had a spare in place and ready to go. It can be your anti-theft device. Just move the coil wire over to the unconnected coil.
    I wouldn't put a fuel filter right there, but maybe something else can be used as an alternative.
    Speedy Canuck, Stogy, drdave and 4 others like this.
  5. Tim
    Tim
    from KCMO
    Bottle of hot sauce lol
    Stogy, Outback, Six Ball and 2 others like this.
  6. RodStRace
    RodStRace
    It's San Francisco. Maybe a handy squirt bottle of anti-fog?:D
    Just need to find a vintage container.
    Outback, Woogeroo and Six Ball like this.
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks guys. I love the creativity. Coils were on sale, so I scooped up a spare. We’ll see how we do from a space standpoint once it arrives.
    The setup seems sturdy, but we may also add some reinforcement when the time comes. Talk about a custom piece! Note the sleeves for the coils—they were once chromed, believe it or not.
    tr_rodder, Stogy, Ragged Edge and 6 others like this.
  8. Crusty Chevy
    Crusty Chevy
    I believe the master cylinder boot needs to go on the push rod first with the first rubber convolute after the small opening over the washer on the rod. I think one has to stuff the rod in from the big end and work the nut end out the small hole end leaving the disc inside. I say this as mine was like yours is now and when the pedal was pressed in the boot eventually collapsed and stayed stuck down with nothing mechanical to pull it back out. This left the oversized for the rod hole boot end open to scoop up water thrown back from the front wheels which eventually rusted the bore. I have not rectified this yet on mine and could be incorrect but plan to do this on re***embly.
  9. Tim
    Tim
    from KCMO
    Joey, this is the perfect time
    For a Citric acid soak for about 12 hours. It’ll eat the rust and not touch the chrome. Do a neutralizing rinse and a little protective oil and that thing will look just right!
    Stogy, Outback, warbird1 and 4 others like this.
  10. wuga
    wuga
    Since Tim brought it up, not everyone knows the Citric routine. We use it all the time and it is the best. We buy this from Amazon:
    Viva Doria 100% Pure Citric Acid, Food Grade, Fine Grain, 5 lb (2.27 kg)
    I ran across this some years back and the process is right on.
    Cleaning with Citric Acid
    I want to share the process as I know it for fast, cheap and easy rust removal using powdered citric acid. I've seen folks using mol***es, vinegar, electrolysis and expensive store bought products to remove rust. I leaned about citric acid from my brother a few years ago and have never looked back. Here is the process I’ve used with great success, hope this can help my fellow Hambers. step 1 I bought this 5lb bag of powdered citric acid online for about 16$ shipped. For these parts I'll use about 3 cups dissolved in warm water then added to my 5-gallon bucket. A big Rubbermaid tote works well for this also. I’m not to scientific with the measurements, this stuff is cheap enough.
    Here are the parts and some small hand tools I'll be de rusting. Normally I'd give these a quick pressure wash first but my washer wouldn't cooperate so I did these as is.
    Once your acid is mixed dump it in the bucket, where your parts are already covered in water.
    I bought a length of 3" ABS and capped one end. Put the solution in the pipe. It is a great way to clean long thin parts that don't want to fit in your soaking tub.
    Warren
    Now it's as easy as letting them soak, 24 hours is usually plenty, sometimes I leave the worst parts in longer. The Citric acid is mild enough it won't damage anything but the rust.
    Now after your soak pull out your parts and they don’t look impressive just yet.
    If you have a pressure washer use it here. If not, a wire or nylon bristle brush will clean off all of the loosened rust. Give it a quick wash and your parts should look like this. This is after a grand total of maybe 5 minutes with a wire brush. The rust will literally just scrub right off. Its that easy! When I’m finished with the acid bath, I neutralize it with a cup of baking soda then dump it out in my side yard. It doesn’t even hurt the gr***. The acid is so mild it doesn’t burn your hands or put off any odor. I did all of this batch in my garage with no problems at all. Also, I've painted parts that have held up very well for several years after this process. Hope this helps you guys. If anyone else wants to add to this thread feel free to do so.
    Deutscher, Stogy, Outback and 3 others like this.
  11. RodStRace
    RodStRace
    I've got a chrome wrap on this coil, too. If it doesn't clean up, you could paint them or cut out new ones from sheet, if you want the look.
    Stogy, Outback and Six Ball like this.
  12. Tim
    Tim
    from KCMO
    I’ll add I also use the dried flakes plus water. I don’t think I generally use that strong of mix and I don’t think I’ve ever had to use a burst of any sort on them. But I also haven't soaked anything that looked like it was off the ***anic. Typically I can just use my hand and sluff the **** off it and dunk it again.
    It also seems to work for a very long time, I’ve used the same container of acid for months with no real leading results. I use a dawn dish soap and water bath to neutralize it and heat/ towel dry with some wind or a fan.
    I’ve also painted the parts with zero ill effects years later. I believe on my model A build I have photos of a chromed column switch from the steering support I soaked. I’ll see if I can find it
    Stogy and Outback like this.
  13. Six Ball
    Six Ball
    from Nevada
    They beat me to the citric acid bath recommendation. You may be surprised how much chrome is still there. It also doesn't hurt most paint and some stickers & decals.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    We have tales of travel, action, and adventure that are long overdue, but I wanted to share yesterday's triumph here. IMG_9880.jpg
    With the help of Yama and Blue, the engine and transmission are back in the car.
  15. 41 GMC K-18
    41 GMC K-18
    The patina on the Carrhart bib overalls, blends perfectly with the vintage resoled boots!
    Looking good young road warrior! And so is 2.0 !
    The 39 guy, J.Ukrop, Six Ball and 2 others like this.
  16. Outback
    Outback
    from NE Vic, Oz
    What a great photo love it!
  17. Tim
    Tim
    from KCMO
    Que old man voice “this generations always laying down on the job!”
    Pretty *****in man :) keep on truckin summers almost here and you’ve almost got a roadster!
  18. ROADSTER1927
    ROADSTER1927
    HA HA that looks Great!
    Stogy, J.Ukrop, osage orange and 2 others like this.
  19. Should be UNDER the car doing something!
    Stogy, J.Ukrop, Woogeroo and 5 others like this.
  20. hotrodA
    hotrodA
    Hey! That guy looks like he’s after your catalytic converter!
    Oh……never mind.
    SR100, Six Ball, The 39 guy and 3 others like this.
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So I've been out sick this week, but I have time for a quick update before it's time to go to sleep.
    Friday:
    Dreamt of vintage tin.
    Saturday:
    Rode old cycles to check out one of my favorite San Francisco houses, built in 1948.
    Then, Saturday night, I fine-tuned the pedals.
    And plugged in the steering, too.
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    You know how it is. Just a little lay-on-the-ground-in-the-dark-heating-a-pedal-with-a-MAP-gas-torch.
    By 9 p.m., the pedals cleared in a satisfactory way.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sunday
    Called up Blue and Yama. Yama's still recovering from the accident, so he was supervising and shooting photos with his 2010s #digicam for that early H.A.M.B. look.
    Setting the scene.
    Making moves.
    Touchdown.
    Joey Ukrop: Happy Camper.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Blue and the machine.
    The whole operation went extremely smoothly. Last time we did this, I was fresh off of knee surgery and was kind of making things up as I went along. This time, with three sets of hands, we made quick work of it. Maybe you already do this, but I devised the plan of marking the U-joint and driveshaft with a paint marker to align the splines. That, plus a jack and a block of wood under the transmission, helped big time. IMG_7977.jpg
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So that does it for tonight's installment. I'm feeling pretty worn out from all the travel this month, so I'm taking a little bit of time to step back, order some odds'n ends and get a plan of attack for the next stage of this project.
    Up next, we have:
    • Brake lines
    • E-brake
    • Steering box install
    • Fan/PowerGen
    • Radiator, shell, and headlights
    The plan is to put the body back on in April, but that's years from now!
  26. RodStRace
    RodStRace
    Fuel system
    Exhaust
    Wiring
    Final once over, torquing everything still accessible, topping up fluids and installing cotter pins.
    Sand and prime body before it's set on the finished frame! ;)
    Looking great, Joey, I really like the QC sticking out the rear!
    EDIT: Thanks to Yama and Blue for pitching in and getting it further!
  27. Dick Stevens
    Dick Stevens
    41 GMC K-18, J.Ukrop and Six Ball like this.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone! I’m excited that things are really coming together. Speaking of Yama, we’re organizing a little old bike/old car show next Sunday at Ocean Beach. For those of you who are local, we’d love to see you down by the water.
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Rode the XLCH to an estate sale today to hunt for a few specialty tools, one of which miraculously found. Also, down in the garage, I got a feel for the old chrome breather/fuel pump setup.
  30. richard noble
    richard noble
    You look like a Garden Gnome…..Ha!
    J.Ukrop likes this.
